Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 44
Reload Thread: dfw bass comp
  1. #16
    tsupra98's Avatar
    tsupra98 is offline CarAudio.com Elite
    Aug 2008
    waco, tx
    743
    Re: dfw bass comp
    Quote Originally Posted by dfw bass View Post
    there is a limit on battery's for the ama class the pro classs for you would be pro 0-750 max watts for this class is 3000 watts
    so what would be best for me to do? what class would i do best in? would it be best to pull the other batt out and go in the ama?
    Vehicle: 95 integra gsr
    Electrical System: stock alt with big 3 and batt in back
    Amplifier(s): vr2000d ran at 2 ohms
    Subwoofer(s): 2 12" L7s
    Box:4 cu ft tuned to 36 hz by designed immacomputer
    146.6db @ 41 hz
  2. #17
    dfw bass's Avatar
    dfw bass is offline Senior VIP Member
    Jan 2007
    fort worth tx
    275
    Re: dfw bass comp
    Quote Originally Posted by tsupra98 View Post
    what battery are you running
  3. #18
    tsupra98's Avatar
    Aug 2008
    waco, tx
    743
    Re: dfw bass comp
    up front it's stock . and in the back is a UB30H. i don't really know much about it but i guess it's 100ah batt
    146.6db @ 41 hz
  4. #19
    dfw bass's Avatar
    Jan 2007
    fort worth tx
    275
    Re: dfw bass comp
    the rules gives ama class competitors one batt under the hood and one addititonal batt or one two farad cap no limit on batt typye as long as its not sixteen volts, Oh by the way the 8 volt 6volt series batts are not allowed in ama class also stock alternater is required
  5. #20
    tsupra98's Avatar
    Aug 2008
    waco, tx
    743
    Re: dfw bass comp
    oh so i'm in the ama still? thats good. so do you have any idea what kind of numbers do people put up in the class i'll be in?
    oh and also how do i register to get in?
    146.6db @ 41 hz
  6. #21
    dfw bass's Avatar
    Jan 2007
    fort worth tx
    275
    Re: dfw bass comp
    I see your from waco I have a event set at the hooters there at the new road exit in june the 14th
  7. #22
    tsupra98's Avatar
    Aug 2008
    waco, tx
    743
    Re: dfw bass comp
    right on i'll have to keep i look out for it. also i'm totally new to texas and i'm flying back home spring break and i need to make a run up to the airport up there cuz thats there i'm flying out of so thats why i'm wondering about this comp thats going on up there feb 22nd. i'll do both in the same day so it all works out for me. i just need to know how much it's going to cost and when i have to register and where
    146.6db @ 41 hz
  8. #23
    dfw bass's Avatar
    Jan 2007
    fort worth tx
    275
    Re: dfw bass comp
    registration is the day of the event from 12pm to 5pm the registry stops at 3:30 registration is 20 dollars
  9. #24
    tsupra98's Avatar
    Aug 2008
    waco, tx
    743
    Re: dfw bass comp
    does the comp usually get over on time? or how long do they usually last here. cuz i know in utah they lasted all day long pretty much and never seemed to run all that smooth......at least the few i made it to
    146.6db @ 41 hz
  10. #25
    dfw bass's Avatar
    Jan 2007
    fort worth tx
    275
    Re: dfw bass comp
    most of time yea they end on time it depends on the turn out
  11. #26
    tsupra98's Avatar
    Aug 2008
    waco, tx
    743
    Re: dfw bass comp
    alright sounds good i'll be there for sure then.
    so do you have to run with your car off or can you keep it running? and where is the mic located at when metering?
    146.6db @ 41 hz
  12. #27
    dfw bass's Avatar
    Jan 2007
    fort worth tx
    275
    Re: dfw bass comp
    for more info goto www.texasbasswars.freeforums.org
  13. #28
    tsupra98's Avatar
    Aug 2008
    waco, tx
    743
    Re: dfw bass comp
    sorry man reading>me. just one more questions in the am 601+ class do you need your own cd's or is one provided for you to use?
    146.6db @ 41 hz
  14. #29
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    27
    21,072
    97 Post(s)
    Re: dfw bass comp
    One is provided.
    1,000+ designs since March 2011...
    I have my PM's turned off, please email at Ryan@RAM-Designs.com
  15. #30
    tsupra98's Avatar
    Aug 2008
    waco, tx
    743
    Re: dfw bass comp
    Quote Originally Posted by RyanM923 View Post
    One is provided.
    sweet thanks
    146.6db @ 41 hz
