Results 1 to 9 of 9
Reload Thread: Omega alarm install in 03 grand am
    dirtye30's Avatar
    dirtye30 is offline Senior VIP Member
    Aug 2006
    buffalo
    421
    hey im putting a K-9 sombra in an 03 grand am and i was wondering if i could somehow tap into the lock and unlock wires from the MARS remote start. the grand am has only one white wire for the lock and unlock and i dont rememeber the resistance for the unlock. i also dont have a multimeter at the moment. can somone point me in the right direction?
    azbass's Avatar
    azbass is offline the salty ca.com mod
    Sep 2004
    Long Beach, CA
    34,922
    Re: Omega alarm install in 03 grand am
    Lock is straight negative trigger. Unlock is negative trigger thru a 1.5K (1500) ohm resistor. MUST use relays. MUST close doors to lock with a single pulse.
    The BCM (Body Control Module) is between the blower motor and the passenger side kick panel.
    dirtye30's Avatar
    Aug 2006
    buffalo
    421
    why MUST i use relays??? the omega MARS R/S has em built in, at least it should. the blue and green wires coming from the r/s are tapped into the white wire....
    azbass's Avatar
    Sep 2004
    Long Beach, CA
    34,922
    relays are for a better ground, some alarms cant suply a good enough ground to triger the door locks (usually 5 wire. other special cases)
    if you do the install without relays and the door locks work. you are good.
    if you do the install without relays and the locks dont work. then add relays to provide a better ground, and the locks will magicaly work
    azbass's Avatar
    Sep 2004
    Long Beach, CA
    34,922
    and if the alarm only has 2 wires for the locks it probably does NOT have built in relays. and you will most likely need to use relays for a better ground.
    if the alarm has 4 wires for the locks then it has relays.
    from what i have see/installed.
    dirtye30's Avatar
    Aug 2006
    buffalo
    421
    alarm has 6 wires for locks. 3 lock 3 unlock. they are supposed to go to relays, BUT i was wondering if i could just tap them into the remote start that was already installed.
    THUNDERBIRD's Avatar
    THUNDERBIRD is offline CarAudio.com Veteran
    Feb 2005
    LANSING, MI
    2,316
    Quote Originally Posted by dirtye30 View Post
    so u gonna carry around 2 remotes?? why didnt u just get a new all in 1 unit. but i would think u could tap into those wires. azbass should know.
    94' thunderbird *parked*<
    4.6 V8 with a shift kit
    clarion dxz 645mp clarion sirius tuner
    ED 6000v.2- front jbl 5.25 comps- rear
    dynamated and edeaded trunk lid, rear deck, front doors
    Big 3 in green of course
    viper 791xv w/ battery backup
    3 jl 10w0
    2000 ford ranger supercab 3.0v6 4x4
    stock hu
    alpine mrp-m350
    2 9kv.3's
    clifford matrix rsx 50.5x
    spring time getting clarion MAX675VDII and front components possibly jbl's again
    azbass's Avatar
    Sep 2004
    Long Beach, CA
    34,922
    you should get a remote start alarm, in one whole unit, instead of adding an alarm to a allready installed remotestarter.
  9. #9
    dirtye30's Avatar
    Aug 2006
    buffalo
    421
    its all on one remote now. you can program a aux channel on the alarm remtoe. so now the remote start works off the alarm. anyways its not my car.
