+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 39 of 39
Reload Thread: Why do Capaciters even exist?
  1. #31
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    14,439
    192 Post(s)
    6839 Post(s)
    Re: Why do Capaciters even exist?
    Quote Originally Posted by DarkKnightSM View Post
    And i read the manual already. Very very basic installation instructions. I dont remeber there being anything about "muting" if voltage is lower in the manual
    Do you think they'd include something like that in the manual? no this is all due to people all running them and reporting problems/issues regarding this. Its from inherent amp design. Same issues with rockford's BDCP line and a few zed and zapco heavily regulated power supply amps.
    I'd recommend you getting a voltmeter and connect it at the subwoofer amp's positive and negative terminal. Yes shove it in with your 0 gauge. Whatever voltage you think you are getting, is your front battery voltage which will be significantly different from the voltage the amp sees.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
  2. #32
    Victorinox's Avatar
    Victorinox is offline Member
    Aug 2012
    Denver, CO
    47
    10 Post(s)
    Capacitor part of supercapacitors is what get people confused. Supercaps is absolutely killing it, bank of 6 500F caps can start my truck reliably every time and deliver 200-250A of current on demand in microseconds,unlike battery. It also weigh 1/10 of agm batt.
  3. #33
    Jeffdachef's Avatar
    Feb 2013
    14,439
    192 Post(s)
    6839 Post(s)
    Quote Originally Posted by Victorinox View Post
    however without proper alt power, on long sustained notes, super caps definitely get depleted and all you are left with is battery reserve. Super caps isnt an option for people that cant fit lots of alts and is running huge power. It has to be hybrid with agms or lithiums if they dont have stout alternator power.
  4. Thanks Victorinox thanked for this post
  5. #34
    wew lad's Avatar
    wew lad is offline wew lad inc
    Mar 2015
    Des Moines, IA
    4,483
    44 Post(s)
    2311 Post(s)
    Quote Originally Posted by Jeffdachef View Post
    this
    they're a great addition if you're seeing massive voltage drops on spontaneous notes but on long heavy draws without the alternator output to back them up they wont work miracles
    also to add to this;
    "super caps definitely get depleted and all you are left with is battery reserve" and depleted caps that are now requiring power themselves
    Quote Originally Posted by JohnKuthe View Post
    I AM The Future of personal transportation, NOW!!
    Quote Originally Posted by Loudz View Post
    Pretty sure everyone on this site hates you (@JohnKuthe) more then me and that's very hard to accomplish.
  6. #35
    SQBubble's Avatar
    SQBubble is offline CarAudio.com Elite
    Mar 2006
    MTL
    1,895
    10 Post(s)
    isnt voltage drop an alternator issue in the first place? id put my money on a solid HO alt and solid battery before anything else... gotta start from the source of power and work your way up from there
  7. #36
    Jeffdachef's Avatar
    Feb 2013
    14,439
    192 Post(s)
    6839 Post(s)
    Quote Originally Posted by SQBubble View Post
    Try doing two or more alts in a 2009 sienna engine bay. Only way its possible to run what im running is through battery power.
  8. #37
    mazdakid's Avatar
    mazdakid is offline CarAudio.com Veteran
    Oct 2004
    illnoise
    33
    11,339
    6 Post(s)
    1303 Post(s)
    When i was a teenager there was an older saturn around here with atleast 4 alternators, he cut holes and had them running up out of the engine bay. Youve got options lol.
    06 altima sedan
    Alpine 9887
    Sax 125.4 selenium 6.5s SEAS Prestige 27TAFNC/G
    Dd m4 2 15" fi n2
    traded-pickup1, power-fanatic07, fbi90909
    sold to-superspank, dumple, JoeRa22, sub-FATHER, TrlcKed_OuT, rosrock, dcole18, RaiN, BassAddictJ, tommyk90, MANTI5, Micah_Jones, mrflamboynt, g6ryder, rebelfromva, n8skow, crxbmpn, xr650jkallen, thewes
  9. #38
    wew lad's Avatar
    Mar 2015
    Des Moines, IA
    4,483
    44 Post(s)
    2311 Post(s)
    i have 1/4 the voltage drop that i did previously after adding a bank of caps. the caps act as a damper in a way and prevent the fluctuations from being so vast and thats why they help with voltage drop
  10. #39
    Victorinox's Avatar
    Aug 2012
    Denver, CO
    47
    10 Post(s)
    Obviously true. but amplifier don`t draw constant current on music, if you listen to sinewaves then of course.
+ Reply to Thread
