Page 1 of 2 1 2 LastLast
Results 1 to 15 of 27
Reload Thread: Viper 5901 Remote Star in 05 Ford Focus
    jcbunker's Avatar
    jcbunker is offline Junior Member
    Apr 2009
    Milwaukee, WI
    14
    I was hoping maybe someone on here that installs remote starts/alarms could help me out with an issue.
    I am planning on having the new Viper 5901 with remote start installed in a 2005 Ford Focus ZX3 manual trans. at a local shop in the next couple of weeks.
    The lady (who is the owner of Car-feteria in Milwaukee)was looking over Directed's technicians wiring and info website at the specific of my car (2005 ZX3 Manual). It said that the Focus had 30 amps coming into the car. She said that 30 amps is probably not enough for the remote start so they would have to go to the battery for power. Something like it takes more than 30 amp to start the car. Now I have heard this on 2 separate quotes from 2 different places. Is this true that a 10 guage power needs to be run from the battery? I can't seem to get a clear answering or find anything in any searches I do.
    Also do these prices seem fair?
    Viper 5901 installed $500.00
    XK04 Bypass $60.00
    Manual Trans. Programming $75.00
    If need to run new power $50.00
    I would run the new power just to save money because I can easily do that, but am not sure if its needed and thought I would ask someone who might have experience with this before.
    Thanks in advance,
    mcsoul's Avatar
    mcsoul is offline such is life
    Mar 2008
    dfw
    4,430
    Re: Viper 5901 Remote Star in 05 Ford Focus
    It's a little high, but if they are a really good shop it may be worth it.
    ________________________
    Car: 2004 Nissan Altima 3.5 manual
    Head unit: Alpine CDA-9815 (running active)
    Midbass: Morel HU-621 Hybrid Uniflow 8 ohms
    Mid Amp: Audison lrx 4.300 bridged 2x140w @ 8 ohms
    Doors: 24ft Damplifier Pro, Second Skin D-flex pads, eggcrate foam, sealed up.
    Tweeter: SEAS 27TFFNC
    High Amp: Audison Lrx-2.150
    Subs: Two RE SE 12 d4's
    Box: 4 cubes net at 30hz
    Sub Amp: Sound Stream Van Gough 1600.2
    Electrical: Knu Flex 1/0, Batcap 2000 in back
    Rear Deck: No 6x9's just holes and grills
    Cudda_Kine's Avatar
    Cudda_Kine is offline Member
    May 2009
    Hawaii
    87
    That's how much our audio shop charges for the alarm installed. Seems Ok.
    Fiercetimbo17's Avatar
    Fiercetimbo17 is offline CarAudio.com Veteran
    Jan 2007
    dallas
    2,345
    The manual programming will only take them 5 seconds, tell them take that off and its a good deal.
    Pioneer Avic-z3
    4-way Active
    CDT ES-01
    CDT ES-04
    Dls IR8
    Zapco dc650.6
    12" idmax IB
    zapco dc 1100.1
    tsunami wiring
    200 sq ft edead/damp
    4 gallons spectrum/sludge 160 ft overkill
    132.6 db at 22 hz...
    mcsoul's Avatar
    Mar 2008
    dfw
    4,430
    10g for over 30a sounds about right. Your better off letting them do everything.
    Well done remote start installs are not cheap (manual makes it worse iirc).
    jcbunker's Avatar
    Apr 2009
    Milwaukee, WI
    14
    I would let them do everything except installed the wiring from the battery to the inside of the car if new power would need to be ran. So 30 amps coming into the car from the factory is not enough for the remote start?
    Worlddre's Avatar
    Worlddre is offline Big Darkie
    Sep 2004
    Charlotte, NC
    28
    17,899
    if the key can start the car with 30 amps of current so can a remote start thats asinine if you have 30a at the key cylinder and the key doesnt need more current then why would a RS not too mention that is more then enough to take care of security features as well they may actually believe they are doing the right thing in which case they are wrong or they may just be trying to upsell you in which case they are d-bags not to mention that is the worst shop name ive ever heard of
    "humility in the face of overwhelming genius will obviously amount to hypocrisy"
    jcbunker's Avatar
    Apr 2009
    Milwaukee, WI
    14
    Quote Originally Posted by Worlddre View Post
    Yea I'm new to the whole security system thing so I thought I would get a second opinion from people more knowledgeable than myself. I have heard the possibility for needing the new power from 2 different shops thats why I was unsure.
    As far as the name it is a little cheesy, but they have been around for 42 years down here, and have heard they have a good reputation. Their expertise is installing Viper systems, so hopefully it works out.
    JVC AVX 800 DVD headunit
    Phoenix Gold RSD6.5cs components
    Eclipse Amps
    2 10" older JL Subs
    http://www.cardomain.com/ride/3328711
  9. #9
    Proximity's Avatar
    Proximity is offline CarAudio.com Veteran
    Apr 2008
    Detroit
    23
    2,274
    1 Post(s)
    $75 for the manual remote start is absolute larceny. The 5901 comes factory programmed for manual remote start, it's the default option and the wiring is no different.
  10. #10
    jcbunker's Avatar
    Apr 2009
    Milwaukee, WI
    14
    Aside from the manual trans. programming, what about the power needing to be run from the battery? Is that reasonable or probable or is it not needed?
    Eclipse Amps
    2 10" older JL Subs
  11. #11
    THUNDERBIRD's Avatar
    THUNDERBIRD is offline CarAudio.com Veteran
    Feb 2005
    LANSING, MI
    2,340
    my shop would charge $350 to install that unit plus, bypass cost. we wont touch a rs on a manual. and tell them to wire that to a 12v in the car. it they use as many negative triggers as they can the unit wont see much draw, i have personally seen a basic keyless wired all negative triggers powered off of a 18gauge 12v source, because they dont draw ****. we did redo it to a heavier gauge that was just to get the point across
    94' thunderbird *parked*<
    4.6 V8 with a shift kit
    clarion dxz 645mp clarion sirius tuner
    ED 6000v.2- front jbl 5.25 comps- rear
    dynamated and edeaded trunk lid, rear deck, front doors
    Big 3 in green of course
    viper 791xv w/ battery backup
    3 jl 10w0
    2000 ford ranger supercab 3.0v6 4x4
    stock hu
    alpine mrp-m350
    2 9kv.3's
    clifford matrix rsx 50.5x
    spring time getting clarion MAX675VDII and front components possibly jbl's again
  12. #12
    Proximity's Avatar
    Apr 2008
    Detroit
    23
    2,274
    1 Post(s)
    Won't be needed.
  13. #13
    jcbunker's Avatar
    Apr 2009
    Milwaukee, WI
    14
    Thanks everyone, I am gonna bring up the issue about the new power when I call them tomorrow. If anything, I'll tell them to hook it up without the wire, but if a new power is necessary after its installed then they can ask me. As far as the $75 for programming, I'm not sure what to ask because they are still cheaper than any of the other shops in town and have been more helpful than any of the others.
    Plus I have a certificate for 10&#37; off my next purchase so I will almost recover most of that $75.
    Thanks again everyone, I really appreciate it!
    Eclipse Amps
    2 10" older JL Subs
  14. #14
    Proximity's Avatar
    Apr 2008
    Detroit
    23
    2,274
    1 Post(s)
    Tell them that there isn't any programming that needs to be done at all. You're paying for nothing.
  15. #15
    Proximity's Avatar
    Apr 2008
    Detroit
    23
    2,274
    1 Post(s)
    If they say otherwise, tell them to show you what they mean. There is NOTHING that needs to be programmed (just one option, but the default is manual mode), and the only thing extra is to make one little splice to the clutch wire. You can do that yourself.
