Results 1 to 7 of 7
Reload Thread: Changed only the brain, antenna, remote from viper 560 to 791, what happened?
    ace_800's Avatar
    ace_800 is offline CarAudio.com Veteran
    May 2004
    Okinawa, Japan
    37
    5,418
    4 Post(s)
    500 Post(s)
    As the title states, I changed out the 560 stuff for the 791. For some reason I had to cut the hood pin switch cause it would shut off when I tried to use the remote start. It was not doing this with the 560 and I had no problems with it. I did not touch anything but the brain and antenna. I did not mess with any wires besides plugging them in. What could have happened?
    Current set up: 94 Toyota Chaser (1JZ motor) Kenwood 5907, 3 way active (Alpine DLX-Z30T Tweets, CDT 04's and 06's), Helix P Six DSP/Amp, 4 IDQ12's, MMATS D3000.1
    66 Pontiac GTO, modified stock radio, Crossfire CFA 302, Kicker KS6.2's in the front kicks, Crossfire CFA 452 for the 6x9's I need.
    hardhitta47's Avatar
    hardhitta47 is offline CarAudio.com Elite
    Dec 2006
    Dayton, OH
    658
    Re: Changed only the brain, antenna, remote from viper 560 to 791, what happened?
    Are you sure all of the wiring is supposed to be exactly the same from the 560 to the 791? might wanna email them to make sure
    The hood pin switch for the may need to be normally open for the 791, but normally closed (or grounded) for the 560? idk
    Sold to: wackdogg | confusedsoul | got_focus? | 04|5spdcivic |billabongcr | Zxcvtypo | BigEM | ElBandito
    Bought from: UndercoverPunk | Se7en (diyma) |alphakenny1 |IonSQL |cd6551 | QtrHorse |PowerNaudio | Duece212 | ace_800 | Logikalliquid | 9512ds | altima98 | MiniVanMan
    azbass's Avatar
    azbass is offline the salty ca.com mod
    Sep 2004
    Long Beach, CA
    34,922
    first off never change brains, thinking the wireing will be 100% the same.
    THUNDERBIRD's Avatar
    THUNDERBIRD is offline CarAudio.com Veteran
    Feb 2005
    LANSING, MI
    2,316
    Quote Originally Posted by azbass View Post
    x2 i know you can do that for the 791 to the 5900
    94' thunderbird *parked*<
    4.6 V8 with a shift kit
    clarion dxz 645mp clarion sirius tuner
    ED 6000v.2- front jbl 5.25 comps- rear
    dynamated and edeaded trunk lid, rear deck, front doors
    Big 3 in green of course
    viper 791xv w/ battery backup
    3 jl 10w0
    2000 ford ranger supercab 3.0v6 4x4
    stock hu
    alpine mrp-m350
    2 9kv.3's
    clifford matrix rsx 50.5x
    spring time getting clarion MAX675VDII and front components possibly jbl's again
    atoz350's Avatar
    atoz350 is offline CarAudio.com Elite
    Apr 2006
    Denver, Co.
    1,928
    Have you programmed it yet?
    Current System:| Alpine CVA-1005|Audiocontrol DQXS Active Crossover|Soundstream TRA880.5 5 channel|
    |Scan Speak D2904/6000 tweeters (Alpine Version)|Usher 8137A 8" Kevlar/Carbon Fiber Woofer|1 Alpine Type-E 10"|
    Rebuilding...
    Refs: Sold to:amedeuce
    ace_800's Avatar
    May 2004
    Okinawa, Japan
    37
    5,418
    4 Post(s)
    500 Post(s)
    I have already contacted DEI, they said I can replace the 560 to the 791 or python 881. Just not to the new 5900 or whatever it is. The install guide for the 560 and 791 are exactly the same besides the antenna and remote. Nothing else is different and the wiring is the same.
    Vestax's Avatar
    Vestax is offline Blends No. 27
    Aug 2004
    San Jose, CA
    401
    If the gray wire for the hood pin is grounded on the 791xv or 881xp, then it will inhibit remote start. Leaving it disconnected will do nothing. I would see if that gray wire is being grounded anywhere else. Otherwise, you need to make sure that the neutral safety switch is grounded, the tach or tachless is hooked up, and the brake wire and bypasses are properly wired for remote start to work.
    USUC World Champion - Stock System Class, Super Street Division Special Edition Bose 26 piece speaker system with enhanced ported tweeters. 89.2 db Legal, 89.6 db Outlaw
    Antonio Corleone, Uptown Golden Ear Mafia
