Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 34
Reload Thread: 1997 Jeep Cherokee Sport
    Bologna's Avatar
    Bologna is offline Ad ministrator
    Apr 2009
    USA
    587
    I have a 1997 Jeep Cherokee Sport SE, 4 door, 4.0L v6
    It won't start, it'll turn over but that's it. I just bought a brand new battery and it still won't work so that's not the problem.
    It worked fine the day before but I went to turn it on in the morning and it wouldn't start. And my Jeep is kept in my heated garage every night too so it wasn't the weather.
    I can start to smell gas when trying to turn it on especially when I open the hood. Not sure what that means those.
    Any help is appreciated, thanks.
    Refs: BlackWaterOp x2, Master69 x3, Scottie x3, RidnClean, JusBlaze (Scammed Me), SPLaudio x3, ltr450racer690, dbeez, LuisT, SPY, Mgcauctions09 x3, pieper88 x3, scottyk, Jh8909, JB312, stretch, Mechman, 01SpyderDB23, andrewtexas123, 50 black guys, bubbagumper6, btr, SacTownBully84
    plugitin's Avatar
    plugitin is offline She Bangs plugitin is a Supporting Member of the forum!
    Jul 2009
    Da U.P. eh?
    23
    6,503
    1 Post(s)
    Re: 1997 Jeep Cherokee Sport
    coil...or the magnetic pickup in the dizzy.
    Team DC Audio
    Refs: absoluteaudio, rab, walnut, seedubs1, dbeez, -leister-, Louisiana_crx, bubbagumper6, DS Autpsports, Mr.Ronin_2U, lil98cabrio, wone, micah_jones, grinder1989
  3. Thanks Bologna thanked for this post
  4. #3
    Bologna's Avatar
    Apr 2009
    USA
    587
    I'm not a car guru so a little more explanation would be helpful lol. Sorry.
  5. #4
    plugitin's Avatar
    Jul 2009
    Da U.P. eh?
    23
    6,503
    1 Post(s)
    lol, its ok
    The coil is what sends spark to your spark plugs. They can and do randomly die. Pretty easy to replace.
    There is a pickup of some sort in the distributer that can go bad...should be easy to replace also.
    These would be where i would start if it was me
    Team DC Audio
  6. #5
    Bologna's Avatar
    Apr 2009
    USA
    587
    Quote Originally Posted by plugitin View Post
    lol, its ok
    Alright, I'll check that out tomorrow. I'm making a list of possible problems. Other things I have written down to check is: Fuel, air filter, compression, spark plugs, and crankshaft position sensor.
  7. #6
    plugitin's Avatar
    Jul 2009
    Da U.P. eh?
    23
    6,503
    1 Post(s)
    Quote Originally Posted by Bologna View Post
    crankshaft sensor is the only one out of there that would make it just stop running one day. Maybe, and just MAYBE the fuel filter.
    Team DC Audio
  8. #7
    Bologna's Avatar
    Apr 2009
    USA
    587
    Alright thanks bro. I'll see what I figure out tomorrow after school.
  9. #8
    plugitin's Avatar
    Jul 2009
    Da U.P. eh?
    23
    6,503
    1 Post(s)
    no problem. I doubt youll be able to tell if most of those things are bad by looking at them. I mean, if they have broken wires you will be able to.
    Team DC Audio
  10. #9
    Bologna's Avatar
    Apr 2009
    USA
    587
    The spark plugs were getting spark but I don't think enough. They sparked like every 1.5 seconds when i was cracking it over. I think it should spark faster than that.
    I just towed it up to the local car mechanic and I'm going to see what he says. But he said it'd probably be Monday before he looks at it.
  11. #10
    Rickdod3's Avatar
    Rickdod3 is offline CarAudio.com Elite
    Jan 2011
    Centralia, IL
    581
    1 Post(s)
    Im going to say its most likely a spark issue. Try that first
    Buyer/Seller Feedback
    http://www.caraudio.com/forums/buyer-seller-feedback/505787-rickdod3-feedback.html
  12. #11
    Bob Saget's Avatar
    Bob Saget is offline Banned
    Jun 2010
    Seattle, WA
    3,094
    distributor cap & rotor, fuel pump, check your major fuses & relays
  13. #12
    audioatg's Avatar
    audioatg is offline CarAudio.com Elite
    Aug 2006
    NJ 08080
    1,739
    That spit sputter spark you see when you are cranking it over is going to be some what normal. Your not going to get a good spark(well constant) from it because its not up and running. What kind of spark tester were you using. Also were did you test it.
    Pulling that cap off and check the cap and rotor you could of done yourself very very easy to do on a jeep 4.0 motor.
    My next thing is you say you can smell fuel under the hood. Its fuel injected you shouldnt smell fuel at all under the hood unless you have a leak some place. Could very well cause a no start.
    When you were sitting in your jeep cranking it. Did you happen to look at the RPM gauge did it go up from zero when you were trying to crank it. Or did it just stay at zero the whole time you were cranking it.
  14. #13
    Bologna's Avatar
    Apr 2009
    USA
    587
    Quote Originally Posted by audioatg View Post
    All I did to test the spark was take off the cover for spark plug # 6, I believe, and stick a screwdriver in there and laid it across something that was grounded.
    I believe the RPMs sat at 0. Can remember that well.
  15. #14
    plugitin's Avatar
    Jul 2009
    Da U.P. eh?
    23
    6,503
    1 Post(s)
    Hmm...makes me wana say its the lil magnetic pickup in the distributer. I forget what theyre called on the jeeps...
    and could you here the fuel pump turn on? its uncommon for them to just die. But it is possible
    Team DC Audio
  16. #15
    audioatg's Avatar
    Aug 2006
    NJ 08080
    1,739
    Its a cap and rotor type. What you and others are thinking of is a tad bit older in age, years. This type the rotor sits on a shaft and spins around sending spark to each spark plug through the cap from the coil.
    Now saying you think you seen the RPMs just sit at zero while you were cranking it. Says crank signal. Crank position sensor do go bad on the jeeps all the time. And will give you a weak spark while cranking. That sensor sits on top on the bell housing area. Near the steering shaft.
Tags for this Thread
