Results 1 to 2 of 2
Reload Thread: what kind materials to use for box?
    jd_man_90's Avatar
    jd_man_90 is offline Rollin on 14's
    Oct 2005
    Trenton, Fl
    28
    198
    I am building a 5 cu ft slot ported box for 2 12's. I have almost completely designed it so i just want to check and make sure i have desided on the right materials. I am planning on using 1'' MDF is this an appropriate thickness. I am going to be putting 2 12'' type r's in the box. also the box is not ver deep so there arent going to be any large panels so i wouldn't think there would be much danger for the box flexing. I am planning on using 2.5 inch coarse thread sheetrock screws. i know these are the type of screws to use but is that a good lenght? I am planning on using spiked "t" nuts with the matching bolts to attach the subs. what do most people use when attaching their subs? for sealing the sub in i am thinking of purchasing some speaker sealing caulk from parts express. it is sold in 36in lengths for only $1 each. is this a good choice for sealing? this is my first system and i am a perfectionist so i want to do it right. thanks for your help!
    vosschs's Avatar
    vosschs is offline Banned
    Oct 2004
    just east of STL
    31
    5,658
    Re: what kind materials to use for box?
    Quote Originally Posted by jd_man_90
    you wont have too worry about flexing i dont think since your using 1'' wood, also you dont need 2.5 inchs screws, just use wood glue and 1.5 inch screws, maybe 1.75 if you want, just pre drill the holes and use wood glue
  1. what kind materials to use for box?
    By jd_man_90 in forum Enclosure Design & Construction Help
    Last Post: 11-12-2005, 06:25 PM
  2. What kind of Audio guy are you?
    By psycho72 in forum General Discussion
    Last Post: 02-09-2005, 10:52 PM
  3. materials
    By fyrspray in forum General Discussion
    Last Post: 05-19-2003, 07:29 PM
  4. materials
    Last Post: 05-16-2003, 01:52 AM
  5. what kind of box?? Need help fast
    By RadioActive in forum Enclosure Design & Construction Help
    Last Post: 12-04-2002, 03:34 PM
