Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 60 of 60
Reload Thread: Installing Viper 791vx In 99 blazer?
  1. #46
    sparkplug121988's Avatar
    sparkplug121988 is offline SWINE FREE!!!
    Mar 2009
    spokane, wa
    1,235
    Re: Installing Viper 791vx In 99 blazer?
    Im guessing that the 3rd ignition brown was not used. And I found 3 brown wires but they all go to 0volt when in start position. So im not sure which one to use. 2 are like 18guage and 1 is like 12gauge. Also is their a way to reset the alarm unit? I might have messed up on the programing?
    1999 2dr Blazer
    4 Fi BTL 18s
    1 sd8k
    6 g31s
    Quad Alts!!
    155.2 @ 36hz
    Refs- soundwave.co, jermy few others just ask.
  2. #47
    Worlddre's Avatar
    Worlddre is offline Big Darkie
    Sep 2004
    Charlotte, NC
    33
    18,014
    1 Post(s)
    49 Post(s)
    You can reprogram the alarm using the valet switch...second and third ign drop 12v during crank but maintain it during run.
    "humility in the face of overwhelming genius will obviously amount to hypocrisy"
  3. #48
    Mar 2009
    spokane, wa
    1,235
    Ok I reprogramed and installed a relay to the pink wire of ribbon harness. Now how do I know which 3rd ignition wire to tie into? Because all 3 brown wire do the same thing.
    1999 2dr Blazer
    4 Fi BTL 18s
    1 sd8k
    6 g31s
    Quad Alts!!
    155.2 @ 36hz
  4. #49
    Worlddre's Avatar
    Sep 2004
    Charlotte, NC
    33
    18,014
    1 Post(s)
    49 Post(s)
    trace the one that returns to the plug at the key cylinder which is likely the heavy guage wire
  5. #50
    Mar 2009
    spokane, wa
    1,235
    ok now for the relay which way do I conect it? They have 2 87 conection which one do I use. Does it mater?
    Also could I still have the wrong tach wire? It just seems like everything is conected right. The only other wire I'm not sure about is the factory disarm wire. I found that wire at the bcm.
    1999 2dr Blazer
    4 Fi BTL 18s
    1 sd8k
    6 g31s
    Quad Alts!!
    155.2 @ 36hz
  6. #51
    Worlddre's Avatar
    Sep 2004
    Charlotte, NC
    33
    18,014
    1 Post(s)
    49 Post(s)
    Disarm generally tests by turning the key in one of the door cylinders.
    Relay
    85 and 87 - 12v fused
    86 - pink wire on RS ribbon harness
    30 - output to 3rd ign
    Tach could still be the prob unless it doesn't work with voltage sense as well.
  7. #52
    Mar 2009
    spokane, wa
    1,235
    So should I set it to voltage sense? And I will try and see if that does anything.
    1999 2dr Blazer
    4 Fi BTL 18s
    1 sd8k
    6 g31s
    Quad Alts!!
    155.2 @ 36hz
  8. #53
    Worlddre's Avatar
    Sep 2004
    Charlotte, NC
    33
    18,014
    1 Post(s)
    49 Post(s)
    yes attempt the remote start with voltage sense if it does the same thing then tach is not the problem
  9. #54
    Mar 2009
    spokane, wa
    1,235
    if it still does not work could the bypass it self be bad?
    1999 2dr Blazer
    4 Fi BTL 18s
    1 sd8k
    6 g31s
    Quad Alts!!
    155.2 @ 36hz
  10. #55
    Worlddre's Avatar
    Sep 2004
    Charlotte, NC
    33
    18,014
    1 Post(s)
    49 Post(s)
    sounds like an ign prob...we ruled out the bypass by trying to start it with the key in the ignition
  11. #56
    Mar 2009
    spokane, wa
    1,235
    What about the alarm disarm? Could that have anything to do with the problem? Im wondering if I have to have the main ignition split and have the 2nd conected. or does it matter?
    1999 2dr Blazer
    4 Fi BTL 18s
    1 sd8k
    6 g31s
    Quad Alts!!
    155.2 @ 36hz
  12. #57
    Worlddre's Avatar
    Sep 2004
    Charlotte, NC
    33
    18,014
    1 Post(s)
    49 Post(s)
    Disarm is not the problem. You have cnfused me with what you said about the ign wires
    You are overcomplicating the ignition wires. All you have to is trace the heavy guage wires back to the key switch and make sure they are all wired up. If you missed one that is the wire you wire up the 3rd ign relay to. If they are all conected then we will move on to the next potential problem.
  13. #58
    Mar 2009
    spokane, wa
    1,235
    Thanks for all the help. It has been installed and works perfect now!
    1999 2dr Blazer
    4 Fi BTL 18s
    1 sd8k
    6 g31s
    Quad Alts!!
    155.2 @ 36hz
  14. #59
    SentraStyle's Avatar
    SentraStyle is offline Senior VIP Member
    Dec 2002
    Kissimmee, Fl
    497
    1 Post(s)
    31 Post(s)
    So...what was the problem...third ignition?
    Refs:
    Sold To: R-sosa , SRim23, bchandler , feloosa, JHughes, profoundwill, ArrizX, sinclair10, Aztec
    Bought From: the727kid, mattj, 2000Gator, fanninator, zerojeff, Fast1one, grizzly02, KTFO, ribeiro953 , michaellane
    Traded: masone, ReDemoN, nismos14, 919motoring, jdm94coupe
  15. #60
    Mar 2009
    spokane, wa
    1,235
    lol no it wasent third ignition. It was the resistance wire for the by pass. I was told to split ignition 2 and have the yellow going to key side and yellow black to the othe. But after talking to you guys and a few other I figured out that I had to spilt the wire for the passlock on the ignition harness. Once I did that it started right up....... lol im such a dumb ***. Well now I know how to install a alrm on a s10 gonna try a malibu.
    1999 2dr Blazer
    4 Fi BTL 18s
    1 sd8k
    6 g31s
    Quad Alts!!
    155.2 @ 36hz
