Results 1 to 15 of 15
Reload Thread: check engine light came on....
    graffix989's Avatar
    graffix989 is offline Member
    Oct 2004
    east coast
    62
    ok just hooked up my system friday, lanzar VIBE286 amp(2000wattz). by sunday i noticed the check engine light came on in my car... ok so my question is that if my amp is drawing too much power will it make the check engine light go off?? shouldnt it make the little batt light turn on instead? or is this just a quencidence. i noticed my bat seems to be getting a little weaker when i go to start up my car too, but its done that ever scense this whole single digits cold front pushed in... i dunno i could be a combo of dif things my car is a POS. but i wanted to know if anyone elses light came on shortly after installing their system.
    also i dont realy crank my system up all the time eithor, i dont even have it making any kind of noise when im in the neighbor hood cuz my car will get broken into. so for now instead of upgrading to the HO alt. could i just use a switch to controll the power to my amp instead of the HU, so i could keep it turned off so the batt has enough time to recharge after running it so hard... or would that just be wasted effort.
    ExS's Avatar
    ExS
    ExS is offline eXcess
    Dec 2004
    1,036
    Re: check engine light came on....
    I had the same problem before when after I installed head unit. The light was on, but after couple of months it was off again.
    n2audio's Avatar
    n2audio is offline OPTIDRIVEN
    Dec 2001
    Lawrence, KS
    4,209
    Quote Originally Posted by graffix989
    Just turn the volume down (near minimum) a couple minutes before you turn the enginge off. That should help you get a little extra charge to the battery.
    With your check engine light -- What are you driving, and exactly how many miles are on it?
    graffix989's Avatar
    Oct 2004
    east coast
    62
    its a 92 cavalier, 133k
    nothin was wrong wit it before i put the system in it... then a day or two later it came on.. i was just wonderin if my install could of made the light come on, ill find out what the error code is tommarow. just wanted to see if anyone else had this problem before so i dont sound like an *** when im talkin to the mechanic
    deadboi77's Avatar
    deadboi77 is offline DrunkManWalking
    Apr 2004
    Mi.
    1,049
    Quote Originally Posted by ExS
    im not sure bout your ride but im mine(`96 cherokee)it resets itself after 50 start ups..krazy thing is last sunday(when a on a good road trip to a car show)and on the way home my GEN lite came on but i was getting norm volts(13.5-14.2) to my amp but we stopped and ate.. started it back up and it was off
    Breakfast well, for tonight we all dine in hell.- Leonidas 480 B.C.
    Boy, the next word that comes out of your mouth had better be some brilliant f**kin' Mark Twain sh**, 'cause it's definitely gettin' chiselled on your tombstone.
    Vestax's Avatar
    Vestax is offline Blends No. 27
    Aug 2004
    San Jose, CA
    403
    Check engine light can mean a number of things. It varies on every car. You can take it to a shop that can diagnose the problem and they'll tell you what it is. Normally, if you disconnected the battery while the key was still in ignition, the check engine light will go on. Try disconnecting the battery for a bit, then plug it back in and see if it'll go off.
    USUC World Champion - Stock System Class, Super Street Division Special Edition Bose 26 piece speaker system with enhanced ported tweeters. 89.2 db Legal, 89.6 db Outlaw
    Antonio Corleone, Uptown Golden Ear Mafia
    Bigrick31's Avatar
    Bigrick31 is offline Carpe Diem
    Mar 2004
    Mid*Cal
    3,557
    unhook your battery for a few minutes then hook it back up. should reset everything. somethims it makes the light go off meaning that there was no real problem with your car.
    j3bus2k3's Avatar
    j3bus2k3 is offline Si vis pacem, para bellum
    Aug 2004
    St. Pete, FL
    6,285
    If you don't have a seperate oil light, then its just a reminder to get your oil changed or your due for maintence according to the manufacturer. Sometimes they're just money making schemes but more often then not, they actually serve a purpose.
    AIM: SPL Performance1
    /////Alpine 9835
    Active Processing via Coustic XM7
    Dayton 7" Mid-woofer with Seas Neo Tweet
    JBL/Crown 1100 & Power 300.4
    12" TC3000 Based Custom in 2.25ft^3 at 32hz
    Wallet say But I say
    References:Moe Lester, PV Audio, sss18734, DJ-Torn, dleccord, jiggy2dmax, Negativezeroz, Bama350z, TeamPSI, dB Dom, Kenny Pollock, Flossinon24s, Patfitz9 (x2), AppleBonker, BassAddictJ, the727kid, skadude016, CaliKid, Thumper88, Djman37, TeamQuakeCelica, Cerob, Pimpedout97x, Troy_Audi0, got_focus?, Karleon, Jamaica2G, rtillare, dumple, JohnnyBusa, mattmcss, whitem1ke88, nineball
  9. #9
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,516
    1 Post(s)
    A lot of times it means that your O2 sensor is bad. Take it to a shop, get a back pressure test done on the catalytic convertor before the diagnostic test.
  10. #10
    BigPimpin18's Avatar
    BigPimpin18 is offline Member
    Nov 2004
    Seattle, WA
    110
    juss use an OBD2 sensor on it. Also check if your alternator is good (while your car is running disconnect the positive battery terminal) I had this happen to my car this past week. Also check your grounds with an ohm meter, and if you have 0 ohms than it's a good ground if not than you wanna change your ground.
  11. #11
    dbhittin's Avatar
    dbhittin is offline Banned
    Apr 2002
    Van...Wa
    29
    5,828
    or u can turn your key to the on postion, find your ecu, turn the dial, and check for codes to see why its on.. then go from there
  12. #12
    zane's Avatar
    zane is offline Bored.....
    Dec 2001
    Cedar Rapids, IA USA
    1,887
    Quote Originally Posted by BigPimpin18
    OBDII was not present until late 1994, this car is still OBDI.
    There are several relatively in-expensive OBDI Code Readers available at most local auto stores and even some Wal-Mart's.
    The OBDI ports were typically under the hood on most models, but a few did locate them under the dash, glovebox, or behind the kick panels.
    OBDI Code Readers typically use a small LED to flash the code from the vehicle. You simply observe the number of flashes of the LED and their sequence, and refer to the included book, or a Chiltons Manual for your vehicle, to see which code is being thrown.
    That's your first and most important step.
    I would seriously advise not doing anything else until you know what caused the MIL to come on.
    Ignoring it will in most situations cause the vehicle to go into "Limp Home Mode" where it's bare basics are all that's used engine wise. Performance, efficiency, fuel economy, etc, all suffer greatly in this situation.
    Throwing parts at it without the OBDI information is just a plain idiots way of working, and costs quite a bit more, and seldom works.
    Bottom line - get the code(s) first, or have AutoZone, or a Mechanic do so.
    Then and only then will you know the next (second) step to take.
    Scan the codes on the vehicle before anything is done.
    Webslave - www.SoundwavesCS.net
    "The man who goes alone can start today; but he who travels with another must wait till that other is ready."
    - Henry David Thoreau
  13. #13
    `pr0digy's Avatar
    `pr0digy is offline - turbobricks.com -
    May 2004
    Philadelphia, PA
    1,676
    Quote Originally Posted by zane
    I agree.... My car has a built in OBDI connector w/ probe, makes that pesky light SO much easier to deal with
    HU: Apline 9815
    Sub: Image Dynamics 12 v3 @ ~ 28 hz
    Sub Amp: eD NiNe.1
    Comps: Looking towards ID CTX65cs
    Comp Amp: Needed! Got 150w x2 @ 4 ohms to sell ?
  14. #14
    Primo's Avatar
    Primo is offline ibtl
    Apr 2004
    Grants Pass, Oregon
    26
    1,319
    on my truck it's easy to turn off. two wires under the dash, one of them is connected and the other isn't, just switch them and problem solved. it went off at 80k and 120k miles.
    4 life
  15. #15
    ighettoboyi's Avatar
    ighettoboyi is offline Shot Caller
    Mar 2004
    mean streets of OC
    2,702
    autozone lets you use their scanner for free....that's what i do
    DTM HATER
  1. More HP!!!!!
    By thumpinblazr in forum Car Interior/Exterior Enhancements
    Last Post: 10-23-2004, 04:20 AM
  2. HU dims, Amp light Dims, bass cuts off for 1 sec.
    By 31337hxr in forum Amplifiers
    Last Post: 05-09-2002, 02:58 AM
  3. Ok im ready to fix the engine noise.
    By iceberg in forum Wiring, Electrical and Installation Help
    Last Post: 02-05-2002, 01:59 PM
