Results 1 to 13 of 13
Reload Thread: when is bracing needed?
    nas786's Avatar
    nas786 is offline Senior VIP Member
    Sep 2004
    central cali
    216
    9 Post(s)
    I'm gonna throw 2 12's in a 2.7 cu.ft. box, and i'll be feeding it around 1000 watts. Do you think I'm going to needed internal bracing for the box, or should it be fine? (i'm going to make it out of 3/4 in mdf).
    If you recommend bracing, let me know how you guys brace your boxes. I've never really seen it before, i'm not really even sure exactly what it is, pics would help.
    chinny's Avatar
    chinny is offline Banned
    Apr 2005
    Miami Dade
    29
    5,313
    Re: when is bracing needed?
    amedeuce's Avatar
    amedeuce is offline :crap:
    Jan 2004
    CA
    1,791
    3 Post(s)
    2.7 cubic ft. You should use bracing. Is the enclosure sealed or ported? Slot port or round.
    Slot ports add support to the enclosure. Round ports do not. If this box is sealed need to brace.
    References
    Sold to
    jamesdean,jonny101abc,LowLinc,bumpinaintEZ,TurboDu devr4,SVTRELAMPAGO,mk_ ,Burnout956,bonesninja,yenwen,bhsdriller,dalucifer ,BoondockSaints,WillyG4444, alfmoney,btnhfan,dB Dom, mazdakid, giltyler
    Bought From
    TeamPSI,ace_800, Zxcvtypo,bjfish11,atoz350,timbre-audio,Derrick824, lastcall,eclipsefool,rtillaree,PioneerPimp,6spdcou pe,ctmike,Thieroff
    amedeuce's Avatar
    Jan 2004
    CA
    1,791
    3 Post(s)
    where in cali are you??
    References
    Sold to
    Bought From
    nas786's Avatar
    Sep 2004
    central cali
    216
    9 Post(s)
    its a sealed box...i really wanted to go ported, but couldn't fit it comfortably in my trunk.
    I'm in sac, sometimes fresno to visit the parents. You in the valley?
    amedeuce's Avatar
    Jan 2004
    CA
    1,791
    3 Post(s)
    Quote Originally Posted by nas786
    lemoore
    References
    Sold to
    Bought From
    amedeuce's Avatar
    Jan 2004
    CA
    1,791
    3 Post(s)
    there is a good bracing tutorial on jlaudio.com if will come up.
    I like to use 3/4" x 3/4" oak stock for bracing.
    References
    Sold to
    Bought From
    FOSGATE JOE's Avatar
    FOSGATE JOE is offline R.F team and 49er fan!!!!
    Dec 2004
    CALI
    1,496
    Icon10 Re: when is bracing needed?
    Can never go wrong whith bracing!!just do it
    ref.gohillaaudio
  9. #9
    BlackHaze-'s Avatar
    BlackHaze- is offline Member
    Feb 2005
    The Sun
    80
    Just use some small peices of 2x4 works well, or an outer ring along the inside of the box
    Head Unit - Kenwood KDC MP625
    Subs - 6 12" RE REs
    Box - Around 10 sq inch Tuned to 34~35 Hz
    Amp - Elemental Designs Nine.1
    Alarm - Viper 791 XV
    Wiring - Audiopipe PK3000P 0 Gauge
    Box wiring - Knu Koncepts 12 awg
  10. #10
    Logikalliquid's Avatar
    Logikalliquid is offline CarAudio.com Elite
    Oct 2003
    SoVA
    33
    972
    What subs you putting in there? Is each sub in its own chamber? If so, 3/4in mdf should be thick enough to not need bracing. Then again, it doesn't hurt to throw a dowel rod or 2 in there for support.
    "The only thing we have to fear more than fear itself is the indifference of good men."
    -Boondock Saints
    '98 240SX SE
    US Acoustic 4085 - Crystal SSX615
    US Acoustic 2150 - JL 10W6
    REFs: http://www.caraudio.com/vb/showthread.php?t=94778
  11. #11
    djjdnap's Avatar
    djjdnap is offline FreakyFreaks ofall Freaks
    Mar 2002
    indy-nap-lis
    1,971
    6 Post(s)
    not needed for that lil bit of power,
    besides ur not gonna notice it that much anyway, u would only need it if you where trying to squeeze in a couple more db's
    KArAudio.COM
    OMGROFLHI2ULOLLERZTITSHAHAHAHASEALEDMTWTFSTFUKTHXB YENO0B
    -Nick
  12. #12
    nas786's Avatar
    Sep 2004
    central cali
    216
    9 Post(s)
    The subs are treo ssi, but only feeding them 500 watts a piece. They will have seperate chambers, but one wall is going to be shared. So, from the outside it will seem as though its just one box, but from inside it each will have its own seperate air space.
    I think I am going to go with bracing technique "C" from this ( http://www.jlaudio.com/tutorials/bracing/index.html ) website, which ameduece refered for me . It's basically triangles in the corners. It actually seems easier to do than the other ones, althought the website says different. I'm assuming i do only 4 corners per chamber, top/bottom and both sides...nothing in the rear, right? Also, using the same 3/4" mdf would be fine, yes?
  13. #13
    Oct 2003
    SoVA
    33
    972
    Quote Originally Posted by djjdnap
    That divider in the center and the strength of 3/4in mdf should be plenty unless your going to be competing.
    -Boondock Saints
    '98 240SX SE
  1. Replies: 4
    Last Post: 03-03-2005, 01:01 AM
  2. Bracing
    By LIGHTBEING in forum Enclosure Design & Construction Help
    Last Post: 11-15-2004, 03:25 PM
  3. bracing needed for ported box???
    By chinxtaboi in forum Subwoofers
    Last Post: 08-27-2002, 10:57 PM
  4. Box Bracing
    By Registered in forum General Discussion
    Last Post: 06-13-2002, 08:08 PM
  5. Replies: 11
    Last Post: 03-08-2002, 05:57 PM
