Results 1 to 3 of 3
Reload Thread: Compustar Install Help
    MB07's Avatar
    MB07 is offline Junior Member
    Aug 2004
    Toronto, ON
    The second relay (not the starter kill one) the one with a blue and purple wire dangling off it which is supposed to be meant for a 2nd ignition I'm assuming so when you remote start the heater etc will come on too. But they dont say how to wire up that one relay. Where does the blue go and where does the purple go? Any help is appreciated
    DJ Riggz's Avatar
    DJ Riggz is offline don't ride no white horse
    Aug 2004
    Roswell, GA
    123
    Re: Compustar Install Help
    i dont think there would be a second ignition just for the heater. there might be a lead for the heater/air. but an ignition lead will just start the engine
    2004 Ford F-250 Super Duty Crew Cab 6.0L Diesel
    HU & Nav: Pioneer AVIC-D3
    Sirius: Pioneer SIR-PN2
    Front: eD 6000s
    Rear: eD 6000s
    Sub: (2) eD 11Kv.3 (Sealed .55cuFt ea.)
    Amp: eD NINe.5
    Rear Cam: Kenwood CCD-2000
    Power Cable: 1/0 KnuKonceptz Kolossus
    immaculateaudio's Avatar
    immaculateaudio is offline the fiberglass-master
    Aug 2004
    Plainfield, NJ
    39
    14
    That wire is not needed unless your car needs to have a second true ignition wire energized to start the car... If your car doesnt have a second ignition wire (shows 12V in on and crank key positions), you dont need to wire up that relay... The accessory wire is the wire that controls your climate control...there way also be two of these wires in your car... Call Firstech to find out for sure how to wire up this particular relay!
  1. install cost
    By Sleeklsc in forum General Discussion
    Last Post: 08-20-2004, 10:04 PM
  2. Bad professional install advice (long)
    By Drowner in forum General Discussion
    Last Post: 07-26-2004, 06:24 PM
  3. where should i install video
    By munky223 in forum Car Video, Security and Electronics
    Last Post: 04-11-2004, 01:29 PM
  4. everyone says "if it's a good install, anything will wang hard" but my question is...
    By wickedmax in forum Enclosure Design & Construction Help
    Last Post: 02-14-2004, 11:15 AM
  5. Replies: 5
    Last Post: 01-04-2004, 05:29 PM
