Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Reload Thread: Need some Fiberglass help...pics inside
    bumpn_gt's Avatar
    bumpn_gt is offline CarAudio.com Elite
    Sep 2003
    Columbus, WI
    35
    1,055
    18
    I started fiberglassing the trunk of my caddy and this is the first time ever using fiberglass. I am running 2 Digital Designs 9515's with a Planet Audio 2500d on each......
    my question is, how many layers of mat and resin do I put on before I start the fleece?? I have used a little over 3 gallons of resin so far......
    Attached Thumbnails Attached Thumbnails Need some Fiberglass help...pics inside-picture-046.jpg   Need some Fiberglass help...pics inside-picture-044.jpg   Need some Fiberglass help...pics inside-picture-043.jpg   Need some Fiberglass help...pics inside-picture-045.jpg
    bumpn_gt's Avatar
    Sep 2003
    Columbus, WI
    35
    1,055
    18
    Re: Need some Fiberglass help...pics inside
    hit me up on AOL under bumpngt if you can help me out yet tonight in the next hour or so.......otherwise just post up
    bcarpenterfhl's Avatar
    bcarpenterfhl is offline Kiss Me I'm Shitfaced
    Sep 2004
    San Francisco/Hillsborough, CA
    30
    2,211
    17
    3 gallons? holy ****! how many layers do you have on there?
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    32
    15,426
    21
    yea dude. that might be enough
    how many layers is it?
    you would have been better off just laying down 3\4" MDF for the flat spots, and then glassing them together on the corners tho...
    bumpn_gt's Avatar
    Sep 2003
    Columbus, WI
    35
    1,055
    18
    I can still lay mdf......I have about 6 layers
    I was just worried about it shattering with all the pressure the subs produce. I had a 9 cube wood box in there, but I wanted something bigger
    Sep 2004
    30
    2,211
    17
    if thats really only 6 layers (with 3 entire gallons?), then you should probably still put mdf on the flat parts. are you sure you used gallons and not quarts? otherwise, 6 layers is about fine.
    BeanII's Avatar
    BeanII is offline Senior VIP Member
    May 2005
    Dallas
    459
    six layers? you should be fine. Remember it'll have the support of the car behind it.
    If it's strong enough for you to stand on (which it should be by now) it'll be fine.
    May 2004
    Dayton, OH™
    15,659
    4 Post(s)
    I'd do atleast 10 layers myself, but I like making **** sure things don't flex, I can stand on the molds for my door pods... **** I can jump on them and heel stomp them and their fine.
    Overkill=my friend...
    If you're worried about the large flat spots, soak some rope in resin and put it in there, that's what Ramos used to always reccomend...
    Caraudio.com - Where the average member couldn't wire a SPST toggle if they had to.
    More proof.
    Quote Originally Posted by Andrew_as View Post
    I need a program or something that will help me find mounting depth without having to build box and such...
    No, Andy, I'm sure the context is fine.
  9. #9
    InhumanAcura's Avatar
    InhumanAcura is offline 1/3ofTEAM PwNAGE..*****es
    Feb 2004
    South Florida
    8,639
    43 Post(s)
    6 layers is still gonna flex...any thing that is backed by something solid anyway. build as much as possible out of MDF.
    being your as far as you are, Id slap some resin down on the mold then lay some fleece over it and soak it for some extra stregnth...then go from there. worked for my previous box.
  10. #10
    bumpn_gt's Avatar
    Sep 2003
    Columbus, WI
    35
    1,055
    18
    so lay fleece on the interior of the mold and soak that? I have plenty of mdf laying around that I can throw that in also.
    I'm positive I used gallons.....I used as much as I could each time I laid a layer down.....have gone through quite a lot of matting also......I don't trust standing on it yet....granted I am 300+ lbs also.....
  11. #11
    Sep 2004
    30
    2,211
    17
    whats the glass' density?
  12. #12
    packerfan's Avatar
    packerfan is offline CarAudio.com Veteran
    Jan 2003
    Beaver Dam WI
    31
    3,809
    Quote Originally Posted by bumpn_gt
    When your done, we can both test it out by standing on it....550lbs+ should test it Lookin good otherwise, id lay MDF down in any flat spots possible. Fiberglass is only realy strong in curvy areas and fairly weak on just flat spots.
    Eclipse CD7000
    MTX TA7804
    Eclipse SC8365
    MTX TA92001
    9 Elemental Designs 13Ov.2's (15.5 cu ft ported box)
    O/1g All around, 2 Yellow tops, big 3.
  13. #13
    Feb 2004
    South Florida
    8,639
    43 Post(s)
    exactly, with the amount of surface area your have, you might want to try something denser like carpet you cover a box with etc...
    more mdf than f/g...
  14. #14
    bumpn_gt's Avatar
    Sep 2003
    Columbus, WI
    35
    1,055
    18
    its about .25" across the entire mold........I had some metal screen laying around so I threw that in there also.....cut it into strips and resin'd it in there.......the only spots that worry me are the big flat spots....I will just mdf those parts.....its about 20-25lbs now
  15. #15
    packerfan's Avatar
    Jan 2003
    Beaver Dam WI
    31
    3,809
    Oh hey colin, hit me up on AOL @ berettasql...im gonna be needing some amps soon and still wondering if you can get those PA's for a decent price.
    Eclipse CD7000
    MTX TA7804
    Eclipse SC8365
    MTX TA92001
  1. ported fiberglass box.
    By derek33 in forum Enclosure Design & Construction Help
    Last Post: 02-24-2005, 04:09 PM
  2. Grand Am Custom trunk ideas, pics inside
    By Trancer in forum Enclosure Design & Construction Help
    Last Post: 08-17-2004, 02:17 AM
