Results 1 to 11 of 11
Reload Thread: .707 vs .85
    jellyfish420's Avatar
    jellyfish420 is offline i design boxes .......
    Jul 2004
    STL ill side
    37
    4,234
    .707 vs .85
    i've been contemplating building a sealed box for my RL-p's. just to see what kinda sq these babies really got. now i wanna aim for a q of .707 right? the SS site recommends 2ft per 15, and by all the calculators i've used this is a q of right around .85, for a q of .707 i get a box of 3.25ft per 15. wouldn't the 2ft box tend to be a little peakier, and have a higher F3? what would be the advantage or disadvantage to either box? and what would you pick and why? thanks
    NEED A BOX DESIGN? PM ME
    HEAD UNIT
    860mp
    ACTIVE FRONT STAGE
    JBL GTO75.4 II
    RE 6.5
    VIFA XT25 ring radiator 1"
    SUB STAGE
    ega 1400d
    3HP FI
    STOLEN
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,300
    Re: .707 vs .85
    Quote Originally Posted by jellyfish420
    Assuming those Qtc values are correct; yes
    Well: 2cuft would be peakier, have higher mechanical power handling, have less low frequency extension, worse transient response and group dealy, and more output
    3.25cuft would have flatter frequency response, less overall output, lower mechanical power handling, better transient response and group delay and better low frequency extension
    I'd go for .707 for the better transient response, better low frequency extension and higher efficiency
    80INCHES's Avatar
    80INCHES is offline EPICENTERGLUED 2 ME
    Jan 2005
    WESTCHESTER, NY
    37
    6,962
    5 Post(s)
    Re: .707 vs .85
    i'm with sqeak...i would pick the .707
    but remeber the bigger the box the better the low extention and the less power u need 2 power your sub.....but u dont want to build a box to big then the sub will act as if it was in a free air situation
    80
    Jul 2004
    STL ill side
    37
    4,234
    Re: .707 vs .85
    i emailed mike @ soundsplinter and this was the response:
    Both the 3.25 cu ft and the 2 cu ft net volumes will work, but in all
    honesty the response difference between the two will be quite minimal.
    Attached you will find the leap graph for the RL-p15 exhibiting the
    relative
    differences.
    The Butterworth (magenta solid) box is 2.1 cu ft net volume.
    The Bessel (tan dashed) box is 3.55 cu ft net volume.
    The Enhanced Q (green dotted) is 0.95 cu ft net volume.
    Essentially, you are asking for a comparison between the Butterworth
    and
    Bessel alginments, which as evidenced in the attached image, follow
    each
    other quite closely. I do not think that a 2 cu ft box will be much
    more
    peaky than a 3.25 cu ft box at all to tell you the truth.
    HEAD UNIT
    860mp
    ACTIVE FRONT STAGE
    JBL GTO75.4 II
    RE 6.5
    SUB STAGE
    ega 1400d
    3HP FI
    STOLEN
    Raven's Avatar
    Raven is offline Lacking social skills!
    Dec 2004
    Michigan
    33
    4,618
    3 Post(s)
    Re: .707 vs .85
    That is going to make such a small difference that if you do notice it, you're doing better than I would be.
    Jul 2004
    STL ill side
    37
    4,234
    Re: .707 vs .85
    Quote Originally Posted by Raven
    well it works out perfect this way. since there is no audible difference, i will be able to build it @ 3.25 sealed, and if it doesn't suit my needs then i can port that box and lower it to 2.5 ported. instead of going w/ 2 sealed and me not liking it, and having to build a whole new box
    HEAD UNIT
    860mp
    ACTIVE FRONT STAGE
    JBL GTO75.4 II
    RE 6.5
    SUB STAGE
    ega 1400d
    3HP FI
    STOLEN
    saywhat?'s Avatar
    saywhat? is offline satx120, jealous?
    Apr 2004
    H'Burg Mississippi!
    30
    11,175
    Re: .707 vs .85
    ooooor u could build that and put on a external port on it, and add a couple 2x4's maybe to drop it down around 3 cubes, right in the median of the reccomended specs.
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    Re: .707 vs .85
    I think you meant "IB situation"...and for some subs, that's perfectly alright. Elemental Designs' O series were an example of a sub that excelled in infinite baffle setups.
    Remember:
    IB = seperated front and backwave
    Free air = front and rear waves mingle with each other (no baffle used)
  9. #9
    80INCHES's Avatar
    Jan 2005
    WESTCHESTER, NY
    37
    6,962
    5 Post(s)
    Re: .707 vs .85
    or u could put them in a bandpass box
    80
    i can design one 4 u...but u have to build it
  10. #10
    chubby's Avatar
    chubby is offline CarAudio.com Elite
    May 2004
    NC
    1,557
    Re: .707 vs .85
    ew^
    i drive a honda element.
    -Eclipse AVN h/u
    -custom fiberglass doorpods
    -CDT 7.2usx comps
    -mmatts SQ####? amp (200x2wrms underrated)
    -"custom" TC9/XXX 15"
    -Cadence zrs-10
    and lots and lots of bjork.
  11. #11
    theCybe's Avatar
    theCybe is offline sector three
    Dec 2004
    Columbus, OH
    6,004
    Re: .707 vs .85
    ( What's the difference between an IB and a Dipole? )
  1. .85 cubes (internally) for Type R??
    By zimmer82 in forum Subwoofers
    Last Post: 05-31-2005, 10:08 AM
  2. Replies: 1
    Last Post: 10-02-2004, 09:46 AM
