Results 1 to 6 of 6
Reload Thread: first work with plexi / lexan
    carhartt_ford's Avatar
    carhartt_ford is offline Junior Member
    Aug 2005
    Fargo, ND / Great Falls, MT
    35
    so i'm about to do an install for an MX van. one of the ideas that the owner had is to put either plexiglass or laxan pieces between the subs and the amps.
    first question... is it really going to make much difference if i use plexiglass or lexan?
    i am planning on bead blasting it, but i'm torn between either dulling out the numbers or dulling out everything but the numbers. any thoughts?
    djman37's Avatar
    djman37 is offline SOLID
    May 2004
    DFW, TX
    8,344
    Re: first work with plexi / lexan
    what numbers???
    Doug Blohm
    Team Southern Bass
    Chevyaudio's Avatar
    Chevyaudio is offline :poof:
    Mar 2005
    Back in the Dirty BR, Louisiana
    30
    13,157
    Depending on the install,If there is going to be any kind of lighting (Neon, LED) Behind the plexi i would say leave the numbers clear. If no lighting will be present leave everything but the numbers clear.
    theCybe's Avatar
    theCybe is offline sector three
    Dec 2004
    Columbus, OH
    6,004
    Drill 5mm holes in the sides of the lexan; Just large enough for LEDs.
    If you blast everything but the numbers/letters, then the numbers/letters will be "outlined" in light, and the rest will be illuminated;
    If you blast only the letters/numbers, they'll be outlined in light AND illuminated.
    If you don't need to see through it, put a mirror or mylar film behind it; Should make a great effect.
    cxixer's Avatar
    cxixer is offline Member
    Nov 2004
    Hays, KS
    41
    Lexan (polycarbonate) is flexible, not sturdy like plexiglass (acrylic). There is a huge difference, these are not the same material!
    Aug 2005
    35
    Quote Originally Posted by djman37
    what numbers???
    it's an MX van... the numbers in question are his racing numbers.
    thanks for the suggestion of using mylar. the box will be housed under a seat taken from a conversion van. the subs will be on each end of the box. the plexi will be the front plates to separate enclosures, with the amps mounted in the middle.
  1. Help on getting speakers to work properly
    By jblaze05 in forum Wiring, Electrical and Installation Help
    Last Post: 08-16-2005, 03:35 AM
  2. where to find 1" plexi??
    By bumpin_blazer in forum Enclosure Design & Construction Help
    Last Post: 05-02-2003, 03:14 PM
  3. plexi window
    By saber in forum Wiring, Electrical and Installation Help
    Last Post: 12-20-2002, 02:22 PM
