Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Reload Thread: Crown Vic won't crank!
  1. #16
    Sep 2008
    North Carolina
    28
    4,214
    1 Post(s)
    163 Post(s)
    Re: Crown Vic won't crank!
    Could be the ingniton switch relay ontop of the steering column. Real pain in the ***, ive replaced some.
  2. #17
    audioatg's Avatar
    audioatg is offline CarAudio.com Elite
    Aug 2006
    NJ 08080
    1,741
    8 Post(s)
    I just went over real quick. Have you tested voltage drop over the starter seloniod. That click noise is coming from relays in the dash fuse box location. I had a few ford trucks do the same thing( and before any one says anything its a ford they use the same setup). The battery cable is going bad. One day its good the other day its bad. When its bad it will show low voltage at the starter selonoid but have normal voltage at the battery. When you go to start it will click then everything will act like they are seeing low voltage.
  3. #18
    Jul 2006
    Georgia
    12,842
    1 Post(s)
    1167 Post(s)
    probably just getting a bad connection at times and it acts as if the batt is dead.
    Voltage drops kill your electrical also
    REFS:
    Squeak9798, Kumbos310w6, BigBangTheory, Jmanpc, MillzThaYungin, WLDock, -Leister-, ThomasG, J31Rob (and a few more I have forgotten)
    Quote Originally Posted by BassAndBeer View Post
    sorry man but ford will always be a ford. ford is the sony xplod of cars and trucks. you had bad experiences with chevy because your a ford guy. its what seperates the men from the boys. friend billy use to drive a ford. he drives a chevy now. they call him billy no more. hes known as bill now..
