Results 1 to 4 of 4
Reload Thread: First time installating car alarm, need help
    kentb's Avatar
    kentb is offline Senior VIP Member
    May 2008
    Las Vegas
    401
    here is the manual on the scytek astra 777 alarm
    and this is the wiring diagram for my 2000 ford explorer
    i already mounted the brain, the siren and the shock sensor.
    also wired them.
    i haven't wired the horn, parking lights and the doors. i need help on this.
    the wiring is kinda confusing.
    for the horn, it says that the wire is negative and must use a relay, how will i wire a relay with a negative wire?
    for the parking lights, do i just choose which wire polarity i will hook up from my car and just set the jumper? how will i know if the parking lights exceeds 10 amps and needs a fuse?
    i'm totally confused on how to wire the doors. don't need the triggers just need the unlock and lock feature.
    i **** at this..
    thanks in advance to anyone that can help!
    Louisiana_CRX's Avatar
    Louisiana_CRX is offline dem shoes...... Louisiana_CRX is a Supporting Member of the forum!
    Aug 2006
    Piney Hills of Louisiana
    34,141
    31 Post(s)
    Re: First time installating car alarm, need help
    Good Luck
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
    s Beatz's Avatar
    s Beatz is offline Banned
    Sep 2008
    Los Angeles, CA
    963
    Lmao i would never recommend installing a alarm on your own unless you have someone that knows how to helping you, those things are a *****! Lol..
    quest51210's Avatar
    quest51210 is offline CarAudio.com Veteran
    Nov 2006
    South Texas
    3,131
    the alarm has a neg output for the horn=no need for a relay to horn, just direct connection
    parking lights will be fine with a direct connection with the Scytek
    why no door triggers? the shock sensor won't be much of a theft deterrent just on its own. hook up door triggers to domelight, i would also add a glass breakage sensor at the minimum.
    as far as doorlocks, well you sir have a pain in the *** vehicle for door locks. this truck has what is the GEM module. the doorlocks in essence "go to sleep" and can cause false triggers all night long.
    you will need to pick up some diodes and a use the bottom diagram.
    the BCM is located to the left of the radio behind the dash.
    refs:bhsdriller-sold, jermaine29-sold, stereohead69-sold, foreman-bought, dconder-bought, SVTRelampago-bought, Mihklo-sold, CRXican-bought, dron178-sold, wes007parks-bought, elementalXB-sold, revrider-sold, IonSQL-bought.
    Under old S/N SATX210: zachzchw-bought, lowlinc-sold, ksin291-sold
    got quite a few good refs on diyma, caco, and ebay under Quest51210
