Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 16 to 30 of 37
Reload Thread: Pontiac Guys, Supercharger Upgrade?
  1. #16
    Austinw88's Avatar
    Austinw88 is offline Senior VIP Member
    Jul 2013
    South Carolina
    354
    69 Post(s)
    Re: Pontiac Guys, Supercharger Upgrade?
    Quote Originally Posted by Timmy13091 View Post
    Lol change modify a little not much ? How many of these swaps have you done ?? I've read into this a lot more them u think with v6 camaros and grand ams in the past .. Nothing is built to support that extra power and even getting the car to allow any more is decent cash ... I wouldn't bash people knowledge based on what they typed in a single thread .. I've built 2 mustangs up myself and worked around cars for years .. It's not a easy or cheap task he's looking at .. So I'm clueless about your last post bro
    Not bashing anyone, was a question.. From what everyone is saying "doing it right" is going to cost a lot? That maybe be true if he's looking to push 8-14psi in it.. Superchargers are much more efficient than turbos, turbos need more boost to make the hp compared to a supercharger. that being said... If he is looking for something daily and enjoyable 5-6 psi on a SC is perfect for what he is looking for, Not saying im the greatest mechanic out there because I know I'm not even close. But I can make 5-6 psi on a stock 3.4 safely for under 2000.
    Supercharger: 300-500
    Tune: 250
    Injectors for a gxp/gtp: 15 each on ebay 90-100 total
    Intercooler with bov, 250-300
    gaskets:100-150 from parts store.
    other stuff like the belt and some bolts, can be found cheap at a junk. Not the belt lol
    Probably around 1600-1700 i could get it done safely and right!!
    Not trying to start beef but i've worked with a lot of turbo/superchargers
    SPL Audio 18, 5.5cb ft tuned to 34 hz
    SAZ 1500DV2
    PWX 6.5x2
    Kenwood HU
  2. #17
    Timmy13091's Avatar
    Timmy13091 is offline Team DC
    Apr 2012
    Chicago
    3,000
    1 Post(s)
    1286 Post(s)
    Quote Originally Posted by Austinw88 View Post
    Tune: 250
    2,000$ is cheap to you ? And that's a best case scenario my Friend.. And pushing only 6lbs for 2,000$ that makes it a even bigger waist when stock they push way over double that safely with a tune or chip .. And then if you do push more power that torrent trans/drive train is not made to handle that at all .. So you just opened a whole new can of worms
  3. #18
    Austinw88's Avatar
    Jul 2013
    South Carolina
    354
    69 Post(s)
    2k is cheap for a budget supercharger setup yes, And back to the daily thing. you are correct about the trans/drive train wont hold a **** ton of power. But again op said he wants something more enjoyable/daily. so therefore he is not shooting for 15psi, 15 psi on a supercharger is about the same as 25 or so with a turbo. I said 5-6psi on the 3.4 which would be somewhere between 12-16 with a turbo because of turbo lag and you have a faster response with a SC. Now 5-6psi on his motor takes it from a stock 185 to somewhere around 230-250hp that's a pretty **** good gain for under 2k that is also on the safe side as i said. when I say safe I mean that for the internals of the motor and head gaskets, also for the trans/ drive train. The stock motor and trans/ drive train can handle a 50-70hp increase without being punished.
    SAZ 1500DV2
    PWX 6.5x2
    Kenwood HU
  4. #19
    ciaonzo's Avatar
    ciaonzo is offline TheContinental
    Feb 2009
    WI
    42
    10,740
    15 Post(s)
    1030 Post(s)
    Yeah, 2K is plenty reasonable. I'm not looking to take this thing to the strip, I just want to get my groceries fast. lulz
    I bought it for very little money so I can afford to put a little more into it for a bit of added horsepower. Significantly more than a K&N filter would provide but not enough to break everything down the line. I figure when I have to get in there and replace the cam sensor I can throw in some metal head gaskets if need be, but if you guys don't think the drivetrain on this thing will want to see more HP than what 5 pounds of boost will produce, it probably won't be necessary.
    Thanks for the list, Austin. I noticed that didn't include a fuel pump upgrade, that feasible?
    Saying "clipping doesn't kill speakers" is a half-truth at best. Technically no, clipping itself does not hurt the speaker. But in clipping your amp, you can easily create a situation that WILL kill the speaker. Was the squared waveform the DIRECT cause of the failure? No. In the end, the answer is, always has been, and can only be... heat kills speakers. BUT, clipping increases heat generation, sometimes by a drastic amount. So to start a thread simply to state that clipping does not hurt speakers is, again, a half-truth at best.
  5. #20
    jrdnhsnbrg's Avatar
    jrdnhsnbrg is offline Pimped my grandma's ride
    Aug 2012
    Menomonie, WI
    22
    1,874
    683 Post(s)
    Quote Originally Posted by ciaonzo View Post
    Have you considered exhaust upgrades?
    2013 Ford Taurus SEL - James aka Captain Slow
    Stock... For now.
    New build log:http://mobileaudioforum.com/forum/showthread.php?8019-2013-Ford-Taurus-SEL-audio-performance
  6. #21
    Austinw88's Avatar
    Jul 2013
    South Carolina
    354
    69 Post(s)
    no problem, as fas as the fuel pump goes I would do one and thanks for pointing that out. you might be able to use a walbro 255, they are mostly universal, but I would want to do some research on you're stock pump before doing so. the pumps are anywhere from 40-90 bucks on ebay.
    SAZ 1500DV2
    PWX 6.5x2
    Kenwood HU
  7. #22
    ciaonzo's Avatar
    Feb 2009
    WI
    42
    10,740
    15 Post(s)
    1030 Post(s)
    Quote Originally Posted by jrdnhsnbrg View Post
    I will probably need to at some point. Good for a little torque, anyhow. I don't like loud, though. Throaty but quiet would be ideal, if that makes sense.
    I just don't want this to become a project car, or have it look like I actually like Torrents, Pontiacs, or GM anything. Putting stupid light kits on it, stickers, and all that other immature garbage. It's plain and clean, just want to keep it that way. Maybe have someone say "I didn't think a Torrent would be that fast" in the sleeper sense. Nothing big.
    Oh boy... I might be a fanboy afterall. Can't help but think that Torrent would look pretty nice with these Buick rims.
  8. #23
    jrdnhsnbrg's Avatar
    Aug 2012
    Menomonie, WI
    22
    1,874
    683 Post(s)
    My car is the very definition of sleeper sound system-wise... 2001 Lincoln continental, only exterior upgrades is HID headlights (aimed properly as to not blind all other drivers) and LED switchback blinkers. Then, I added my system and yeah... Trunk kid vibrates like no tomorrow and the sunroof leaks if it's wet out and I'm bumpin
    Stock... For now.
  9. #24
    ciaonzo's Avatar
    Feb 2009
    WI
    42
    10,740
    15 Post(s)
    1030 Post(s)
    Appreciate the input!
  10. #25
    Timmy13091's Avatar
    Apr 2012
    Chicago
    3,000
    1 Post(s)
    1286 Post(s)
    No that trans and **** will not handle 70hp gain just fine lol .. Where are you getting this info. .. And 2,000$ is a best case scenario ... I'm not gunna sit and argue bottom line no it's not cheap / practical or smart to do to a daily car unless you plan to do a hell of a lot to support it all
  11. #26
    SounDrive's Avatar
    SounDrive is offline www.soundrive.audio SounDrive is a Supporting Member of the forum!
    SounDrive is a Supporting Vendor of the forum!
    Apr 2013
    Lebanon, TN
    3,072
    20 Post(s)
    1347 Post(s)
    Supercharging a torrent is like supercharging my Taurus. Only one person has done it and he spent thousands (more than a few) and a ton of labor doing it.
    And it's still slow, because... ITS STILL NOT GOT ANY HORSEPOWER. If you want a fast SUV, go buy a Trailblazer SS and call it a day. You'll be saving money in the end and going faster.
    Owner, SounDrive Audio
    Visit our store at www.soundrive.audio
    Like us on Facebook at www.facebook.com/soundriveAudio
    PLEASE EMAIL ME FOR FASTER RESPONSES - damie[email protected]
    Dealer for: SounDrive Audio | Synergy Audio | Audio Legion | XS Power | Mechman | SPL-Lab | Taramps | Limitless Lithium | Wolfram Audio | Singer Alternators | Ampere Vibraflex
  12. #27
    Austinw88's Avatar
    Jul 2013
    South Carolina
    354
    69 Post(s)
    Quote Originally Posted by Tenacious. View Post
    I am not going to disagree with this, in all my previous posted I never said he was going to get an amazing amount of hp or speed but a little. But I do agree fast suv= trailblazer ss or Jeep srt8
    SAZ 1500DV2
    PWX 6.5x2
    Kenwood HU
  13. #28
    Freeman's Avatar
    Freeman is offline I TrY
    May 2013
    Watertown, SD
    834
    310 Post(s)
    Why in the hell are u asking thus on a car-audio site Their should be a pontiac forum that people know exactly what their talking about.
    1986 Nissan hardbody
    Hu:Kenwood Kmm-100u
    front:1 Cheep Kenwood speaker.
    Rear:the 3in of room behind my seat where my amp sits
    Sub:soon
    Amp:polk pa330
    Wiring:1/0 knu kca to 4gauge distribution block and 1/0 kca big 3
  14. Likes Full Tilt liked this post
  15. #29
    Freeman's Avatar
    May 2013
    Watertown, SD
    834
    310 Post(s)
    Hu:Kenwood Kmm-100u
    Sub:soon
    Amp:polk pa330
  16. Likes Full Tilt liked this post
  17. #30
    mclerico83's Avatar
    mclerico83 is offline CarAudio.com Veteran
    Oct 2009
    tampa
    7,652
    4 Post(s)
    1033 Post(s)
    MMS 3400 Powertrain Control Module (PCM) - Milzy Motorsports
    call mms they know everything about the 3.4 (not a big fan). I own a pontiac grand prix turbo rebuilt everything dyno 452hp
    ---------- Post added at 02:34 PM ---------- Previous post was at 02:33 PM ----------
    atleast get A canned pcm
  1. Pontiac G8 Audio Upgrade
    By bobmG8 in forum Car Audio Build Logs - Cars/Trucks/SUVs
    Last Post: 09-30-2010, 12:06 PM
  2. New Guy- System Upgrade questions
    By fdimeroller in forum Car Video, Security and Electronics
    Last Post: 08-19-2008, 03:19 AM
  3. Need your guys' advice on a system upgrade...
    By ajy1013 in forum General Discussion
    Last Post: 02-04-2005, 09:16 PM
