Results 1 to 4 of 4
Reload Thread: Viper 791 Help
    matt_attack's Avatar
    matt_attack is offline Junior Member
    Oct 2005
    Southern Cali
    28
    Viper 791 Help
    I just hooked up the 12v constant wire and my car wont start. I was doing just this one to make sure it would work and it didnt. Do i have to hook up all the rest of the wires or did i hook it up wrong? The constant from the battery went to the brain and then back to the factory constant. I also hooked up the ground wire cause i thought that might be the reason but its not. I left all the other wires factory. Do i need to run the starter through the alarm to get my car to start even though its still hooked up factory?
    KaeZoo's Avatar
    KaeZoo is offline CarAudio.com Elite
    May 2004
    Grand Rapids, MI
    1,103
    Re: Viper 791 Help
    Okay, I'm trying to picture what you did from what you said. Did you cut your factory constant power wire to connect it to the alarm? Which constant wire did you hook up, the small red one from the brain or the large red ones from the relay pack? Please explain EXACTLY what you connected, what you cut, where you made your connections, and what kind of vehicle you're working with.
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,715
    20
    Re: Viper 791 Help
    You also need the ignition wire ...
    NG
    http://crunktimes.com/ct/
    nG - BSEE
    zfactor's Avatar
    zfactor is offline Senior VIP Member
    Oct 2005
    usa
    37
    472
    Re: Viper 791 Help
    okay so wait what wires did you hook up besides the red one??? and what kind of car is this. we need more info to really be able to help while not there with the car
    and why did you run the constant from the car to the alarm brain then back to the car?? the alarm takes power from the car doesnt feed it back to it. or at least shouldnt if hooked up right
  1. getting a viper 791
    By bamaboy in forum Car Video, Security and Electronics
    Last Post: 08-19-2005, 08:36 AM
  2. Viper 791 alarm problem
    By gundecker in forum Car Video, Security and Electronics
    Last Post: 03-26-2005, 11:40 PM
  3. Viper 791 Alarm
    By Exploder 97 in forum General Discussion
    Last Post: 07-28-2004, 07:15 AM
