Results 1 to 6 of 6
Reload Thread: 5701 help?
    tymoto21's Avatar
    tymoto21 is online now CarAudio.com Elite
    Apr 2008
    wisconsin
    983
    1 Post(s)
    288 Post(s)
    5701 help?
    i just put a 5701 in my car. i didnt hook the door locks up yet because i gota drill a hole to get the door actuator to fit right. (running one master lock)
    i put the starter in and hit r/s.... it sends back a bad signal then the lights flash 7x. i read you have to program it to automatic mode but when i try to do it still same thing. i turn key on then off, hold light till 3rd flash, hold light till first flash then hold light still 2nd flash, then turn ignition on and off to exit. do i got something wrong there? could it be my tach wire?
    2 sa8 spl's in a 31hz tapped horn
    rd d9 run at 2ohm
    stinger spv70 up front
    kicker zx640.4
    alpine type s comp up front
    kicker ks 6x8's in rear
    pioneer avh-3200bt
    buncha 1/0 awg kicker
    SentraStyle's Avatar
    SentraStyle is offline Senior VIP Member
    Dec 2002
    Kissimmee, Fl
    497
    1 Post(s)
    31 Post(s)
    Re: 5701 help?
    Quote Originally Posted by tymoto21 View Post
    It sounds like you might be trying to program it wrong. What you have to do is open the drivers door (your door triggers must be hooked up to program). Then turn the ignition on and then back off as you said you did. Hold down the valet button until you hear your siren chirp 3 times (you are now in menu 3 of the system features learn routine). Now what you have to do is let go of the valet button. Press and release the valet button once and then press and hold. You should now hear your siren chirp once. Now press the unlock button on your remote (you should hear two chirps from your siren). You are now programmed for automatic transmission mode.
    Now for your tach...have you programmed your tach? Turn your car on (engine running) and then press and hold the valet button down. Your LED should turn on solid at this point if you have the correct tach wire. If it turns on, turn your car off and you should be good to go with the remote start if those two things were the only things wrong.
    Refs:
    Sold To: R-sosa , SRim23, bchandler , feloosa, JHughes, profoundwill, ArrizX, sinclair10, Aztec
    Bought From: the727kid, mattj, 2000Gator, fanninator, zerojeff, Fast1one, grizzly02, KTFO, ribeiro953 , michaellane
    Traded: masone, ReDemoN, nismos14, 919motoring, jdm94coupe
    tymoto21's Avatar
    Apr 2008
    wisconsin
    983
    1 Post(s)
    288 Post(s)
    Re: 5701 help?
    kk thanks alot i was programing automatic wrong. i will go try that now.
    rd d9 run at 2ohm
    kicker zx640.4
    pioneer avh-3200bt
    ktide's Avatar
    ktide is offline Junior Member
    Feb 2009
    Alabama
    Re: 5701 help?
    hello did you plug in the safe.net.switch as well as the input wire
    I had the same thing happen to me
    tymoto21's Avatar
    Apr 2008
    wisconsin
    983
    1 Post(s)
    288 Post(s)
    Re: 5701 help?
    that little switch thing for the neutral safety wire? both are in, but maybe the switch is a lil out or something.
    rd d9 run at 2ohm
    kicker zx640.4
    pioneer avh-3200bt
    Worlddre's Avatar
    Worlddre is offline Big Darkie
    Sep 2004
    Charlotte, NC
    34
    18,014
    1 Post(s)
    49 Post(s)
    Re: 5701 help?
    If you are programing without the siren the led has about a 2 second delay such would be why you are missing programming. Hook the siren up and use that for programming.
    "humility in the face of overwhelming genius will obviously amount to hypocrisy"
