Results 1 to 4 of 4
Reload Thread: NEW to In-Dash Monitors!!
    fatkidbass's Avatar
    fatkidbass is offline Member
    Oct 2005
    Flint, Michigan
    31
    65
    Hey everyone im new to in-dash monitors and i have one and wanna know before i get installing if it's the same as installing a regular CD Player, or is it more in depth. As Much help i can get would be appreciated. Thanks.
    tRiGgEr's Avatar
    tRiGgEr is offline CarAudio.com Veteran
    Jan 2004
    San Diego, Ca
    35
    12,794
    5 Post(s)
    Re: NEW to In-Dash Monitors!!
    Depends if it has a "brain" unit. Of course the standard 12v and ground. Does it have an onboard amp? are you using it? What video sources are you hooking up?
    You have to give us some info.
    Quote Originally Posted by Scoobydoo View Post
    Before poking fun at others at least learn to spell. I won't go into all the gammar mistakes!
    Irony?
    Your sig... Im trying to figure out if you think he spelled grammar wrong. Because, he didn't. Irony indeed.
    PhatTonyDeMarco's Avatar
    PhatTonyDeMarco is offline C0CK,its whats for dinner
    May 2005
    West Palm Beach, FL
    7,729
    If you have the wiring harness to match your vehicle, it should be the same as connecting any other HU.
    Bladey's Avatar
    Bladey is offline Junior Member
    Oct 2005
    london
    49
    If u are going to buy one from the top end of the market, then it will most likely come with a brain which is normally no larger than a large bar of chocolate (U.K. Chocolate..lol). This can be mounted under the seat as the wires are only about 1-1.5 mtrs in length, or mount in Glove box. U have your usual power 12v (in sum cases X3 i/e ACC, LIVE ALWAYS and Illumination), and ground (normally only one lead). Usual set of either 8 or 4 wires for 4 or 2 speakers, most cases RCA output for amp/sub amp.. of course not forgetting the wires connecting yur head unit to the Brain. If u are mounting one of these babies, make sure u have plenty of space for the wires to run behind the head unit. Hope that helps!
  1. wireing doors and dash speakers together
    By Jacobs in forum Wiring, Electrical and Installation Help
    Last Post: 03-30-2003, 11:11 PM
  2. Anyone ever made a fiberglass console for a TV on the dash of a F150?
    By F150Matt in forum Wiring, Electrical and Installation Help
    Last Post: 10-28-2002, 09:50 PM
