Results 1 to 11 of 11
Reload Thread: Built a box, thinking about going with a different design *pics*
    Bolognablake's Avatar
    Bolognablake is offline Redefining body roll
    Feb 2006
    Nashville, TN
    1,359
    Well I built a box for my 12" Dayton RS HO, using moe-lesters design (thanks - btw), it's 2ft^3 tuned to 31 hz. It's really loud, but alot more boomy than I was hoping for, I'm sure some of that's due to how low it's tuned. The box seemed too 'Boomy", and it sounded a little sloppy. It was my first time building a box, and the fist time I've ever used a ported box., so I didn't really know what to expect. I don't listen to rap often at all, but just for kicks I'll (well, to show off) crank it every once in a while.
    Here are my Questions:
    Would a box tuned higher yeild a little better SQ? Or would I just be better off going with a sealed box?
    Also, If I added another sub and decided to use a vented enclosure, would it be okay if the shared the same air space? (for simplicity of box design)
    Comments suggestions?
    Pics of the sub and box:
    1996 Jeep Cherokee 4x4 2-Door
    4.0L I6 | AX15 5-Speed | NP231 TC | 2" RE BB | 31" Bridgestone Dueler M/T | Trimming
    2006 Chevy Trailblazer EXT
    4.2L I6 l Auto l 2WD l Stock
    Facebook
    saywhat?'s Avatar
    saywhat? is offline satx120, jealous?
    Apr 2004
    H'Burg Mississippi!
    30
    11,175
    Re: Built a box, thinking about going with a different design *pics*
    looks like a nice build. those daytons may need to be dropped down a little on tuning, im not sure though. i know they do well in Home Theatre though. Looks good though!
    Chevyaudio's Avatar
    Chevyaudio is offline :poof:
    Mar 2005
    Back in the Dirty BR, Louisiana
    31
    13,157
    SQ=Lower tuned boxes/Sealed Boxes
    Buckshot's Avatar
    Buckshot is offline CarAudio.com Elite
    Jan 2005
    Michigan
    563
    Quote Originally Posted by Chevyaudio
    In other words, tuning this box, or any other similar box 'higher' in frequency will not yield the results you're looking for. Most likely...
    An easy way to play with tuning and finding out what you like is:
    Build a standard ported box for your sub, and use a 4" PVC pipe port, or multiple pipes if its required. Tune it real low. Once installed and listened to, take JUST THE PORT back out, and hack a chunk off. Doing this will make the tuning higher each time, and it will be easy for you to find out which frequency you should tune your next ported sub project at.
    Sorry, I babbled a bit... I tryed!
    spitfirees20's Avatar
    spitfirees20 is offline i have the re boner
    Mar 2006
    Rhode Island
    446
    Hey Bolognablake, I recognize you from the Jeep Forum, sweet deal man. Do you like the volume you have now, want more, less, etc? What are you going for, more sound quality or sound quality level?
    PV Audio's Avatar
    PV Audio is offline The Vision of Sound
    Apr 2004
    Indy
    29
    19,655
    Not trying to be mean, but in the first two pics the lines were nice and clean...but in the end there was glue everywhere. What happened?
    Feb 2006
    Nashville, TN
    1,359
    Quote Originally Posted by PV Audio
    I over did the glue on the top, and I used a paper towel to wipe it off, but instead I just kind of smeared it all over the place. I keep telling myself I'm going to carpet it, but I doubt I'll get around to it.
    Facebook
    Feb 2006
    Nashville, TN
    1,359
    Quote Originally Posted by spitfirees20
    I'm shooting more for sound quality, as most of the time I have my subs turned almost all the way down on my HU. But I'd like to be able to make it uncomfortably loud if I want to.
    Kinda like having a 600HP big block in a daily driver, 95% of the time you don't need most of the power, but you have to burn a little rubber every once in a while.
    Facebook
  9. #9
    Feb 2006
    Nashville, TN
    1,359
    Quote Originally Posted by Buckshot
    That's a good idea. Would some where around 28hz be too low?
    Facebook
  10. #10
    PV Audio's Avatar
    Apr 2004
    Indy
    29
    19,655
    Low 30s will be fine.
  11. #11
    Feb 2006
    Nashville, TN
    1,359
    Well, looking at the 'Woofer Buying Guide' in the Parts Express catalog, they recommend 1.34ft^3 tuned to 28hz for a vented box. My box was 2ft^3 @ 31hz. Maybe I was just giving the sub too much room?
    Facebook
  1. New box design for 4 12"s *some pics*
    By Rawr-DQ in forum Enclosure Design & Construction Help
    Last Post: 04-03-2005, 10:16 PM
  2. built my first box!!! really bad pics...
    By g30ffr3y in forum Enclosure Design & Construction Help
    Last Post: 12-08-2004, 05:47 PM
  3. Competition SPL box design - as big as possible?
    By danfortner in forum Enclosure Design & Construction Help
    Last Post: 04-28-2004, 10:03 PM
  4. Box for 12 inch 8000 MTX
    By Clarion_Guy in forum Enclosure Design & Construction Help
    Last Post: 01-01-2003, 03:54 AM
  5. ATTN: Jmac!
    By MUGEN! in forum General Discussion
    Last Post: 12-31-2002, 04:42 AM
