Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Reload Thread: Requesting box plans, will pay
    bholtmeier's Avatar
    bholtmeier is offline Holtskill
    Sep 2005
    nebraska
    25
    1,483
    Need Box Plans For a 12" Mag D2......left Moe a PM but no response...i'm workin with 28W 13.5H and 15D......lookin to get as close to 2cf as possible, and tuned as low as possible......will pay.....thanks, get back to me
    Refs:
    Patfitz9,Farkel,PowerNAudio,Qtrhorse,theCybe,Kicke R_TauruS,SWEET06CAMRY, mike dressure,vernisog, Racerx250, iceteebone
    Camaro Box build tutorial
    http://www.caraudio.com/forum/showthread.php?t=217344
    Nov 2004
    Grove City, OH
    26
    2,236
    Re: Requesting box plans, will pay
    OK i'll do one irght now
    *DIBS*
    we'll work out a price later
    Nov 2004
    Grove City, OH
    26
    2,236
    BTW if you have AIM send me one at gcadidas13
    pjm2211's Avatar
    pjm2211 is offline bar-b-q or mildew
    Jul 2005
    Omaha, NE
    37
    182
    19
    what part of NE are you in? I'm in Omaha. mokedaddy ..(is in Omaha too)..who is a member of this forum is good at box/vent dimensions. he designed my vented box, and it sounds amazing. pm me if you want to hear it and are in/near omaha.
    '98 Accord V6
    eclipse 8455
    '99 US Amps Xterminator 400X
    '99 US Amps Xterminator 150X
    2 alping type r 12's -vented to 33Hz
    Rainbow Profi CS230
    Nov 2004
    Grove City, OH
    26
    2,236
    Using every inch of your given dimensions, and 30 square inches of port area, the lowest tuning I can get is 37hz without dropping the port area more,
    Nov 2004
    Grove City, OH
    26
    2,236
    Just for comparison... 2 cubes with 24sqin port area brings tuning down to 32hz
    any way the box could be just a tiny bit bigger?
    edit: going to class now, be back round 5
    Ctminime's Avatar
    Ctminime is offline 1/2 Team SubHertz
    Nov 2005
    Lincoln, Nebraska
    25
    1,070
    well its in a 95 camaro so unless u made the box less wide at the bottom (witch IMO wouldnt be THAT hard to do) i know for a fact that ure not gonna get any bigger then that.... we had to remove some plastic from bholtmeiers hatch on his car to get that box to fit in......
    VEHICULAR-'01 Monte Carlo Ls
    DECK-Alpine CDA-9855
    FRONTS-Type-R 6.5" components
    FRONT STAGE AMP Kicker Kx250.2
    SUB AMP-Elemental Designs-eD NinE.1 @ 1 ohm
    SUB-Stereo Integrity Magnum D2
    Wiring-1/0 AWG www.weldingsupply.com
    Electrical-2X Optima Red Tops
    Box-2.0 @ 32 HZ
    REFS- toolowtoogo, cadenceowner, chibahawk, fived, bibby
    Term Lab Scores
    RL-P 12's TL scores---142.8 db drag 138.2 in the bass race..
    SCORES ABOVE AT 30 HZ!!!! (box tuning that is)
    SI MAG 12 TL scores
    Box tuning 32hz - 140.9 @ 46hz
    bholtmeier's Avatar
    Sep 2005
    nebraska
    25
    1,483
    Those are my MAX dimensions, any bigger will not work. 24 sq inch of port would be fine.....what kinda net volume do you get with that?
    Refs:
  9. #9
    Nov 2004
    Grove City, OH
    26
    2,236
    Quote Originally Posted by bholtmeier
    That's still exactly 2 cubes - but that's also before driver displacement (about 0.15 cuft)
    So basically you're looking at 1.85 cubes tuned to 33 with 24 sq in of port area
  10. #10
    Nov 2004
    Grove City, OH
    26
    2,236
    Box
    Removed Top
    Dimensions are follows:
    Top and Bottom: 28" Wide x 15" Deep
    Left and Right: 12" Tall x 15" Deep
    Front (Baffle): 12" Tall x 23.75" Wide
    Back: 12" Tall x 26.5" Wide
    Port 1: 12" Tall x 12.25" Wide
    Port 2: 12" Tall x 12.25" Wide
    Volume: 2.00 Cubic Feet (before sub displacement)
    Port Area: 24 Square Inches
    Port Length: 28.25" (14.00" before bend, 13.25" after bend, 1.00" end correction)
    Tuning Frequency: 31.6 Hz (disregards sub displacement, will be a touch higher)
  11. #11
    Nov 2004
    Grove City, OH
    26
    2,236
    After a bit of thinking here are a few things you should know
    When building your box, cut the hole for the sub last
    Also make sure to use shorter screws near the sub hole so that you aren't screwing into where you will jigsaw later
  12. #12
    PV Audio's Avatar
    PV Audio is offline The Vision of Sound
    Apr 2004
    Indy
    24
    19,672
    What program is that? I'm only wondering because that view makes it look trapezoidal.
  13. #13
    Nov 2004
    Grove City, OH
    26
    2,236
    Autodesk Inventor 10
  14. #14
    PV Audio's Avatar
    Apr 2004
    Indy
    24
    19,672
    Hmm, never heard of it. Looks good though.
  15. #15
    bholtmeier's Avatar
    Sep 2005
    nebraska
    25
    1,483
    Have made a fiew boxes before, just had cancelation issues with the first one and not enough port area on the second. Have yet to hear my mag in a decent box.
    Refs:
  1. will pay for box plans, but have questions
    By jchancellortool in forum Enclosure Design & Construction Help
    Last Post: 09-18-2005, 04:46 PM
  2. box plans needed *PICS* cash waiting
    By roy_barber99 in forum Enclosure Design & Construction Help
    Last Post: 08-27-2005, 10:26 AM
  3. box plans needed *PICS* cash waiting
    Last Post: 08-27-2005, 05:04 AM
  4. need help with box plans please
    By btmorris972 in forum Enclosure Design & Construction Help
    Last Post: 06-27-2005, 10:19 PM
