Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Reload Thread: I was wondering if this would work...
    APitBullT's Avatar
    APitBullT is offline Senior VIP Member
    Dec 2003
    Scottsdale, AZ
    33
    218
    last night i was wondering if i can tape and put foil on the stock dash (it comes right off) and fiberglass it like that to make a custom dash, would that work?
    this is the stock indash
    http://ebay.carad.com/viewItem/viewA...isting=7720553
    its on the 6th row, 3rd picture on the right hand side
    1 RF T30001BD
    4 12" JL Audio 12W6V2-D4
    CDT HD-62 Comps.
    Optima Red Top 75/35 (Front)
    260 Amp Alternator
    Deep Cycle Yellow Top
    1/0 AWG Knukonceptz Wiring
    "Big 3" Upgrade
    djjdnap's Avatar
    djjdnap is offline FreakyFreaks ofall Freaks
    Mar 2002
    indy-nap-lis
    1,971
    6 Post(s)
    Re: I was wondering if this would work...
    The whole thing??
    hmm, looks like a project, i don't see y it wouldn't wrk.
    KArAudio.COM
    OMGROFLHI2ULOLLERZTITSHAHAHAHASEALEDMTWTFSTFUKTHXB YENO0B
    -Nick
    BeanII's Avatar
    BeanII is offline Senior VIP Member
    May 2005
    Dallas
    459
    I don't like using foil. It often sticks to the glass. Also it's not adhesive so the foil doesn't stick while your working with it. Just use masking tape. Two layers.
    djjdnap's Avatar
    Mar 2002
    indy-nap-lis
    1,971
    6 Post(s)
    You put the tape over the foil..(newbs)
    the foil is in case anything would get through the tape.
    KArAudio.COM
    -Nick
    APitBullT's Avatar
    Dec 2003
    Scottsdale, AZ
    33
    218
    well not the whole dashboard, just all the way to the second vent, look at the same row 2nd to last picture
    1 RF T30001BD
    CDT HD-62 Comps.
    260 Amp Alternator
    "Big 3" Upgrade
    APitBullT's Avatar
    Dec 2003
    Scottsdale, AZ
    33
    218
    should i put the tape in the inside or outside?
    1 RF T30001BD
    CDT HD-62 Comps.
    260 Amp Alternator
    "Big 3" Upgrade
    BeanII's Avatar
    May 2005
    Dallas
    459
    Quote Originally Posted by djjdnap
    Seriously? Newb? I'm offended! Dude I've been doing this a long time...... If you do two layers of tape (I recommend that you do the second layer perpendicular to the first layer) it won't soak through. Well, unless you use the blue painters maksing tape. It's really absorbent and will soak it through.
    The foil doesn't stick and can cause problems IMO>
    djjdnap's Avatar
    Mar 2002
    indy-nap-lis
    1,971
    6 Post(s)
    Since all it is is a mold you should be able to just foil and tape over it then fiberglass it, and as long as you have the same shape, ur in bussiness.
    Only thing is the brackets and what not that hold it to the car, you will need some way to secure it. but other than that i would say if it's too big ur fine since you can sand away, but if your to small you have to glass back over that piece.
    KArAudio.COM
    -Nick
  9. #9
    APitBullT's Avatar
    Dec 2003
    Scottsdale, AZ
    33
    218
    well if i did it in the inside, would it be hard to fiberglass the brackets that hold it in place?
    also how many layers would be good? the think looks presttye thick from the side view?
    1 RF T30001BD
    CDT HD-62 Comps.
    260 Amp Alternator
    "Big 3" Upgrade
  10. #10
    djjdnap's Avatar
    Mar 2002
    indy-nap-lis
    1,971
    6 Post(s)
    dont know what you mean by inside? The car?, no, it wouldn't matter, i dont think
    But You might be able to by some that are similar and attach them to your glassed dash, or take the ones off of ur stock dash if you dont plan on keeping it, or go to the junk yard and pull some from there.
    I mean you have alot of options.
    I've heard 7 layers for a box, so idk 7. I mean 7 layers is pretty strong, if your just trying to make it thick use some cloth.
    KArAudio.COM
    -Nick
  11. #11
    APitBullT's Avatar
    Dec 2003
    Scottsdale, AZ
    33
    218
    Inside as in me taking off the stock dash and putting fiberglass inside of it or put fiber glass outside of the dash
    1 RF T30001BD
    CDT HD-62 Comps.
    260 Amp Alternator
    "Big 3" Upgrade
  12. #12
    BeanII's Avatar
    May 2005
    Dallas
    459
    Are you sure you need to fiberglass it? A lot of the stuff you see in custom dash work isnt' glass. It's mdf or bondo or some other material.
  13. #13
    APitBullT's Avatar
    Dec 2003
    Scottsdale, AZ
    33
    218
    mdf? never seen that before, havent researched bondo, and i dont know how that works., i would think fiberglassing would be easy idk
    1 RF T30001BD
    CDT HD-62 Comps.
    260 Amp Alternator
    "Big 3" Upgrade
  14. #14
    BeanII's Avatar
    May 2005
    Dallas
    459
    mdf...... wood.
    What are you trying to make?
  15. #15
    djjdnap's Avatar
    Mar 2002
    indy-nap-lis
    1,971
    6 Post(s)
    Outside..
    Just make sure to get the pieces that go in like the vents you will want to get the depth of those also.
    http://www.sounddomain.com/ride/157597
    KArAudio.COM
    -Nick
  1. is this gonna work?
    By TreyX3X in forum Subwoofers
    Last Post: 09-02-2002, 08:42 PM
  2. just wondering what would be a good SQ system ?
    By qxfosgatesvt in forum General Discussion
    Last Post: 08-27-2002, 07:54 PM
  3. what would work out best?
    By wickedtwista in forum General Discussion
    Last Post: 08-12-2002, 07:55 PM
  4. Exhaust, Body Work
    By Simulator in forum Car Interior/Exterior Enhancements
    Last Post: 07-30-2002, 03:18 PM
  5. Will it work?
    By hyhat33 in forum General Discussion
    Last Post: 07-22-2002, 12:10 PM
