Results 1 to 7 of 7
Reload Thread: 91 Sonoma Reg Cab Cut threw/Sub Enclosure
    SethPhillips's Avatar
    SethPhillips is offline I'sa Playa
    Feb 2005
    Northern Utah
    28
    9,013
    15
    Allrighty. OK I have only got to look at 3-4 trucks in person with the cut threw. where the cab and bed are cut and the sub enclosure lay's in the bed and fire's into the cab.
    at first i didnt want to do it to my truck but that was then. i wanna do it now.
    right now im trying to find info on how to.
    i dont want a cab covering my bed i think that looks goofy. im going to put a fiber glass taunue cover on it so the cut will have just under the rear glass
    thinking 4 Bravox EDX'S in a "V" shape and 2 Cadence ZR-S10 amps
    couple kenetic batts
    but i want to do it right i dont want it to leak!
    anyone with info? pics??
    Feb 2005
    Northern Utah
    28
    9,013
    15
    Re: 91 Sonoma Reg Cab Cut threw/Sub Enclosure
    come on? any info???
    ax600's Avatar
    ax600 is offline CarAudio.com Elite
    Mar 2005
    grand forks N.D.
    694
    Quote Originally Posted by SethPhillips
    I do not have any pics, but I had a blow thru in a f150 a few years back. I ran two Kicker comp 15's in the bed actually attached to the back of the cab, and the bed was clearanced arround the box. This is a the best way I know to have a single cab truck that totaly POUNDS. you will love it.
    Sent from your moms crusty vag using tapatalk
    Feb 2005
    Northern Utah
    28
    9,013
    15
    i definatly want 4 or more subs just wondering if i should go seald or ported?
    bimma85's Avatar
    bimma85 is offline Can't be ****** ;)
    Nov 2004
    midwest
    9,944
    I hope you have lots of experience. Not something I would just go and "try".
    REFS:JimJ, DBfan187, jimj, ology audio, excelerater, private pastry, kenny pollock, priosonnumber6, johnnyber, mattmmcs, vosschs, lax916, davidfre21, iceteebone, cd6551, vladd and others that I cant remember off the top of my head
    Quote Originally Posted by snb778
    I feel like when im bumpin once it gets dark....the street lights often go out. I was driving home the other night and like 3 street lights went out in like 15 minutes.
    Does this happen a lot to any of you??
    Also if you have had the twix ice cream......isnt it amazing!
    Quote Originally Posted by RumbleNTheTrunk
    damn. 8 10"s?........80" of cone area FTW!
    ax600's Avatar
    Mar 2005
    grand forks N.D.
    694
    Mine were in a band pass , ported thru the cab. It really depends on the music you listen to, or how acuratly you want to reproduce the music. I am running a single 15'' sub now in a large ported box tuned to 32hz and am really happy with it. It is loud as he**.
    Feb 2005
    Northern Utah
    28
    9,013
    15
    Im certified in auto body rapair and finishing
    im just trying to figure out a box style
    i listen to mostly rap
    i want tight clean bass but at time i wanna bang it
  1. Cut threw enclosure for reg. cab trucks pro's,...and con's.
    By SethPhillips in forum Enclosure Design & Construction Help
    Last Post: 01-20-2010, 02:41 AM
  2. Anyone have a ranger reg cab?
    By RynoThePirate in forum Subwoofers
    Last Post: 03-01-2005, 11:58 PM
  3. s10 reg cab
    By derekls in forum Wiring, Electrical and Installation Help
    Last Post: 02-11-2004, 11:41 AM
  4. Replies: 4
    Last Post: 03-17-2002, 03:32 PM
