Results 1 to 3 of 3
Reload Thread: areo ports
    Dec 2005
    canada
    54
    areo ports
    How do i find the displacement of areo ports.
    I want to build my box to 3 cubes after sub and port displacement.
    Goint to use 3x 4" areo ports
    Hu- Pioneer DEH-P680MP
    Comps Orion P6.2
    Comp amp Nine.2
    Sub Waiting for new XXX 15
    Sub amp Orion 2500D
    All 0 gage wire
    300amp excessive amperage alt
    3 Yellow tops
    j3bus2k3's Avatar
    j3bus2k3 is offline Si vis pacem, para bellum
    Aug 2004
    St. Pete, FL
    6,276
    Re: areo ports
    simple volume..(area of the base)x(the height)->(pi x r^2)x(h)...since there's 3, multiply that final number by 3.
    AIM: SPL Performance1
    /////Alpine 9835
    Active Processing via Coustic XM7
    Dayton 7" Mid-woofer with Seas Neo Tweet
    JBL/Crown 1100 & Power 300.4
    12" TC3000 Based Custom in 2.25ft^3 at 32hz
    Wallet say But I say
    References:Moe Lester, PV Audio, sss18734, DJ-Torn, dleccord, jiggy2dmax, Negativezeroz, Bama350z, TeamPSI, dB Dom, Kenny Pollock, Flossinon24s, Patfitz9 (x2), AppleBonker, BassAddictJ, the727kid, skadude016, CaliKid, Thumper88, Djman37, TeamQuakeCelica, Cerob, Pimpedout97x, Troy_Audi0, got_focus?, Karleon, Jamaica2G, rtillare, dumple, JohnnyBusa, mattmcss, whitem1ke88, nineball
    IonSQL's Avatar
    IonSQL is offline CarAudio.com Veteran
    Jan 2006
    Aviston, IL
    42
    4,216
    Re: areo ports
    Make sure you use the outer diameter of the port, not 4", which is the inner diameter. Might not make a big difference with Aeroports, but if you use PVC ports, that 1/4" wall can start to add up when you start adding port area...
  1. ports ports ports
    By bhsswrstlr in forum Enclosure Design & Construction Help
    Last Post: 03-14-2005, 11:02 AM
  2. good info on round vs. slot ports...
    By g30ffr3y in forum Enclosure Design & Construction Help
    Last Post: 01-25-2005, 09:52 PM
  3. Multiple ports different sizes
    By DFW40 in forum Enclosure Design & Construction Help
    Last Post: 12-13-2004, 04:18 PM
  4. multiple ports
    By paikiah in forum Enclosure Design & Construction Help
    Last Post: 01-03-2003, 05:50 PM
