Results 1 to 4 of 4
Reload Thread: What does box tuning frequency means?
    DIGIDIGIBOMBO's Avatar
    DIGIDIGIBOMBO is offline Senior VIP Member
    Jul 2005
    Leb
    250
    Hi, i have used the search buttob etc...but what does it means when i tune a box for 20, 25 or 40Hz? i only know that the SSf must be set 1/4 of an octave lower than the tuning frequencies so that very low frequencies dont pass to the sub. What will happen if a box is tuned to 30 rather than 40Hz? Thx
    Jul 2005
    Leb
    250
    Re: What does box tuning frequency means?
    the SSf decides how low frequencies can pass, if box is tuned to 40Hz it means that below 40Hz the woofer will have a very high displacement and will be dammaged? What is the best average tuning frequency, it depends on what thx again
    ruckus's Avatar
    ruckus is offline Banned
    May 2005
    Miami, FL
    39
    1,879
    Quote Originally Posted by DIGIDIGIBOMBO
    your tuning the ports in the box, certain lengths of port tune it to different frequencies.
    ruckus's Avatar
    May 2005
    Miami, FL
    39
    1,879
    depends on the sub, and no 40hz wont damage most subs. I run my subs at 40hz but it does sound peaky for some subs to run that high. most subs for daily drivers tune between 25hz-37hz depending on the sub, music listened to, desired output (SPL, SQ)
  1. bigger box = lower bass???
    By infinity1412 in forum Enclosure Design & Construction Help
    Last Post: 04-22-2004, 01:01 PM
  2. box tuning for kicker L712
    By jmhbowler in forum Enclosure Design & Construction Help
    Last Post: 01-23-2004, 10:05 AM
  3. tuning for kicker 15" box
    By somekook in forum Enclosure Design & Construction Help
    Last Post: 11-22-2003, 10:53 AM
  4. Box for 12 inch 8000 MTX
    By Clarion_Guy in forum Enclosure Design & Construction Help
    Last Post: 01-01-2003, 03:54 AM
  5. ATTN: Jmac!
    By MUGEN! in forum General Discussion
    Last Post: 12-31-2002, 04:42 AM
