Results 1 to 6 of 6
Reload Thread: Tempest Box @ 35 HZ?!?!?
    Daniel's Avatar
    Daniel is offline Caraudio.com
    Apr 2002
    SFLA
    27
    864
    Alright, I was told that people could help me out with how large the port should be and how far it should go in by posting the interior dimensions of my box, and the T/S Parameters of the sub.
    Re 3.50 ohms Le 2.9 mH
    Qms 6.7 Mms 195 grams
    Qes 0.40 Cms 0.34 mm/N
    Qts 0.38 Rms 3.5 N*s/m
    Fs 18.8 Hz Sd 779 cm^2
    Vas 317 liters BL 14.2
    Xmax 16.4 mm one way EBP 47
    SPL 89.1 dB @ 1W/1m No 0.51%
    Pmax 400W per voice coil; 750W total to the driver Distortion <3%, 16 Hz - 200 Hz, @ 103 dB SPL
    And for the Interiors of the Box: ( L x W x H )
    L= 30in.
    W= 14.5 in.
    H= 15.5 in.
    I want to tune it to 35 HZ, and assuming I was to use to front of the box, and the far right side (still in the front) of the box as part of the port, how far to the left would it be, how tall would it be, and how far should the boards go into the box? I really want to finish this because its been sitting around for quite some time now, if you guys dont want to do the math, can you tell me how to make the port using the T/S paras and the Internam Dimensions!
    Thanks in advance.
    2010 Nissan Frontier
    working on it...
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,311
    5 Post(s)
    Let's see here. If you want a slot port it would be 15.5" x 3" x 20.5" long.
    If you want a square port 5" x 5" x 9.9" long both would get you to the 35hz tuning.
    5 % equipment
    90 % install
    5% beer
    Daniel's Avatar
    Apr 2002
    SFLA
    27
    864
    awesome, i thought no one was gonna reply, and i have one more question, you said 20.5" long, is that how far it goes into the box? plus do i have to makke the side that long to, im not sure that its easy to explain, but like i make the 15.5" side going into the box 20.5", do i have to make the 3" side that long to?
    working on it...
    ramos's Avatar
    Dec 2001
    Virginia
    48
    10,311
    5 Post(s)
    You just need on piece of wood to make the port. Three sides will be created by the enclosure. You just need one piece 15.5" x 20.5" When you make the front baffle cut it 3" short. And put the piece you cut in. And blam you have a slot port.
    5 % equipment
    90 % install
    5% beer
    Daniel's Avatar
    Apr 2002
    SFLA
    27
    864
    hold on, the box is like a big rectangle, and i want the sub to be facing out ima try and show u here real quick
    ______________
    | | | The ( O ) represents the 15" tempest, and the
    | ( O ) | | }15.5" lines at the end are the slot port., thats how i
    |____________|__| Internal want the front to look,
    _______
    | | This is the side of it, and as you can see if i wanted to
    | | 15.5" make the port 20.5" deep, it would go right through my
    |_______ | Internal box. How would i tune it to 35hz witht the port in the
    ^ front like shown? Please help and i hope these
    15.25" diagrams show you what i mean,
    Internal
    thanks in advance
    working on it...
    Daniel's Avatar
    Apr 2002
    SFLA
    27
    864
    ______________
    _______
    Internal
    thanks in advance
    wow that got real screwed up after i posted it.
    ______________
    |.............................|....| The ( O ) represents the 15" tempest, and the
    |..( O )...................|....| }15.5" lines at the end are the slot port., thats how i
    _______
    |.................| This is the side of it, and as you can see if i wanted to
    |.................| 15.5" make the port 20.5" deep, it would go right through my
    |_______| Internal box. How would i tune it to 35hz witht the port in the
    Internal
    working on it...
