+ Reply to Thread
Results 1 to 6 of 6
Reload Thread: Viper 5706V Remote Start - No Crank Issue
    keep_hope_alive's Avatar
    keep_hope_alive is offline Acoustics Engineer keep_hope_alive is a Supporting Member of the forum!
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    I am sharing my recent experience with my Viper 5706V in my 2014 Honda Accord Sport (not PTS). I haven't seen much documentation on my issues.
    The initial installation was in 2014. The installation has been reliable, all points were soldered.
    When my car was stolen (and then returned damaged) in spring 2016 and i did a firmware update of the immobilizer bypass which also required a revision to bypass wiring points (the firmware update revised how wires were used).
    In the last month the remote start stopped cranking the engine. Pit stop mode still works (pressing remote start key while engine was running and then removing the key). There are no errors when remote starting - the car turns on and behaves as normal, just no attempt to turn the engine over.
    My local dealer suggested changing the tach mode from virtual tach to tach, and said they experience that with 2013-2014 models. I tried that and to no avail.
    I then found a random thread in which the OP diagnosed the lack of crank signal to a transistor on the board.
    https://www.tacomaworld.com/threads/...-wires.406143/
    It appears the circuitry uses an NPN transistor to pull the relay coil to ground - this is a pretty standard way to isolate the relay coil from the rest of the circuit (something I do frequently in my circuits). This transistor can fail due to frequent use and relay coil current. Once it warms up enough (-15 deg F now) I will pull the brain and swap the transistor to verify.
    For now, I have to start the car manually, then i can use pit stop mode to remove the keys and alarm the car and let it warm up.
    got a question? shoot me a PM. Matthew 6:9-15 - YouTube Channel: https://www.youtube.com/channel/UCkYUo2EShW9lgtrfXiDvLNQ/videos
    2014 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/608637-2014-accord-sport-sq-build-keep_hope_alive.html
    2001 Accord build log: http://www.caraudio.com/forums/car-audio-build-logs-cars-trucks-suvs/536049-2001-accord-ex-sedan-its-long.html
    My 1966 MGB: http://www.mgexp.com/journal/keephopealive
    Fix Photobucket Image Loading ------> https://addons.mozilla.org/en-US/firefox/addon/photobucket-fix/ <------
    tymoto21's Avatar
    tymoto21 is online now CarAudio.com Elite
    Apr 2008
    wisconsin
    927
    1 Post(s)
    258 Post(s)
    Re: Viper 5706V Remote Start - No Crank Issue
    Just an idea since it's been a while but
    Is there a little key light on the dash when you try remote starting?
    On some cars you only need the bypass module for starting the car
    Once it's running you can take the key out
    hispls's Avatar
    hispls is online now CarAudio.com Veteran
    Sep 2009
    Cape Cod, Massachusetts
    9,953
    15
    36 Post(s)
    4040 Post(s)
    I've only ever used Prestige alarm/remote start. Always had good luck with them and they're priced right.
    Anyway, mine have always given some sort of feedback if something isn't right (light flashing code) so for example if it isn't reading the tach right it'll flash a code so you know that's what's happening.
    Sounds to me like a dead transistor is as likely a culprit as anything given all the information you posted.
    tymoto21's Avatar
    Apr 2008
    wisconsin
    927
    1 Post(s)
    258 Post(s)
    what bypass do you have?
    Some send the tach signal through a data line and then all you would need to do it reprogram for tach and not virtual tach
    Although with no tach signal it will still crank the engine it just won't stop cranking until it times out.
    I've seen it where those bypasses loose their program but usually one reprogram and the problem goes away
    fixinit's Avatar
    fixinit is offline Member
    Sep 2016
    Phoenix, AZ
    99
    55 Post(s)
    Are your interior lights still functional after your reboot. I'm new at this.
    JVC KD-R330
    Memphis PR 6.5"
    JBL GTO938 6x9"
    Dual SBPA8
    KnuKonceptz Kolossus 4ga
    20dB
    May 2007
    Quad Cities, IL
    7,082
    28
    48 Post(s)
    1502 Post(s)
    Quote Originally Posted by fixinit View Post
    Yes, my interior lights were unaffected and work as before.
    Quote Originally Posted by tymoto21 View Post
    The bypass I have is the XpressKit DBALL2. It has D2D communication with the Viper (both DEI).
    Quote Originally Posted by hispls View Post
    Agreed, in the past it has given feedback when it didn't start, because it had an error preventing the signal.
    Note this worked fine for 4 years. Either a program loss in the DBALL2 or a failure inside the unit is likely. I verified with my DMM that the unit wasn't outputting 12V on the crank wire. The lack of 12V output tells me either i have a loss of voltage into the unit or a failure to close the relay contact. I verified all fuses are fine and voltage is present (measured voltage on both sides of the fuse).
+ Reply to Thread
  1. Top of the Line Alarm: Viper 791XV Remote Start
    By xknowone in forum Miscellaneous Classifieds
    Last Post: 05-03-2007, 09:24 AM
  2. Viper 791xv (remote start) question
    By RobH415 in forum Car Video, Security and Electronics
    Last Post: 03-15-2004, 08:49 PM
