Hello, my car is running real rough while in neutral and while driving. Its rough when I put in into park and reverse. Just wondering if anyone knows about this car. Car has 68k on it. Thanks
Last time you replaced your plugs/wires/coils?
REFS
Bought from: amedeuce, danssoslow, PsychoTheRapist, mrwigglezdj, ampjunkielikeme, jerseyboy, fasfocus00, magnanimous
Traded with: manosteel916, peas247
Sold to: mustangowner, bagged97tacoma, bubbagumper6, alex95sl2
Current Setup
Alpine w505
SI BM 10" sub in vehicle specific prefab box; JBL 300.1; 300wrms @ 2ohm
Boston Acoustics Z6 components; JBL px300.4; 330+ wrms x 2 @ 3ohm
Im not sure I never have only had car few months... But this thing runs real rough you know think its something more serious
Basic tune-up would be the place to start. If it doesn't help any, atleast you know where you stand in your routine maintenance.
REFS
Current Setup
Alpine w505
Is the check engine light on if so have someone scan it and get the codes. I would start with a tune up as well or could possibly be a vacuum leak. Open the hood listen to see if you hear hissing. You would be surprised how much a small vacuum leak can effect the idling.
2002 SLP Camaro SS
Forged 402 LS6
462rwhp/418rwtq (All motor)
Vacuum leak. On those small import **** motors it can really hurt them as alot of **** is controlled through vacuum pressure.
Im better than you.
I would have to agree with the two gentlemen above. Good luck.
REFS
Current Setup
Alpine w505
I had a rough idle on my 01 Eclipse for a year after I bought used in 2007, checked the vac lines, replaced spark plugs (with Iridium), cleaned the MAS, cleaned the throttle body, and nothing seemed to help.
I finally gave up and was considering new coil packs when I looked at the plug wires real closely and I saw a tiny hairline cracks on two plug boots.
Replaced those two wires (at $18 ea...what a ripoff!) and the rough idle is gone.
Bookmarks
