Results 1 to 5 of 5
Reload Thread: remote starter / suzuki swift 1995 (automatic)
    malaiwah's Avatar
    malaiwah is offline Junior Member
    Jan 2003
    Sainte-Foy, Québec
    Icon32 remote starter / suzuki swift 1995 (automatic)
    Hi.
    I just tried to install a remote starter on my girlfriend's car and I have trouble with the tach signal wire. I looked at a diagram and it seems to be the "brown/white wire at the igniter". I found a brown/white wire under the hood, connected to something which looks like the "igniter".. But I also found a brown/white wire under the steering, connecting to something which seems to be the ECU. Can I hook up the wire there instead of running a wire under the hood?
    The car is a Poniac Firefly 1995. It's a variant of SUZUKI SWIFT 2DR 1995 AUTOMATIC because it's written "Suzuki Corporation" under the hood ;-) Can someone tell me which wire to tap into for the tach signal wire?
    The remote starter unit is named ON/Start and she got it for free. The unit was into another car, I don't have any programming instructions with the unit but with trial and errors, I found out that tapping quickly the yellow wire on the ground tells the unit the tach signal.
    Thanks a lot,
    nismboy6986's Avatar
    nismboy6986 is offline the **** technician
    Jul 2002
    Belhaven NC
    665
    does the car have a tach? u could connect it to this wire. it seems u found two wires that u think are the tach wire. u can use a voltmeter and see which one has AC voltage and that should be your tach wire. do u know if the remote starter has a tachless mode. if the car is a '95 it should be new enough for the tachless mode to work on the car.
    malaiwah's Avatar
    Jan 2003
    Sainte-Foy, Québec
    Re: remote starter / suzuki swift 1995 (automatic)
    The car doesn't have a tach in the dash.
    I would like to use the tachless mode of the starter, but having no programming manual, I can't do it by myself and I'm not sure this unit can be tachless.
    ON/START remote car starter. The unit can lock/unlock power doors, remote start vehicule, has a "aux output".. Any1 could tell me how to make it work on this car please??
    DarkHemprey's Avatar
    DarkHemprey is offline Allen Iverson
    Feb 2003
    St.maries
    48
    313
    i wouldnt waste my time on a suzki my opnion
    Aim: DarkHemprey
    E-Mail: [email protected]
    3rd Place District's 2nd place State
    malaiwah's Avatar
    Jan 2003
    Sainte-Foy, Québec
    Re: Re: remote starter / suzuki swift 1995 (automatic)
    conclusion: the brown wire going to the ECU, that I thought was the tach source WAS NOT! ;-) for a suzuki swift 1995, you must really take the brown/white wire at the igniter (located on the firewall).
    it works like a charm now and my girlfriend is really happy of the installation!
