Results 1 to 3 of 3
Reload Thread: 2002 Accord - Power Steering Pump??
    Zxcvtypo's Avatar
    Zxcvtypo is offline CarAudio.com Elite
    Nov 2004
    Frederick, MD
    30
    1,150
    2002 Accord EX 4cyl 5-speed
    This is the noise my car is regularly making when the steering wheel is turned. Sometimes it doesn't do it at all, sometimes it's a lot worse..I can't figure out what's causing it to come on and off. It also changes a little with rpm's as I'm accelerating in 1st-2nd, leading me to believe it could be the alt or belt?
    Is it the power steering pump going bad? Alternator? Loose belt? I wanna try to get an idea of what it is before I take it in somewhere..I've read a lot of different things online.
    Out of car audio for now..
    Techmaster05's Avatar
    Techmaster05 is offline Senior VIP Member
    Jan 2010
    Venice, FL
    264
    Re: 2002 Accord - Power Steering Pump??
    have you recently gotten your alternator replaced? If so, the alternator might need to be adjusted slightly because the belt is to loose on it. It could be your power steering pump, but it can also be because of your belt. I doubt its your steering rack, if it is, than thats going to put a hole in your pocket.
    audioatg's Avatar
    audioatg is offline CarAudio.com Elite
    Aug 2006
    NJ 08080
    1,741
    8 Post(s)
    Sounds like more pump noise the belt noise. Have you checked the power steering level. May be some what low. If it is check for leaks.
