Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 38
Reload Thread: How hard is it to install a car alarm?
  1. #16
    GaryWA's Avatar
    GaryWA is offline Noobie
    Jan 2012
    Washington State
    109
    Re: How hard is it to install a car alarm?
    Quote Originally Posted by bubbagumper6 View Post
    The12Volt.com will help you greatly...
    Yup, already got the wiring colors. Just gotta learn how to make a relay to pop the trunk and take the plunge haha.
  2. #17
    bubbagumper6's Avatar
    bubbagumper6 is online now CarAudio.com Veteran
    Apr 2006
    The D
    14,057
    10 Post(s)
    Quote Originally Posted by GaryWA View Post
    That website has far more than just vehicle wiring diagrams. For example it has a few dozen relay wiring diagrams...
  3. #18
    daboyfrumdabx's Avatar
    daboyfrumdabx is offline CarAudio.com Elite
    Dec 2009
    Pleasant Mt., PA
    23
    1,204
    Quote Originally Posted by mendon99 View Post
    You don't necessarily need to solder. You can use t-taps if used PROPERLY, this includes stress relief on harnesses so they never get pulled off, and recognizing when a wire is too thick to use a T-Tap (in this case you could cut some of the shielding off but again, experience helps)
    You could probably do this car without the trunk or, add a relay later. the door lock wires are in either kick. Let me know if you need a schem if you're going to try it anyways, give me your email and its yours
    West Palm Beach? I used to live there. Miss it greatly.
    This. If you can do head light relays, these are the same thing. Between the12volt.com and bcae1.com, if you can't figure it out, you need to stay away lol. Do you have a DMM? With a basic understanding on 12V electronics and knowledge of how to use your tools properly you should have no issues. Perhaps I've used them wrong, but I'm not a fan of t-taps. I much prefer solder. T-taps, in my instances, rarely worked out as planned. They either didn't go all the way through the insulation (thin insulation) or cut completely through the wire, which I try to avoid. Perhaps I just had low quality taps that didn't worked as designed, but solder is basically full-proof for me.
    *Sundown Z15 *SAX-1200D *CDT HD-61A *SAX-100.4 *Pioneer DEH-80PRS *KnuKonceptz *XS Power D3400 *270A Mechman
    Sold to: blackbonnie, TheOneJordan, resko1, kr15, Zichardruniga, IBmikexxx, plugitin
    Bought from: Gruszka530, theMessenjah44, ltr450racer690, Dpc69ss, 97maxima(Here and ROE), Pillow(CACO), pro-rabbit, woofercooker, Twisted_0912
  4. #19
    mendon99's Avatar
    mendon99 is offline CarAudio.com Elite
    Jun 2006
    WPB, FL
    929
    Quote Originally Posted by daboyfrumdabx View Post
    You had to have used them wrong or more than likely, used the wrong tool to apply them. I've installed (with no exaggeration) thousands of remote starters and alarms, all with T taps, with a less than 5% come back (if I had to guess) due to a T tap issue.
    SOFL: PM me for Auto Alarm/Remote start installs
    refs: matmcss, nismos14, 6spdcoupe, kpr10is, Pyro by Nature, IONsql, 93 saturn sl2, sporty_drew, MadTheVillain, R-sosa, BiZkiT8u, Benilson09, bamavoo, XsabesX, ldyzlvudis06
  5. #20
    Sleeklsc's Avatar
    Sleeklsc is offline CarAudio.com Veteran
    Jan 2004
    IL
    6,750
    17 Post(s)
    There's 2 things I leave to the pro's, it's alarm's and tint.
    Ref's:1. Midwestcustoms 1.5. Desertheat 2. Mjbailey 3. Terryracing86 4. Sickmint79 5. Untouchable11 6. mattj 7. Ssweet96 8. Kool9accord 9.Kristinspapi10. Kmhogan224 11. Alpine3612 -x3- 12. Vectork39 13. Livinlife 14.Chriscivic 15. Violentraptor 16. Ricky616 17. Bassaddictj 18.orioles26 19.Khail19 20. jak3th3snak311 21. Myjaja 22. Springy101 x2 23. Ali1 24. Privatepastry 25. Plus about 10+ more..
  6. #21
    Dec 2009
    Pleasant Mt., PA
    23
    1,204
    Very possible. I only tried using them twice and with those poor results I moved on to solder and never looked back. If your results have been that good, I'm sure if I had tried them a few more times my results would have improved. I can't say I've installed thousands, or even close to a 100, but of all cars I've done with solder, 0% have come back do to anything wiring related (other than a loose hood pin)
    Quote Originally Posted by sbcaprice305 View Post
    Eh. While my tint was done professionally because I **** at anything with compound curves. Tinting, or trying to tint probably isn't going to damage a vehicle. May damage a vehicles appearance but won't compromise it's integrity. Worst case is ugly car or lots of lost wasted money. Remote start/alarm...I definitely say leave it to the pros or at least someone with some level of experience (I certainly don't consider myself a pro). My first RS/alarm project turned into a 3 days project and I'm lucky I didn't damage my electrical system. I didn't touch one for about a year after that. Just conversed with other installers and picked their minds and by the time I tried a new one, I was well prepared.
  7. #22
    mendon99's Avatar
    Jun 2006
    WPB, FL
    929
    daboy,
    Im sure if you were properly taught, you wouldve found that they're fine...working in a busy shop, its unfortunate that speed is looked at equally as important as quality install (they're in biz to make money obviously), and it doesnt get faster than taps. poke and wrap with solder is def the best 0 risk option though, you're right.
  8. #23
    Dec 2009
    Pleasant Mt., PA
    23
    1,204
    daboy,
    I think that is the key word.
  9. #24
    GaryWA's Avatar
    Jan 2012
    Washington State
    109
    About to order the Viper 3303, glass break sensor, and backup siren/battery. What do you guys think?
  10. #25
    disturbed471985's Avatar
    disturbed471985 is offline CarAudio.com Veteran
    Jun 2009
    Greenwood, La
    28
    6,645
    11 Post(s)
    I want even attempt to install an alarm like many have said way to much that can and will go wrong..
    RIP Christopher Maynard Martin "My heart"
    HU - Eclipse CD7000 For Sale
    Front Stage - 4 Silver flute 6.5's & 4 Seas Prestige tweets Sold
    Front Stage amp - DB Drive A7 125.4 For Sale
    Subwoofer - 3 Skar VVX 10's (Looking for 4th so I can run amp at .5ohm) Sold
    Subwoofer Amp - Skar SK-2500@.67ohm For Sale
    Box - 4.25cf tuned to 30hz using a 6" internal aero 15" long.. For Sale
    Wiring - Knukonceptz everything, Big 3, Sprinter S12V370F & HC1800 Sold
  11. #26
    GaryWA's Avatar
    Jan 2012
    Washington State
    109
    I can't afford an alarm and an install haha.
  12. #27
    Jun 2009
    Greenwood, La
    28
    6,645
    11 Post(s)
    ^^^ can u afford a repair bill if you mess something up??
  13. #28
    Bettr n' Revrse's Avatar
    Bettr n' Revrse is offline I do what I want
    Dec 2010
    Grand Junction, CO
    16,860
    72 Post(s)
    Western Rep.
    99 Honda CRV: (Always Changing) ___________ 79 F-150: Show Truck ________________
    -Head Unit: Eclipse CD7100________________ -Head Unit: Eclipse CD7100
    -Sub Stage: Sundown SD-2 8's sealed________ -Sub Stage: Looking
    -Mids/Highs: Deciding_____________________ -Mids/Highs: Scan Speak & Blaupunkt
    -Sub Amp: MMATS Hifi 6 channel____________ -Sub Amp: American Warrior Set (Zed Built)
    -Mid Amp: ^^^ 5/6 bridged at 1 ohm_________ -Mid Amp: ^^^
  14. #29
    GaryWA's Avatar
    Jan 2012
    Washington State
    109
    Guess I know what I'm doing with my next paycheck I guess..
  15. #30
    Louisiana_CRX's Avatar
    Louisiana_CRX is offline dem shoes...... Louisiana_CRX is a Supporting Member of the forum!
    Aug 2006
    Piney Hills of Louisiana
    34,141
    31 Post(s)
    Hooking up a car alarm is just about as simple as installing a car stereo...you can get a wiring diagram on this site below....
    Remote Car Starter & Keyless Entry Systems
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
  1. how hard is it to install an alarm?
    By zthumper in forum Car Video, Security and Electronics
    Last Post: 08-04-2006, 10:43 PM
  2. How hard is it to install a viper 791XV
    By trigger2008 in forum Car Video, Security and Electronics
    Last Post: 02-03-2006, 11:32 PM
  3. How hard is it to install HU?
    By digital mint in forum Wiring, Electrical and Installation Help
    Last Post: 01-26-2006, 03:41 PM
  4. How Hard Is It To Install 5.25 Components?
    By shanerz21 in forum General Discussion
    Last Post: 12-31-2005, 02:51 PM
  5. How hard is it to install a white face guage kit?
    By Kaos in forum Car Interior/Exterior Enhancements
    Last Post: 10-16-2005, 09:17 AM
