Page 2 of 2 FirstFirst 1 2
Results 16 to 29 of 29
Reload Thread: headlights dont work
  1. #16
    anj46907's Avatar
    anj46907 is offline No Longer Truckin
    Nov 2008
    Bradenton, Florida
    32
    2,999
    3 Post(s)
    Re: headlights dont work
    Quote Originally Posted by Christo19 View Post
    how do i fix that anj46907?
    take alot of trash, put it in a blender and get it nice and juicy and mix it with ure gas ...will treat up to 20 gallons
  2. #17
    MisterGrubbs's Avatar
    MisterGrubbs is offline Kinda Old School
    Jul 2005
    Newnan, Georgia
    30
    5,412
    Would you guys get off the poor dudes nuts? Seriously, Jesus.
    Easiest way is to take it somewhere and have them test it, shouldnt cost anything just to test the control/switch for you.
    Educational session for you retards of the forum:Use there when referring to a place, whether concrete or more abstract. No kove, I will not come over there. Use their to indicate possession. Members of this forum have lost their minds. Remember that they're is a contraction of the words they and are. They're all idiots!
    References(Some of them):SteveyHustle, PepsiFiend69, SubNoize05, BushJ311, Mrray13, Hintzyboy, dbubble, 528hz, Twisted_0912, RKPsk8er
    Ebay: 35+ 100% Feedback Paypal: 14+ Verified
  3. #18
    Davecubs14's Avatar
    Davecubs14 is offline CarAudio.com Elite
    Sep 2008
    Madison, AL
    26
    1,077
    11 Post(s)
    I have a 2001 2 door blazer......I had the same problem not too long ago.
    Where is your power cable located?
    When I had the problem, mine was actually hooked to the fuse box and ran to my amp.....but at the same time, I got a new battery and moved my wire to the pos. side of the battery. So i'm not sure which one fixed the problem.
    '11, '12, '13, '14 Meca Street 2 AL State Champ
    AL Meca Street 2 Record Holder
    2012 Meca Street 2 World Finals - 3rd Place (148.7)
    2013 Meca Street 2 World Finals - 2nd Place (151.1)
    2014 Meca Street 2 World Finals - 2nd Place (152.3)
    https://www.youtube.com/user/davecubs14
  4. #19
    Christo19's Avatar
    Christo19 is offline Rockfords are God.
    Jul 2009
    Bozeman, MT
    256
    2 Post(s)
    alright thanks mistergrubbs, your alot more help then those other dooshers
  5. #20
    Christo19's Avatar
    Jul 2009
    Bozeman, MT
    256
    2 Post(s)
    it gos from the pos side of the bat then up alot the far side of the engine bay then down through that main grommet, its not touching the fuse box
  6. #21
    Davecubs14's Avatar
    Sep 2008
    Madison, AL
    26
    1,077
    11 Post(s)
    Hmm...how many watts are you pushing through? Cause like I said, I also upgraded the battery and the problem went away.
  7. #22
    Christo19's Avatar
    Jul 2009
    Bozeman, MT
    256
    2 Post(s)
    well right now only 500 but they stopped working befor i ran my power cable or my rcas
  8. #23
    Davecubs14's Avatar
    Sep 2008
    Madison, AL
    26
    1,077
    11 Post(s)
    That's weird man. If all fuses look good and such, I would just take it to a shop. Sorry, i'm all out of ideas.
  9. #24
    Christo19's Avatar
    Jul 2009
    Bozeman, MT
    256
    2 Post(s)
    alright thanks
  10. #25
    audioatg's Avatar
    audioatg is offline CarAudio.com Elite
    Aug 2006
    NJ 08080
    1,741
    8 Post(s)
    No headlight function. Turning the headlights on there is power available to the fuses in the Under hood Electrical Center (UHEC). No power at any of the headlights.
    Tests/Procedures: 1. Turn the headlights on, verify power is available at the LTHDLP and RTHDLP fuses. (Key off)
    2. Check the LtGreen connector at the UHEC, pin B1 a Yellow/Black wire, pin B2 a double DkBlue wire and pin A2 a DkGreen/White wire for voltage on all of them.
    3. If no voltage is present verify tight and clean terminal connections.
    4. If OK replace the UHEC.
  11. #26
    audioatg's Avatar
    Aug 2006
    NJ 08080
    1,741
    8 Post(s)
    No low beam headlight operation, no Daytime Running Lights (DRL) operation. Vehicle owner replaced the headlight switch and the multi-function switch on the column. Tested all fuses. Have power at headlights, no ground. Can ground light at headlight and lights do work. Tested at headlamp ground relay. Has ground at Black wire. Light Green/Black wire is not grounded. High beam lights are on normal operation. Ground the Light Green/Black wire, the high beam lights decrease to half brightness.
    Tests/Procedures: 1. Test Yellow wire from ground relay at body relay block terminal A11 to C211 48 cavity connector below steering column terminal E13.
    Potential Causes: Ground
    Terminal Contact
    Wiring
    Tech Tips: Body relay block is located behind left side of dash, right of the Instrument Panel fuse block. BROKEN WIRE ON CURCUIT 525 INSTALLED NEW WIRE FROM MULTIFUNCTION SWITCH TO HEADLIGHT.
  12. #27
    audioatg's Avatar
    Aug 2006
    NJ 08080
    1,741
    8 Post(s)
    Two tests try them out. Also when check the fuses remove then and test each side for voltage. Well the side that is supposed to get voltage. ALso Try swapping fuses some times they can test okay but still dont supply voltage.
  13. #28
    Christo19's Avatar
    Jul 2009
    Bozeman, MT
    256
    2 Post(s)
    alright its the switch and im buying a new one today. 99% sure that will fix the problem
    1983 BMW 320i turbo
    HU:Kenwood x891
    FS: looking for Focal access comps, anyone have any?
    RS:Focal access 5x7
    Amp: Alpine 5 chan f357
    Mid bass: RF p2 8"
    Sub: Alpine type X
    Sub amp: Looking for something
    REFs: Socailstealth, Jake21, BLD 25, k3n12ock, sq_guru
  14. #29
    KyleBechtold's Avatar
    KyleBechtold is offline Buy my fuses $1.25ea
    Nov 2008
    Tampa, Florida
    7,218
    126 Post(s)
    how is your switch setup? is it on a stick from the side of the wheel or on the dash near your door? if its on the stick see if your brights work by pulling it back..
    Ca.com
    Bought from: Sctattooer, Korn4Life, wgsj_fortvalley, bk12321, Queball, bumpincrv, Splmaster, 310w6, Buck, liljojo4711
    Everyone I have Bought from has been awesome.. feel safe with any of them..
    Sold To: Iakona, dustinr, squeak12, Worstenemy453, BeAlLsTaR13, rmzsuzuki89, c_b_, mendon mafia, dropped_tb, SPLluminator, violence., power-fanatic07, schackel, michaellane, aviator08, kodak314, dropped_tb
    Ref Link
    Tamparacing
    -b15spec, 727kid, pshull727, Nt_Hardcore
    Want/Need ANL fuses cheap 150a 200a 250a 300a
    CLICK ME
