refs: zeuslicious(Christian)x8---nomad40---shallowfu---adio---pioneerpimp---fiercetimbo17---hayden---BLD 25--flakko---R-sosa----denim---woc47----lilmaniac2(Chad Kevin motha ****in Hicks)----newtitan---IgnoreMe(George)---JBGabriel---BuddyChrist----KingRanch---assman---MitchZ---JoeSmith502---The Low x2---Fiery---dragnix---tapout -383---splguru---sq wat 4---PimpDaddyq---Mr_Imperial---AbsoluteAudio---KHARPS---Sotelomichael---dt053---cmobley---SomeDonnieDude---ax600---SQcrewcab--Zachfeen--Power-Fanatic07--t4r505--
"You almost had me? You never had your subs. Ask any bass racer. Any true bass racer. Its not about how much a piece of equipment costs. Its how you install it."
well im deffently going to have to do something differnt its hard to keep up with every 1 in my class when they are doing 50s and up and im at a 43...i guess i will have to get another 15 and wall the stang thankfully i got all winter to get it all together and hopefully be ready for next season
- 1998 Ford Mustang -
Head Unit: Kendwood something
Front Stage-6.5 TREO TSX Componets
Speaker Amp- Digital Design C4a
Subs: 8 10" American Bass XD
Sub Amp: 2 RD D9s
Batts- 3 shuriken bt20 under the hood and 9 c&d 100ah batts.........15?.2 outlaw
REFS: B:Louisiana_CRX, amartin_72, SPL KID, Bhhong, K_schutte, Fraze, hllywood29, Andrew_as,S:Jh8909 ,info,teenT:robertawdgsx
Sub Amp: 2 RD D9s
Oh lawdy....
oh come on...lol
we just need to get a real wall in the stang and he will put up some numbers. or a smaller box with the 15 in the trunk...maybe around 3.5 cu ft??? which i know would put his numbers up at least 2-3 db which would also keep him out of a mod class with a single sub. and still sound great.
im going all out im going to wall it **** have n a box in the trunk i already had that before until my buddys dad backed into my quarter panel and i had to cut it out so they could get to the panel
Sub Amp: 2 RD D9s
thats just bad luck.
i use to have to build all my boxes for my 15s in my trunk in my old car.
you could still get loud with proper enclosure testing in the trunk with a single 15. defffffiantly possible. theres a guy on termpro doing over a 152+ in the trunk of a grand am with two 10s without sealing off the trunk from the back seats.
just do the wall and don't look back. You can get loud with a single sub in a comp style set up, but for beating on it daily cone area/motor strength is the key.
Unless you're TommyK then you just get loud with every single sub set up you do...
ya since once you wall it you cant look back out the window
Brian Stewart
Team Cactus Sounds
PART OF TEAM TMH
2003 Mitsubishi Eclipse
2 CACTUS SOUNDS ELT 12
2 CS 9000
4 DD9512s
2009 STREET A NORTH AMERICAN CHAMPION 156.5
Team Kicker (R.I.P.)
Team Sundown
Team Maxxsonics
Team XS Power
Team DD
Team Audio Technix
Team B2 Audio
Team Mechman
2008 Bassrace 130-139.9 Regional and National Champion
2006, 2007, 2009, 2010 and 2012 MECA Champion (S1, SR1, DB1, S2, S3, S4)
One DD 9510 powered by two Sundown SAZ-2500's
Kicker KS tweeters, MB Quart 5.25's active on an MB Quart DSC480
Kicker wiring throughout.
1st Incriminator Audio Rep in the US
Team SBC
Team IA
The Streetbeat Customz Alternator Line is now Available!
Refs - ssackett- parker g - forceww- slam- dbman150-annarbor84 - kylediablo - theMessenjah44 - Korn4life - One Bad MOFO -CrazyKenKid -Buck- Itnelavffej- Phemps - Flex'd- jnralp00 - brandonbm- AudioXtremes- 1phatclipse Strakele- bassaholic- Curse - Owners1-Villeza1-jf2oo6- DaRevrin- DDbump - adixon816 and 30 others
i didnt do that at the show lol. the day before.
Bookmarks
