Results 1 to 8 of 8
Reload Thread: port displacement
    f150ff's Avatar
    f150ff is offline Junior Member
    Feb 2004
    La.
    20
    port displacement
    Can someone help me figure port displacement
    60ndown's Avatar
    60ndown is offline CarAudio.com Veteran
    Jun 2005
    ca
    3,590
    ruckus's Avatar
    ruckus is offline Banned
    May 2005
    Miami, FL
    44
    1,879
    Re: port displacement
    you want to figure out the displacement from your box?
    LxWxH/1728=ft^3
    f150ff's Avatar
    Feb 2004
    La.
    20
    no port displacement
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,449
    11 Post(s)
    Port Displacement
    if it uses of the sides of the box for one side of its port wall, then:
    (port height) x (port length-wood thickness) x (port width + wood thickness) / 1728
    if the ports in the middle of the box, and has its own walls, then:
    (port height) x (port length - wood thickness) x [port width + 2(wood thickness)] / 1728
    f150ff's Avatar
    Feb 2004
    La.
    20
    Thank you guys for the help
    King_Of_Da_Souf's Avatar
    King_Of_Da_Souf is offline ~Playa 4 Life~
    Jun 2005
    MS
    55
    Will round ports and slot ports of the same displacement yield the same tuning?
    Does port area = port area, or is it more complex than that?
    Decipha's Avatar
    Decipha is offline www.EFI Dyno Tuning.com
    Mar 2005
    New Orleans, LA
    30
    3,265
    2 Post(s)
    ,,,depends on the diameter of the round port and the face of the slot port
    supercoupe enthusiast x9
