Results 1 to 9 of 9
Reload Thread: Port Questions...
    Psyence's Avatar
    Psyence is offline Customized
    Aug 2005
    Canada
    43
    445
    Port Questions...
    When you use some online port calculators for round ports, and it gives you say 12" for the port length, is that for EACH or do I divide that by 2?
    ALSO -- How do you know when you should use 2 ports, or just 1 for round ports?
    Psyence
    2008 Sport Trac Adrenalin
    Stock Nav System w/ Sync
    Audison Bit One Processor
    Audison LRx 5.1K Amplifier
    Hertz MLK165's Bi-Amped Components
    Hertz ES250 (2) Sealed Woofers
    tRiGgEr's Avatar
    tRiGgEr is offline CarAudio.com Veteran
    Jan 2004
    San Diego, Ca
    35
    12,794
    5 Post(s)
    Re: Port Questions...
    You would determine to use more than one port if you need more port area.
    And the port calculator will only give you an answer to a direct question. If you list one port it will give you the length for one port. If you list two ports than that is the length for each port...
    Quote Originally Posted by Scoobydoo View Post
    Before poking fun at others at least learn to spell. I won't go into all the gammar mistakes!
    Irony?
    Your sig... Im trying to figure out if you think he spelled grammar wrong. Because, he didn't. Irony indeed.
    Psyence's Avatar
    Aug 2005
    Canada
    43
    445
    Okay, cool.
    This is my dilemma if anyone can pitch in thier 2 cents...
    I have a 2.3061cuft box (excluding port displacement, but including woofer displacement) with a single Type-R in there...
    Id like to have 2 ports, just for the looks mainly --
    4" port would (Estimating on port area taken down to 2.0cuft) = 34.7inches long each -- This is way too long for the space i have available.
    2" Ports would be (Estimating on port area taken down to 2.1cuft) = 7.5" long each... this works, well.
    BUT -- Am I going to get port noise?!
    Hizelp!
    Psyence
    Psyence's Avatar
    Aug 2005
    Canada
    43
    445
    You know what, Ill draw my box, and someone if they have time, can give me some suggestions...
    Psyence
    tRiGgEr's Avatar
    Jan 2004
    San Diego, Ca
    35
    12,794
    5 Post(s)
    Port noise - YES.
    Use at least two 3" ports.
    Irony?
    Psyence's Avatar
    Aug 2005
    Canada
    43
    445
    K, thisi s my mess...
    The ports can go UP, or FORWARD (Sub is facing up)
    Woops the dimentions are incorrect for measurements for #2 triangle, but the area is right, just wrote it down wrong.
    So, yeah, there is lots of space on the side of the subs facing up, which is prefered, but not much space... unless I start the port close to the sub, and use an angle peice to run it to the sides...
    Or it can go on the face, on the left side of the above pic facing forward...
    Or whatever else anyone ccan think of... im looking on tuning 28-30hz or so
    Psyence
    Psyence's Avatar
    Aug 2005
    Canada
    43
    445
    Any port noise issues using 2 - 1x8" Slot Ports?
    Anyone?
    Psyence
    Psyence's Avatar
    Aug 2005
    Canada
    43
    445
    Hello?
    Psyence
  9. #9
    xmax-1's Avatar
    xmax-1 is offline Member
    Nov 2005
    Pooler, Ga
    50
    58
    With 2 cubic feet of airspace, I would go withn 50sq.in. of vent area......That would be roughly (4) 4" round ports.
    Chris Stavely
  1. slot port vs. round port
    By hdave in forum Enclosure Design & Construction Help
    Last Post: 03-24-2005, 10:14 PM
  2. need help figuring this out. im tryin to learn ;)
    By IgnoreMe in forum Enclosure Design & Construction Help
    Last Post: 09-02-2004, 03:05 PM
  3. Frequencies below port tuning questions
    By loudfivepoint0 in forum General Discussion
    Last Post: 08-19-2004, 11:21 PM
  4. J-
    By BigBoomer in forum Enclosure Design & Construction Help
    Last Post: 01-06-2003, 03:50 PM
  5. Box for port wars...
    By F150Matt in forum Enclosure Design & Construction Help
    Last Post: 01-05-2003, 03:22 PM
