Page 4 of 4 FirstFirst 1 2 3 4
Results 46 to 47 of 47
Reload Thread: Fixing Brake line help!!!!!!!!!!!!!!!!!!!!!!!!:)
  1. #46
    Slo_Ride's Avatar
    Slo_Ride is offline Take It Easy
    Oct 2005
    Back to ATL
    13,247
    35 Post(s)
    3230 Post(s)
    Re: Fixing Brake line help!!!!!!!!!!!!!!!!!!!!!!!!:)
    Quote Originally Posted by TwoEggCustoms View Post
    big thing to remember when you are bleeding your brakes are
    1. the master cylinder has to have fluid in the reservoir at all times.
    2. the person pumping the brakes should NOT let off the pedal while the bleeder is open. if this happens you run the risk of sucking fluid back in.
    3. dont leave the bleeder open for too long. if it is open when the pedal is at the floor you run the risk of sucking air in.
    also that crap about bleeding until the color of the fluid changes is wrong. you bleed the brakes until you have no more air coming out of the lines. it will be ready to hit the road when you open the bleeder and only have a constant stream of fluid comeing out. that means no spitting or sputtering and no bubbles.
    enjoy
    also why does your caliper need to be changed? is it sticking? your car is pretty new to be needing a caliper...
    Are you aware that brake fluid has to be changed? The same as engine oil, trans fluid, coolant, etc. Brake fluid over time absorbs moisture and becomes less effective at doing its job. If he is bleeding the brakes then change the fluid while he is there. I bet it has the original fluid in it. Now if the fluid has been changed and is new, then yes all he would have do is bleed the air out. But see, I know more about his situation than you do, so it doesnt matter.
    Refs = PapaGeno21, Goindef154, 92c1v1c, Disarmer, chemmins, 97maxima, kroid777, ithertz, basscort2009, hunterw, mar08052, appleyard, millimac247, jonny101abc, sundownz, cranberryyumyum, mig139, daboyfrumdabx, skateguy92, basebalz13.
  2. #47
    hornedfrog1985's Avatar
    hornedfrog1985 is offline <---Down Syndrome Tiger.
    Jan 2009
    Iowa
    6,111
    1 Post(s)
    You're going to need a lot of brake fluid. I've done this on my moms 2002 civic. Its easy as hell. Just pump the brakes VERY SLOW. You don't want to empty the brake cylinder resevoir, or you have to get that air out that got ****** in. Just recycle the new stuff back to the master cylinder when it starts coming out the ******.
    Quote Originally Posted by danyopjr View Post
    Kickers are not meant to last that long so therefore seems like this sub is either abused with running too much watts to em or have been used for awhile. Kickers are ok for the price but wont last long when running them for awhile or running too much Watts to em
    Refs thread. http://www.caraudio.com/forum/showth...read?p=6573666
