Page 2 of 2 FirstFirst 1 2
Results 16 to 22 of 22
Reload Thread: Sub cutout
  1. #16
    Ingleside's Avatar
    Ingleside is offline Senior VIP Member
    Nov 2005
    San Francisco
    36
    381
    Re: Sub cutout
    look at the pic of my W6 below...
    the cut out diameter is how big you want to make the hole in your sub box from one side to the other. your owners manual should tell you how large to make this hole.
    if you are going to use a compass to draw your circle divide the cut out diameter in half to get the radius.
    to make your box flush mount you'll want to now measure the flush mount diameter so you can build another baffle to put on top of the regular baffle your box already has. most of the time the manual will also tell you this measurement. i usually cut them out so spec to give it a clean look but you can make it a little bigger than the woofer if you want.
    lastly, if you really want a clean look measure the how deep the mounting flange is on your sub and get a piece of wood about the same thickness. so the sub doesnt stick out too much or it isnt sunk in too deep.
    i think the alpine X and R subs have a pretty think rubber surround on their mounting flanges so another panel of 3/4 MDF should do the trick.
  2. #17
    Jun 2005
    Eagan, MN
    28
    1,320
    1 Post(s)
    Re: Sub cutout
    haha u can see threw the surround? what material is that?
    2010-11 Project:
    1 15" DC XL
    1 ap3k
    1 3.5 cube adjustable port box (Box will be sub up port to drivers side, unless you have tips on better position?)
    Hoping to break 150 db's when this is all done in a 2dr Blazer!
    Reppin MINNESOTA
  3. #18
    AlpineUser's Avatar
    AlpineUser is offline Bumpin
    Mar 2006
    St. Charles Mo
    31
    549
    Re: Sub cutout
    Quote Originally Posted by nissanrider06
    i think it is a grill
    1998 Monte Carlo
    Alpine CDA-9857 hu
    2 Alpine Type R 12" Subs
    Audioque 1200d
    diamond hex 5.25"s with 1" tweets
    diamond d3's 6X9"s
    rockford 450.4
    3ish cubes @ 33Hz
    bigger box coming soon!!
  4. #19
    Ingleside's Avatar
    Nov 2005
    San Francisco
    36
    381
    Re: Sub cutout
    yeah, thats the JL W6 grill
  5. #20
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Re: Sub cutout
    Quote Originally Posted by AlpineUser
    jasper?
    Jasper circle jig for the router. If you have a router I highly suggest one. Once you use it, you might end up smacking yourself for not getting it sooner
    5 % equipment
    90 % install
    5% beer
  6. #21
    ramos's Avatar
    Dec 2001
    Virginia
    53
    10,329
    104 Post(s)
    Re: Sub cutout
    Like they said it's the grill. W6 doesn't have the surround covering everything like the W7 does.
    5 % equipment
    90 % install
    5% beer
  7. #22
    danteBirosel's Avatar
    danteBirosel is offline CarAudio.com Veteran
    Aug 2005
    San Diego, CA
    30
    7,123
    3 Post(s)
    Re: Sub cutout
    Quote Originally Posted by ramos
    x2, bought mine couple weeks ago, and omg i fell in love with it....
    also known as... LivinLife
    [ References ] q-ball (kickerL5), ssackett (yellowtop), chaarlieee, Kenny Polluck (motoBTheadset), BassAddictJ, Iamamp3pimp (enclosure), lilmaniac2 (paintball gun, motors, & others), cardinalsfan (I paid half, den paid the rest), amorsh (sub), nVRuckus, LeofromtheH (amp), k4rts, rassymx, sublime0420x, lax916, ilaydit, KSilver2000, Raven, mtdewelf, SiX, KngOfThePkngLot, Dozy_production, supa_c, davidfre21, trevor87, bumpn_gt, Pistonsfav70, dbubble & moreeee!!!
  1. Cutout diameter
    By danteBirosel in forum Enclosure Design & Construction Help
    Last Post: 02-19-2006, 10:14 PM
  2. 15" XXX cutout size
    By jtomsic in forum General Discussion
    Last Post: 03-13-2005, 10:09 PM
  3. Need cutout size for JL 15w6
    By BiaBia in forum General Discussion
    Last Post: 08-19-2004, 05:17 PM
  4. need sub cutout length
    By marleyskater420 in forum Enclosure Design & Construction Help
    Last Post: 08-16-2003, 12:54 PM
  5. cutout for 12"re se
    By nick310 in forum Subwoofers
    Last Post: 02-04-2003, 03:18 AM
