Results 1 to 2 of 2
Reload Thread: Starter killing battery.. help please
    mickyd32's Avatar
    mickyd32 is offline Member
    Mar 2004
    Canada
    53
    Ok this is for you guys that install car alarms/starters. I have a compustar alarm start combo. A little while ago I had a problem with the wiring in the siren and I took it back to the place that installed it to get it fixed. Since its summer time I havn't had to use the starter portion of the kit. Last week it was F'n cold here and I decided to try starting my car to let it warm up. I assumed it would start, and when I went to leave, it wasn't started and my battery was dead. I thought it was a battery problem. So I boosted my car. When I went to leave university that same day, I again went to start my car in advance to warm it up, got there and the same problem, a dead battery. I thought there was a problem in my battery grounding or somehwere in my big 3, so I went and purchased some cable to redo that problem this comming weekend. I hadn't used me car starter this week since its been beautiful, but this morning I hit the start button instead of the unlock button in my half dazed sleep. Wouldn't you know it, as soon as I hit that, everything went dead. All I have to di to fix the problem is ground my battery to my frame with my booster cables and life comes back to my battery. This is why I thought it was a ground problem in my car wiring itself. But I tested just hitting the start button after bringing my battery back to life and again it went dead. Would I be correct in assuming they f'd somewhere when they fixed my siren and there is a short somewhere in the start function of the unit now? Everything works fine as long as I don't use the command start
    thanks
    ---'95 Grand Prix GTP--
    -Kenwood KDC 522MP (should be better)
    -Alpine MRDM 500 mono amp
    -Sony 754HX 4 chanell speaker amp
    -Alpine 174A SPR 6.5" comps (fronts)
    -Alpine SPS 690 6x9" rears (rears)
    -Boss audio Eq (forget the number)
    -Phoenix Gold 1.0 fard power cap
    -dual 12" type R's in a sealed box
    -4 guage wiring
    -custom fiberglassed door panels to fit the oversized door speakers (its like fun with playdough, but for big kids)
    Compustar 2 way alarm/starter
    -=Danny=-
    Einzee's Avatar
    Einzee is offline Service Professional
    Aug 2004
    Norwalk, CA
    44
    344
    4 Post(s)
    Re: Starter killing battery.. help please
    You're right about being one for the installers. As a retired installer I will assume that you have checked and rechecked the obvious. I've got two scenerios for ya. First, when you had this siren problem. Is it possible that your defective siren may have shorted something inside the alarm? Second (this is more likely the culprit) Since you have discovered that you can "Bring the car back to life" I would recon that you should check the ground wherever the "Box" is located. I have done numerous installs w/ starter alarms (mostly Autopage) and there are three to five grounds, depending on what options were installed, coming from the alarm. While you are down there check all other connections as well. Grab wires and move them around a little to see is there might be a bad connection somewhere. After you have done that and you still can't find the problem, you may want to prepare to invest in another alarm.
    Stupid questions make more sense than stupid mistakes!
    It is best to remain silent and be thought of as stupid, rather than opening your mouth and removing all possible doubt!
    Quote Originally Posted by Twistid View Post
    Try taking the positive wire from your battery and run it to the engine block, see if that should fix things...
    Quote Originally Posted by PaulD View Post
    THE FUSE AT OR NEAR THE AMP PROTECTS THE AMP. WIRES DO NOT NEED "PROTECTING" WITH A FUSE SINCE THEY ARE NOT POWER PRODUCING DEVICES.
    Quote Originally Posted by shake this View Post
    Which one sounds better (short small diameter or long large diameter)?
  1. remote starter wiring question
    By rippinitup7 in forum Car Video, Security and Electronics
    Last Post: 09-26-2004, 02:28 AM
  2. two batteries?
    By buster in forum General Discussion
    Last Post: 01-26-2003, 01:46 AM
  3. Help solve the Mystery of the Dying Battery!
    By Diabolic in forum Wiring, Electrical and Installation Help
    Last Post: 01-16-2003, 05:24 AM
  4. killing my battery
    By 1bigchevy in forum Amplifiers
    Last Post: 05-18-2002, 10:47 AM
