Results 1 to 2 of 2
Reload Thread: Video Setup Recommendations
    ma_teg's Avatar
    ma_teg is offline Junior Member
    Dec 2004
    Boston, MA
    Whats going on guys?
    I recently did over my audio setup in my integra and now that its winter, the car will most likely be in storage, I can decide what I want to do for a video setup. The good thing is that my headunit broke (an older signal only alpine which i swore by) so I am open to different methods of running the video setup. Basically I'm not too knowledgable about the video stuff.
    I know that I could get a semi-expensive flip-up screen with an integrated dvd/mp3/cd player, but if i just get that, im going to be spending at least 650, and i would have to make sure that it would be able to play dvd formats right off the bat, because i wouldnt want to have to add another reciever to that setup.
    I know i could also go with a standard audio only deck that could read mp3s then buy a small dvd player, put it in the glove box, and throw a eBay special 7" screen above the mp3 reciever.
    The problem is i dont know what the most effective, easiest to use, least problematic setup would be. Would the single flip-up screen be the best idea? I need your guys expierienced input. I have an external amplifier for the car's components so an internal amp is not neccessary.
    I am looking to spend about 500-700 dollars on whatever I buy, which must include some sort of DIN unit, becuase as I said my older alpine finally **** the cradle.
    I know that I want the best possible quality of sound when the DVD is playing, I dont want to have a great audio setup, but when i turn on the DVD, i still want it to sound just as good as my audio only setup.
    Current Setup:
    4 Alpine Type-S 6.5" 2-Way Speakers
    Alpine MRP-350 4 Channel Amp 4x75 max
    2 Alpine Type-S 12" Subs
    Kicker ZR360.2 Amp
    4 gauge power wire to a Lightinng Audio distro block to two 8 gauge wires
    what are your guys reccomendations, ideas?
    Sleeklsc's Avatar
    Sleeklsc is offline CarAudio.com Veteran
    Jan 2004
    il
    6,938
    856 Post(s)
    Re: Video Setup Recommendations
    well if you want simplicity i'd get the all in one..
    i myself am planning a video install this winter..im building a custom center counsel to house my eq, h/u, 1/2 din dvd player, and misc stuff...im mounting my m+d 7" in the center of the dash were the factory radio was..its at perfect eye level and just fitts in...
    it would prob all equallout either way you do it
    all in one $650ish
    seperate:
    cd player:225
    dvd:150
    screen:200-225
    up to you..of course the above can be had cheaper but that is generally were the mid line is
    Ref's:1. Midwestcustoms 1.5. Desertheat 2. Mjbailey 3. Terryracing86 4. Sickmint79 5. Untouchable11 6. mattj 7. Ssweet96 8. Kool9accord 9.Kristinspapi10. Kmhogan224 11. Alpine3612 -x3- 12. Vectork39 13. Livinlife 14.Chriscivic 15. Violentraptor 16. Ricky616 17. Bassaddictj 18.orioles26 19.Khail19 20. jak3th3snak311 21. Myjaja 22. Springy101 x2 23. Ali1 24. Privatepastry 25. Plus about 10+ more..
  1. Need help with midrange..new setup...Adire Kodas
    By coach87 in forum General Discussion
    Last Post: 11-16-2004, 04:20 PM
  2. setup to replace mag
    By littlebuddy34 in forum Subwoofers
    Last Post: 10-22-2004, 12:50 PM
  3. Opinions on first setup
    By lmnop in forum Subwoofers
    Last Post: 10-21-2004, 04:25 PM
  4. Need help designing video setup
    By XSovereignty in forum Car Video, Security and Electronics
    Last Post: 10-15-2004, 10:10 PM
  5. New Setup of Sorts
    By Shyne151 in forum Enclosure Design & Construction Help
    Last Post: 09-29-2004, 09:42 PM
