Results 1 to 2 of 2
Reload Thread: M3 box
    MemphisLove.'s Avatar
    MemphisLove. is offline CarAudio.com Elite
    Nov 2005
    PCB, Fl.
    28
    583
    M3 box
    15" downfiring memphis M3.
    The original plans say for a optimum vented enclosure 3.5/36/14.5x1.5x13. If someone can tell me what that means lol id appreciate it. or if someone has a better box plan
    j3bus2k3's Avatar
    j3bus2k3 is offline Si vis pacem, para bellum
    Aug 2004
    St. Pete, FL
    6,276
    Re: M3 box
    probably 3.5ft^3 tuned at 36hz...the 14.5"x1.5" are your slot port dimensions and a length of 13." But that doesnt seem like too much port area. Check the sticky above for a similar box and you'll be good to go.
    AIM: SPL Performance1
    /////Alpine 9835
    Active Processing via Coustic XM7
    Dayton 7" Mid-woofer with Seas Neo Tweet
    JBL/Crown 1100 & Power 300.4
    12" TC3000 Based Custom in 2.25ft^3 at 32hz
    Wallet say But I say
    References:Moe Lester, PV Audio, sss18734, DJ-Torn, dleccord, jiggy2dmax, Negativezeroz, Bama350z, TeamPSI, dB Dom, Kenny Pollock, Flossinon24s, Patfitz9 (x2), AppleBonker, BassAddictJ, the727kid, skadude016, CaliKid, Thumper88, Djman37, TeamQuakeCelica, Cerob, Pimpedout97x, Troy_Audi0, got_focus?, Karleon, Jamaica2G, rtillare, dumple, JohnnyBusa, mattmcss, whitem1ke88, nineball
  1. box is finshed (pics)
    By bass maniak in forum General Discussion
    Last Post: 11-30-2005, 10:17 AM
  2. XXX and Box Situation
    By fury in forum Enclosure Design & Construction Help
    Last Post: 07-05-2004, 04:21 PM
  3. General Box Building Rules?
    By BooLeaN in forum Enclosure Design & Construction Help
    Last Post: 06-23-2004, 12:51 AM
