Results 1 to 8 of 8
Reload Thread: bulldog security
    sdb318's Avatar
    sdb318 is offline Junior Member
    Sep 2005
    Mont Clare, PA
    26
    13
    bulldog security
    is the bulldog security remote start any good. its a do it urself tpye thing. i am just looking for something easy and cheap and something i can do on my own. it is going i n a 95 nissan maxima. post comments about this. thanks scott
    KaeZoo's Avatar
    KaeZoo is offline CarAudio.com Elite
    May 2004
    Grand Rapids, MI
    1,107
    Re: bulldog security
    I've only ever installed one Bulldog remote start and I wasn't impressed. It had built-in terminals to attach the high current wires to, but it was impossibe to slide on the spade connector without dislodging the terminal from the circuit board. I had to open it up and re-solder the terminals.
    A '95 Maxima is going to require a separate relay to activate a second starter wire. If you're not sure how to do this, I'd leave it to the pros.
    pss5075104's Avatar
    pss5075104 is offline D, FIRST CLASS CERTIFIED
    Jan 2006
    Ohio
    bulldog is junk. go with a dei sstem like viper.
    Jun 2004
    Saginaw, Mi
    27
    1,852
    Quote Originally Posted by KaeZoo
    Ekk... all connections should be soldered.
    I'm lazy...
    joeboxer5876's Avatar
    joeboxer5876 is offline Woof! Woof!
    Jan 2005
    Detroit, MI
    31
    1,825
    i had it, opened it up and thought i could do it. i probably could have done it but i would have rather just had it installed somewhere for $100. i would suggest it to anyone and i took mine back to the store.
    Mr. Nipples's Avatar
    Mr. Nipples is offline Pimp ***
    Apr 2003
    Grand Rapids
    582
    yea F Bulldogs, seriously Go with a DEI
    4 power reference Memphis 12"'s
    1 Alpine MRV 1507
    1 Kenwood KDC x979
    =148.5 db & One happy Jason
    [img]http://www.sloganizer.net/en/image,Mr-dot--spc-*******,white,black.png[/img]
    jrouter76's Avatar
    jrouter76 is offline jrouter76
    Apr 2005
    Mount Vernon ,Illinois
    1,149
    bulldog make good remote starters,I have installed 2 and they work perfectly witout a problem.I have the RS114 its a high-end remote starter from bulldog I think I paid about 50 dollars for it,it has door lock controls and pop trunk..go for it you know despite what has been said half of the responsders have never used bulldog equipment so their statement dosen`t hold water with me far too many people are quick to give their opinion on a product they never used how interesting!
    Active Front Tweeters:Seas Neo Alumn.
    Midbass:ID OEMs
    Mids & Highs amp PPI DCX1000.4
    Subs 2-12 Si Mags 2nd gen.
    Box ported tuned to 34hz 2.17 cu.ft dual chambers
    Sub amp Kicker KX2500.1
    H/U:Alpine 9815
    Doors and Trunk are deaden by SS
    PPI MAN
    REFS:2lows10, XylerB, Scoobasteve, Ksin291,TheLow, Amokie , MemphisSoul4u , TheHardKnoxLife , RydHy3845 ,GORDOS420 , Mihklo,Jameseypoo , integra88
    KaeZoo's Avatar
    May 2004
    Grand Rapids, MI
    1,107
    Quote Originally Posted by Shyne151
    Yes, but you shouldn't normally have to open up the case and re-solder terminals to the circuit board.
  1. Security
    By bigman411 in forum General Discussion
    Last Post: 11-20-2005, 10:36 AM
  2. Kenwood KDC-5019 security code input
    By CvTech in forum Wiring, Electrical and Installation Help
    Last Post: 09-10-2005, 12:36 PM
  3. alpine 98xx security screw?
    By ClayMan in forum General Discussion
    Last Post: 07-25-2004, 01:23 PM
  4. Help with security system install
    By LoneRanger in forum Subwoofers
    Last Post: 06-27-2003, 10:08 PM
