how accurate are the Audiocontrol epic 150??
Fs/t
Orion 2500d
Orion 4004
250 amp alt w. external voltage reg. for a ford explorer
Refs: Electrodynsmic, Millerboy, Ugaboiii, Ezekiel81923, Toaster, Team Psi, KickerCivic1, MatrxxDude, TommyK90, Xterra02_Pat
any1 know how accurate the epic 150 is?????
Fs/t
Orion 2500d
Orion 4004
acurate up to 150, and the higher you go up, the more inaccurate it gets.
(SUMMER)2001 Ford Mustang GT PremiumMach460Alpine CDA-9835KnuKonceptz Wiring
BingoOriginally posted by mattj
acurate up to 150, and the higher you go up, the more inaccurate it gets.![]()
- Steve
Moderator
2007 Chrysler 300C
2005 Chevrolet Silverado 2500HD Crew Cab
Optima, Volant, Bully Dog, Corsa, Gibson, Powermaster, California Super Trucks, Fox Racing, Airaid
Alpine 7998, Alpine HDA-5460, Arc Audio MEQ-30, (2) Adire Audio Shiva, Image Dynamics CD-2COMP, Image Dynamics CX64, (2) Image Dynamics ID8V.2, Arc Audio 2100CXL, Arc Audio 4150CXL, Arc Audio 1500D-R
2006 Kawasaki Ninja ZX14
Originally Posted by DJGTSR
Ding Ding Ding!Originally posted by ss3079
Bingo![]()
- Steve
they are supposed to be fairly accurate but don't forget that the Mic is in the unit so it is not positioned propper...
but i got that covvered with my mates epic the epic is in the dash and we get the reading from the dash...
relocated the meter to a bracket like on a propper spl mic and there is a plug in the window demister vents on top of that dash...
Alpine 7892 Deck will get converted to am mp3 deck one day
Apline DLC-176A splits
Alpine MRD-M1000 sub amp i want 3 more
Alpine MRV-T320 Split amp
Alpine SWS-1241 woofers X2 they are mums i have better subs in store
144.5 Db's worth on a linear X with mummys subs sealed wait till i port them and unleash the fury
7 Months and 2 jobs later i am back louder smarter and alot poorer so watch yo asses cause i am back
The aussie rice boi Slammed pulsar on 18's and tyres that are as thick as a condom :P
ok, so if i have it mounted on my dashboard, and i hit a 151.. then what is actually? or more close to? ive only been to 2 shows..and the 1st show, they placed the mic on the window.. right above the place i have it now.. and the 2nd time, they put it in the trunk..right next to my speakers..which i know , thats outlawed..
also, i still have my stock alternator, and w/ the epic 150 i can check my voltage.. a few times i dropped in the 11's which my amps cut off then..i just got my 165 amp alt today, so i should be able to put it in.. what i want to know is, can this add more dbs, by suppliing more power? or will it just keep enough power so, my amp dont cut out and headlights flicker and all that good stuff?
Fs/t
Orion 2500d
Orion 4004
yes adding a bigger alt will in most casses add more SPL if you run the engine while you do your SPL run
yes, adding a bigger alternator supplies your amps with the power they draw (or should) and keeps them nice and voltage fed. higher voltage = higher amp putout.
why come when i replaced my stock alt w/ an HO alt.. i actually now have lower volts..
my stock was 70 amp and it stayed at 14.4 most the time.. my HO, ive never seen it past 13.9...so would my stock alt actually be better than my Ho alt?
Fs/t
Orion 2500d
Orion 4004
Bookmarks
