Results 1 to 9 of 9
Reload Thread: How To Find Engine Block Casting Numbers
    Donks's Avatar
    Donks is offline CarAudio.com Elite
    Feb 2008
    CO, Ohio
    1,129
    5 Post(s)
    Trying to find engine black casting numbers. i think i have a SBC engine. i was told it was a 67 chevelle 350 engine. But that cant be true because they didnt even make 350's back then....im haveing hella trouble finding the casting number for the engine. where the heck can i find them. they said they were under the passenger rear but i still cannot seem to find it....and its erking me!!!
    DONKS
    Refs: Jep772, thegreatestpenn, KiLLaCaM, Redgp
    Ray21's Avatar
    Ray21 is offline CarAudio.com Elite
    Aug 2004
    The Rock
    786
    8 Post(s)
    Re: How To Find Engine Block Casting Numbers
    I've seen them on the left side (facing the front of te engine) near the exhaust manifold.
    '10 F150 - 3Sixty.2 / MTX 2150x / MTX 275x / Blueprint XBL^2 Subs/ Boston SL80
    REFs: flakko, Naxis2k1, JCJetta, jrgreene1968, NoPh33rRaCiNg, VTECnicalAccord, jadon087, sundownz, lmllopez, Toxic Tuan
    Sep 2008
    Virginia
    10,711
    350's started being made in 67 buddy.
    Sep 2008
    Virginia
    10,711
    265, 283 and 327 SBC motors are all have more HP than the 350 and the 283 and 327 make more torque.
    Sep 2008
    Virginia
    10,711
    The L-48 is the original 350 cu in (5.7 L), available only in the Camaro or Chevy II/Nova in '67 & '68. In '69 it was used in almost everything; Camaros, Corvettes, Impalas, El caminos ,Chevelles & Novas. From '75-'80 it was available only in the Corvette. L-48's use a Hyd Cam, 4bbl Qjet, Cast pistons, 2 bolt main caps, "Pink" Rods, #0014 Blocks & #993 heads. Power output ranges from 300HP(gross) down to 175HP(net).
    Well there you go, it could be a 67 but then it wouldnt be a chevelle.
    Donks's Avatar
    Feb 2008
    CO, Ohio
    1,129
    5 Post(s)
    Hopefully these pics may help you help me.....thanks
    where could the casting numbers be located on this sucker?
    DONKS
    Sep 2008
    Virginia
    10,711
    Wow thats ugly.
    Engine Code Stamping Numbers
    All engines are stamped with an engine ID code, consisting of assembly plant code, production date and suffix code. V8 codes are stamped on a pad just forward of the right side (passenger) cylinder head. 6 cylinder engines are stamped on the passenger side of the block behind the distributor
    Engine ID Code Example: V0101CLJ - (V = Plant, 01 = Month, 01 = Day, CLJ = Engine Suffix Code)
    Another example: T0830CTY - (T = Tonawanda, 08 = August, 30 = 30th day, CTY = 1970 396 Camaro, 375 hp, 11.0:1, TH400)
    Code Engine Plant Code Engine Plant
    F Flint (Motor) S Saginaw Service
    H Hydramatic T Tonawanda
    K St. Catherines, Ontario V Flint (Engine)
    (McKinnon Industries Canada)
    M GM of Mexico
    http://www.nastyz28.com/sbchevy/sblock.php
    stangman67's Avatar
    stangman67 is offline CarAudio.com Veteran
    Feb 2009
    Seattle
    2,519
    Look at the exhaust ports, are there 2 bunched in the middle?
    04 Focus
    4 sa-8
    Solid f2500
    JVC highs amp
    Parts express drivers for high end
    REFS
    Sold to: RidnClean, thegreatestpenn, MrChow, Tuck05, whitem1ke88, moo_awn, Ray21, ben031681
    Bought from: Mike465, Shinju (x3), azngotskills, Hazardous0388
  9. #9
    Donks's Avatar
    Feb 2008
    CO, Ohio
    1,129
    5 Post(s)
    according to this http://www.chuckschevytruckpages.com/casting.html
    I did find my casting number. It is 3970010
    which according to that page is either:
    3970010 - 302 1969 Camaro Z/28 - 4 bolt main bearings
    3970010 - 327 1969 2 bolt main bearings - trucks
    3970010 - 350 1969 - 80 2 or 4 bolt main bearings
    Also I Just Called the Previous Owner Stating that it was a "1976" Chevelle 350 Engine.....Must have gotten the numbers mixed...lol...idk but i think i do know now for sure its a 76 chevelle 350..
    DONKS
