Results 1 to 2 of 2
Reload Thread: issues with Viper 791XV install, help!
    Jasper's Avatar
    Jasper is offline CDT *****
    Jan 2005
    Boston, MA
    32
    73
    was installed today. this is the 3rd alarm i've installed, but the first where i've had to get rid of the factory alarm. local shop i talked to said just take the old brain and disconnect it (since i'm running all new wiring)...well...long story short
    alarm works fine...havent tested the shock sensor, but its LED is blinking, so i know its at least active
    parking lights are wired to flash when system is armed/disarmed...only brake lights flash (and yes, im sure i've tapped into the right circuit...the brake light wires are seperate from the parking/running lights)
    hoodpin / trunk merc. switch and all door pins work as they're supposed to
    remote start doesnt work at all.
    ive checked all fuses...satellite relay is wired properly, everything that needs a 12v constant has one (although i may run another one off the battery, because im beginning to wonder if thats where i'm having my issues?)
    one odd thing i noticed about my car, i have 2 ignition wires (was expecting that)...and 2 starter wires. this threw me off. i tested both with my DMM, and both have 0volts @ off, accessory, and RUN...one has 12v @ start, and one hit ~8-9volts (car had already started at that point, i couldnt keep cranking it over). the Viper harness had 2 seperate wires for 2 ignition wires, but only one starter wire (and a starter kill, but thats for an optional StarterKill addon)
    this is a list of what each particular wire does in my car
    http://www.jmteam.net/metalhead/new%...a%20wiring.txt
    and this is the install guide for the 791XV
    http://www.directechs.com/guides/man...564V_01-05.pdf
    anyone know whats going on here? (please, don't post unless you know what you're talking about. i want to find out why my remote start isnt working, not contribute to someones postcount)
    Slody4Futbol's Avatar
    Slody4Futbol is offline CarAudio.com Elite
    Jan 2004
    Jackson, MS
    33
    1,207
    Re: issues with Viper 791XV install, help!
    you need 2 use arelay to activate the 2nd starter wire... use your 2nd starter output... it's on your remote start relay pack... and run it to a relay to activate the 2nd starter
    Been out of this for a longgg time...
  1. Replies: 100
    Last Post: 01-24-2006, 07:53 PM
  2. viper 791xv
    By newb in forum Car Video, Security and Electronics
    Last Post: 12-27-2004, 09:11 AM
  3. Tweeter Install for best imagine help!
    By shtoops in forum Wiring, Electrical and Installation Help
    Last Post: 10-08-2004, 03:57 PM
  4. install prices
    By gummi217 in forum General Discussion
    Last Post: 06-28-2002, 01:32 PM
