you make that 150million yet Jntar? You coming the 12th?
mmmhmm
"humility in the face of overwhelming genius will obviously amount to hypocrisy"
wrong topic ftl
99 G cherokee
headunit: deh-p720 premeir
Midbass: Diamond Hex 6.5
Tweeter: LPG NFa
Front stage amp: eclipse xa4000
Woofage: eD 16kv.2 3.5 @ 30hz
Sub amp: Eclipse xa1000
87 Nissan Hardbody
HU: Deh-p 3000ib
Comps: eD 6500
Front stage amp: pg 4.0:2
Woofage: 2 9kv.2s sealed
Sub amp: PG 4.0:2
So Im excited for the build day. My front right door needs new deadening, ensolite, rewire, so I figured I would do that and my other 3 speakers along with new headunit install all in one day...
References & Feedback
08STI
I have 2 new amps to install, and maybe a new box if I can get a table saw
2009 Pontiac G8 GT, New Era Intake, Doug Thorley Exhaust, Patrick G Tune
Building: Hybrid Imagine 6.5 front, Image Dynamics CTX 5.25 rear doors. Peerless SLS 8's rear deck off of Kicker ZXSum8 and ZX 700.5
2007 Toyota 4Runner
Eclipse XA100 sub amp and Incriminator 187 10 in 1.6 cubes
Working on Double Din, nice 6.5 Seperates and 6.5 coaxs rear
Refs: Pike110,Hintzyboy,dcmcki, qcsfinest704, MagickMan, allstar1500bd, ravemeister, Team PSI, Jntar, Brian Owens, and others....so many
Ill have an MT and Brahma MKII to recone. We can wall the Brahma if you want before the recone
Also will be doing some deadening of the B-pillar.
I wish i could drive down there for this.....![]()
Team High Desert Mobile Electronics ABQ, NM
Eric im going to text you...
I need to rerun my speaker wire, install 9887, redeaden the front right door, deaden the trunk. Rebuild my false floor. Rewire my amps and batterys and install a DLS A5, and see if i like comps + 1 sub over comps+coaxial+2subs.
I need help installing a viper5900+glass break...
08STI
Ineed you to rerun my speaker wire, install 9887, redeaden the front right door, deaden the trunk, rebuild my false floor, rewire my amps and batterys and install a DLS A5 all while I sit and crack jokes about underage teens and young mothers. Also when you get done I am sure I will change my mind before I give it a listen so you will need to then hook up my comps, coaxials, and two subs.
Also I need you to install a viper5900 and glass break while I hit on your sister.
Lawl
Ok back to work now.
Bookmarks
