Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 44
Reload Thread: 1/2 inch
    tmilla's Avatar
    tmilla is offline MMMMMMM Cheese
    May 2005
    Wisconsin
    23
    152
    1/2 inch
    im about to build my first box and can i use 1/2" boards instead of 3/4"
    HU: Panasonic CQ-C7301U
    Sub: Pioneer TS-W256C
    Sub Amp: Power Acoustik A520-2HP
    PhatTonyDeMarco's Avatar
    PhatTonyDeMarco is offline C0CK,its whats for dinner
    May 2005
    West Palm Beach, FL
    7,729
    Re: 1/2 inch
    What size box, how many subs, what subs?
    If you use enough bracing, and do it properly, you shouldnt have a problem.
    Why cant you use 3/4"?
    tmilla's Avatar
    May 2005
    Wisconsin
    23
    152
    Re: 1/2 inch
    its 1 10" pioneer ts-w256c
    well i have some 1/2" laying around
    the demensoins for the box is 30"w x 11"h x 6.5"d
    flakko's Avatar
    flakko is offline Veteran (my butt)
    Aug 2004
    So Cal
    27
    10,480
    Re: 1/2 inch
    im pretty sure you will be fine. i take its a seald rite?
    just brace it a lil and youll be fine
    1998 Acura TL 3.2L
    Crappy Sansui DVD player
    Stock Speakers
    "Hi ladies, my name is Wo-Hen Nankan"
    "I like you. You have balls. I like balls."
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,691
    Re: 1/2 inch
    Half inch what? MDF?
    or particleboard...
    tmilla's Avatar
    May 2005
    Wisconsin
    23
    152
    Re: 1/2 inch
    its like layered sheets
    yes its sealed
    how do i brace it
    JimJ's Avatar
    Jun 2004
    Hillsborough, NC
    31,691
    Re: 1/2 inch
    Plywood? Or many different layers of different shapes and sizes...
    flakko's Avatar
    Aug 2004
    So Cal
    27
    10,480
    Re: 1/2 inch
    layered sheets... sounds like particle board huh?
    if so, then no.
    bracing is just glueing pillars (so to say) of mdf in your box to keep the box from fleixing. you have to take into account the dispacement too theres other kindsa bracing also.
    1998 Acura TL 3.2L
    Stock Speakers
  9. #9
    May 2005
    West Palm Beach, FL
    7,729
    Re: 1/2 inch
    Particle Board = No No for boxes
    Go out and get a 4' x 8' sheet of 3/4" MDF for like $10.
  10. #10
    tmilla's Avatar
    May 2005
    Wisconsin
    23
    152
    Re: 1/2 inch
    its all solid sheets
    its ply wood
  11. #11
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,737
    20
    Re: 1/2 inch
    Is the title of this thread also the size of your *****? Use 3/4" poosie
    NG
    http://crunktimes.com/ct/
    nG - BSEE
  12. #12
    May 2005
    West Palm Beach, FL
    7,729
    Re: 1/2 inch
    Quote Originally Posted by ngsm13
    Is the title of this thread also the size of your *****? Use 3/4" MDF poosie
    NG
  13. #13
    Classick96's Avatar
    Classick96 is offline So Fresh And Clean
    Jun 2005
    Daytona Beach, FL
    25
    278
    Re: 1/2 inch
    plywood = no no use mdf...just go to the store and buy it its cheap...
  14. #14
    flakko's Avatar
    Aug 2004
    So Cal
    27
    10,480
    Re: 1/2 inch
    Quote Originally Posted by PhatTonyDeMarco
    WHERE?
    1998 Acura TL 3.2L
    Stock Speakers
  15. #15
    Jdizzle's Avatar
    Jdizzle is offline tha dirty dizzle ;)
    Jul 2005
    Carthage, NC
    25
    2,676
    Re: 1/2 inch
    yea we tried to be cheap about it and used plywood for a box for a fbx 15 and within 5 minutes of playin the box fell apart, spend some money and get mdf you'll be happier with the look in the end
    and around here a 4 x8 sheet os 3/4 is like 25 bucks
    99 G cherokee
    headunit: deh-p720 premeir
    Midbass: Diamond Hex 6.5
    Tweeter: LPG NFa
    Front stage amp: eclipse xa4000
    Woofage: eD 16kv.2 3.5 @ 30hz
    Sub amp: Eclipse xa1000
    87 Nissan Hardbody
    HU: Deh-p 3000ib
    Comps: eD 6500
    Front stage amp: pg 4.0:2
    Woofage: 2 9kv.2s sealed
    Sub amp: PG 4.0:2
  1. 3 inch port to small for AA Atlas 12?
    By Bartak1 in forum Subwoofers
    Last Post: 06-27-2005, 12:52 AM
  2. 5/8 inch board
    By tclay77 in forum Enclosure Design & Construction Help
    Last Post: 04-09-2005, 11:11 PM
  3. two 10 inch audiobahn, or two ten inch MA audio's?
    By xplicit in forum General Discussion
    Last Post: 04-12-2003, 03:31 PM
  4. 10 inch or 12 inch w7's?
    By paintball9908 in forum General Discussion
    Last Post: 03-10-2003, 12:27 PM
