Results 1 to 4 of 4
Reload Thread: Factory Alarms?
    SirSteve's Avatar
    SirSteve is offline Senior VIP Member
    Dec 2002
    USA
    162
    Factory Alarms?
    I just purchased a 2003 Toyota Tacoma (new system going into it) and it has a factory alarm that has these features:
    SECURITY AND CONVENIENCE ALL AT THE TOUCH OF A BUTTON
    - Vehicle Specific Design: VIP system is custom built specifically for your Toyota vehicle
    - Point-of-Entry-Protection: Activates VIP's full alarm cycle if any door, trunk, or hatch is opened without the key
    - Full Alarm Cycle: For 60 seconds the lights flash, horn sounds, starter is disabled, and the Forced Lock feature will continue to re-lock the doors(on models with electric locks)
    - Starter Disable: Prevents the vehicle from being started after the alarm is triggered
    - Hot-Wire Protection: Sounds the alarm and disables the starter if an attemt is made to start the vehicle without the key
    - Automatic Arming: Insures that your VIP system will automatically arm after exiting your vehicle(when programmed)
    - Rolling Code Technology: Helps protect your VIP system from code grabbers that can steal your security codes
    - Glass Breakage Sensor: "Listens" for noise and triggers a 20 second Warm Away Alarm if it senses that the window glass is tappped or broken. Full alarm is triggered on the second detection
    - Automatic Rearming: Allows VIP system to re-arm if no door or hatch is opened after remote disarming
    - LED Display: Warns intruders that your vehicle is protected by VIP security
    CONVENIENCE
    - Remote Keyless Entry: Conveniently locks and un-locks doors
    - Remote Arm/Disarm: Activates/deactivate VIP system via remote control
    - Passive Disarming: Allows ignition key to disarm VIP security system after automatic arming
    - Tail and Marker Lights Flash: Confirms successful arming or disarming
    PERSONAL SAFTEY
    - Panic Alarm Button: Remotely activates alarm to sound horn and flash exterior light
    - Interior Light Activation: Turns on lights when the system is disarmed using the remote
    - Door Ajar Warning: Sounds if a door is ajar when remotely arming the system
    I really like the ideao of not having to add another alarm. What does everyone think of this alarm? Should I get an aftermarket one or keep this?
    96greencivic's Avatar
    96greencivic is offline Newb to car audio
    Aug 2004
    NJ
    42
    42
    Re: Factory Alarms?
    Keep it. A buddy of mine has an Srunner and he did some mods to the stock alarm. Go to www.customtacos.com. There were some crazy buttons and the order he had to press it, but he got to customize it the way he wanted.
    **edit**
    Go here for instructins
    Audio List:
    Kenwood eXcelon X459
    MB Quart 6.5 components
    Orion 6X9's
    Directed 5 channel amp
    10" Kicker Comp Sub w/ ported box
    If there are any NJ Civic owners here, post up at Clubcivic.com and tell'em 96greencivic sent you.
    SirSteve's Avatar
    Dec 2002
    USA
    162
    Re: Factory Alarms?
    Thanks! I appreciate it.
    Aug 2004
    NJ
    42
    42
    Re: Factory Alarms?
    No problem. Always glad to help out. Have fun with all those codes though.
    Audio List:
    Orion 6X9's
