Results 1 to 8 of 8
Reload Thread: 06 randevue remote start
    Stroker_Boy's Avatar
    Stroker_Boy is offline Kendall
    Apr 2005
    Adrian, Mi
    127
    Does anyone have the wire colors for a 2006 buick randevue (sorry cant spell)
    the program we use is not helping at all.
    so if anyone has them it would be a lot of help.
    Thanks
    i use to work for Music masters electronics but im out of there now
    Looking for a job but Michigan *****
    Myspace- www.myspace.com/loveskaitlyn
    MSN- beavis_21_04@yahoo.com
    Chevyaudio's Avatar
    Chevyaudio is offline :poof:
    Mar 2005
    Back in the Dirty BR, Louisiana
    26
    13,170
    Re: 06 randevue remote start
    what program...I can try Directwire
    Apr 2005
    Adrian, Mi
    127
    we are using Installation excellence and it does tell us arm or disarm wire and resitor values
    azbass's Avatar
    azbass is offline the salty ca.com mod
    Sep 2004
    Long Beach, CA
    34,958
    12volts orange (20A), orange (10A) + ignition harness
    Starter yellow + ignition harness
    Second Starter N/A
    Ignition pink + ignition harness
    Second Ignition dk. green + ignition harness
    Third Ignition N/A
    Accessory orange + ignition harness
    Second Accessory brown + ignition harness
    Keysense lt. green - ign harn or BCM, gry 16P plg, pin A5
    Notes: The BCM is in the center console above the fuse block.
    Power Lock red/black - dr kick or BCM, pink plug, pin B4
    Notes: Lock is negative trigger thru a 470 ohm resistor. Unlock is a straight negative trigger. MUST use relays.
    Power Unlock same as power lock wire
    Lock Motor gray 5wi DKP or fuse block, blk plug, pin B2
    Unlock Motor tan 5wi DKP or fuse block, blk plug, pin A1
    Parking Lights+ DO NOT USE
    Parking Lights- lt. blue - sw or BCM, gray 16 pin plug, pin A6
    Hazards tan - switch or fuse block, gry plg,pin E2
    Turn Signal(L) lt. blue/white + switch or fuse block, gry plg,pin F2
    Turn Signal(R) dk. blue/white + switch or fuse block, gry plg,pin F1
    Reverse Light lt. green + fuse block, black plug, pin C10
    Door Trigger dk. blue/white - BCM, pink plug, pin A3
    Dome Supervision gray/black - fuse block, black plug, pin C9
    Trunk/Hatch Pin pink/black - BCM, pink plug, pin A9
    Hood Pin N/A
    Trunk/Hatch Release white/black - BCM, gray 16 pin plug, pin B1
    Power Sliding Door N/A
    Factory Alarm Arm arms on lock with door open
    Factory Alarm Disarm purple - dr kick or BCM, pink plug, pin A4
    Disarm No Unlock see factory alarm disarm
    Tachometer NOT pink or white ac any fuel injector
    Notes: On the 3.5L models, can also use purple, red/white, or lt. blue at the ignition coil pack.
    On the 3.6L models, can also use the wire that is NOT pink/black, black/white, or black at any ignition coil.
    Wait to start N/A
    Brake Wire white + brake pedal switch
    Parking Brake orange/black - switch or BCM, pink plug, pin A1
    Horn Trigger black - sw or BCM, gray 24 pin plug, pin A11
    Memory Seat 1 white - mem mod under seat, gry plug, pin A3
    Memory Seat 2 purple - mem mod under seat, gry plug, pin A2
    Memory Seat 3 N/A -
    Interface Module: Category:
    Immobilizer Bypass Required:
    Yes Type:
    PASS-Key III
    Part #: 555GW
    Alternate Part1 #: 556UW
    Alternate Part2 #: DesignTech 20402
    Alternate Part3 #: DesignTech 29402
    Notes: Standard on all models.
    Combo Interface Required:
    Yes Type:
    Data Bus
    Part #: 457GW
    Notes: Can use the 457GW to bypass the PASS-Key III, but it will not control the door locks on this model year.
    Door Lock Interface Required:
    Yes Type:
    Multiplex
    Part #: 456LW
    Notes:
    Smart Starter Kill Relays: Not Available
    Chevyaudio's Avatar
    Mar 2005
    26
    13,170
    sorry dude, I forgot about ya...but AZmike took care of you. and PS Keyless/remote start is a ***** on that truck.
    Jun 2004
    Saginaw, Mi
    27
    1,852
    Quote Originally Posted by Chevyaudio View Post
    I just looked it up on directechs and it doesn't look that bad...
    I'm lazy...
    azbass's Avatar
    Sep 2004
    Long Beach, CA
    34,958
    the pass key III crap may give ya troubles.. thoes dei modules kinda **** ***.
    Jun 2004
    Saginaw, Mi
    27
    1,852
    Quote Originally Posted by azbass View Post
    Ahh I didn't notice it was passkey3... i wasn't even paying attention, haven't had to deal with it yet.
    I'm lazy...
