Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Reload Thread: idle questions..
    KyleBechtold's Avatar
    KyleBechtold is offline Buy my fuses $1.25ea
    Nov 2008
    Tampa, Florida
    7,233
    1 Post(s)
    idle questions..
    When i first turn my car on and its in park my car will idle at 1k rpm and will stay there.. i can bump my system full blast and stay at 13.7-14.2.. now then as soon as i put it in drive it will idle at 700 rpm or lower.. and my voltage will be 12.8-13.2 when bumping.. even if i now shift it back to park it will still be same rpms.. is there any way to increase idle rpms with out hitting the pedal?
    Ca.com
    Bought from: Sctattooer, Korn4Life, wgsj_fortvalley, bk12321, Queball, bumpincrv, Splmaster, 310w6, Buck, liljojo4711
    Everyone I have Bought from has been awesome.. feel safe with any of them..
    Sold To: Iakona, dustinr, squeak12, Worstenemy453, BeAlLsTaR13, rmzsuzuki89, c_b_, mendon mafia, dropped_tb, SPLluminator, violence., power-fanatic07, schackel, michaellane, aviator08, kodak314, dropped_tb
    Ref Link
    Tamparacing
    -b15spec, 727kid, pshull727, Nt_Hardcore
    Want/Need ANL fuses cheap 150a 200a 250a 300a
    CLICK ME
    Apr 2009
    dallas tx
    6,962
    1 Post(s)
    Re: idle questions..
    yes theres a way but i forget how. my step brother showed me how to adjust the idler control. google it?
    Nov 2008
    Tampa, Florida
    7,233
    1 Post(s)
    the wire attached to the pedal? like i can rev the car from the engine.. i know where that wire is attached to a lever.. that what you talking about?
    Ca.com
    Ref Link
    Tamparacing
    CLICK ME
    Apr 2009
    dallas tx
    6,962
    1 Post(s)
    maybe. i never saw him do it. but when i brought it his hsop he explained to me HOW to do it. i know thats not much help but i know for a fact that u can raise the idle of a car. my explorer went from 500 to almost 1200 at idle. i had a bad idle problem
    Nov 2008
    Tampa, Florida
    7,233
    1 Post(s)
    don't want 1200 just want like 1k rpm at idle..
    Ca.com
    Ref Link
    Tamparacing
    CLICK ME
    Nov 2008
    Tampa, Florida
    7,233
    1 Post(s)
    could you ask?
    Ca.com
    Ref Link
    Tamparacing
    CLICK ME
    Apr 2009
    dallas tx
    6,962
    1 Post(s)
    its almost midnight i would have to ask tommorow. ill shoot u a pm after i do if thats cool?
    Nov 2008
    Tampa, Florida
    7,233
    1 Post(s)
    Quote Originally Posted by basscort2009 View Post
    lol i didn't mean now.. like CALL HIM NOW!! lol but ya thats cool... i am in no hurry.. i have a 2001 altima if its relevant..
    Ca.com
    Ref Link
    Tamparacing
    CLICK ME
  9. #9
    Apr 2009
    dallas tx
    6,962
    1 Post(s)
    yes it is relevant lol. throttle body or carboratoer? (<---spellcheck)
  10. #10
    ▼)Ñ╩fZΣµΣ♠░ÿ's Avatar
    ▼)Ñ╩fZΣµΣ♠░ÿ is offline CarAudio.com Elite
    Jan 2008
    reno
    1,532
    just get a bigger alt?
  11. #11
    Apr 2009
    dallas tx
    6,962
    1 Post(s)
    no its probly just an idle control valve or some cars have an idle screw u can tighten and make it idle higher
  12. #12
    TnT_Sounds's Avatar
    TnT_Sounds is offline profiling gets **** done!
    Apr 2008
    Colorado
    23
    3,624
    There's a module you can buy for an adapter to the TPS. Throttle position sensor. I have one and its fully adjustable, you can program the 4 buttons to have various idle controls.
    1 is my normal idle 750-800
    2 is 1500rpm
    3 is 2000rpm
    I have one on my drag car as well. They come in handy and are mainly used for those so you can hold a steady burn out idle and stage line idle.
    3 8's
    39.9 consistently
    Quote Originally Posted by PV Audio View Post
    It will never be proved that loudness is somehow related to SPL because it isn't.
    Loudness, a subjective measure, is often confused with objective measures of sound pressure such as decibels or sound intensity.
    Quote Originally Posted by Pete Kulicki
    Building a stereo just to measure it's sound pressure level is like building a microwave oven for no reason other than to measure it's electromagnetic radiation emissions.
  13. #13
    ciaonzo's Avatar
    ciaonzo is offline TheContinental
    Feb 2009
    WI
    8,636
    21 Post(s)
    You may also want to consider adding an additional electric fan for the radiator depending on how sensitive the engine is. Sitting still for too long with even a slightly higher idle will make some engines run a bit hot.
    My Toyota has a small screw on the throttle body that allows for idle adjustment. Very easy.
    Saying "clipping doesn't kill speakers" is a half-truth at best. Technically no, clipping itself does not hurt the speaker. But in clipping your amp, you can easily create a situation that WILL kill the speaker. Was the squared waveform the DIRECT cause of the failure? No. In the end, the answer is, always has been, and can only be... heat kills speakers. BUT, clipping increases heat generation, sometimes by a drastic amount. So to start a thread simply to state that clipping does not hurt speakers is, again, a half-truth at best.
  14. #14
    TnT_Sounds's Avatar
    Apr 2008
    Colorado
    23
    3,624
    Make sure with an electric fan you have a fail safe light.
    I've seen to many precious drag cars burn up from people thinking there electric fan is working when they are driving and it wasn't.
    The light will turn on when it thinks your fan isn't turning on and the engine is too hot.
    3 8's
    39.9 consistently
  15. #15
    SicAudio's Avatar
    SicAudio is offline did you fart dude?
    Apr 2009
    melting HO alts...
    42
    6,211
    find the screw that adjusts the cable at the throttle body and turn it clockwise till you reach the 1k mark do this after the car is warmed up and after you have put it in drive then back to park.
    Quote Originally Posted by slammedincouch View Post
    Sic rolled me in front of my mom earlier...
    Quote Originally Posted by misfit138 View Post
    How did you manage to pack that much stupid into such a small amount of words?
    Quote Originally Posted by Magnus View Post
    I got rick rolled by SicAudio lulz
    I just got rick rolled by SicAudio again lulz.
    Quote Originally Posted by chickaboom View Post
    awww.... dude! I can't believe you were the first! to rick roll me! I am a noob!
    sold to: Johnny Law.Lulz/Worstenemy453,Pumkinman, j1b1e1, DexterMoped, miyagi gboo559,CSU87,nate2587, MichaelLane, SmLLySack. MR_Imperial, Herrrerra, ltr450racer690, 05fronty bought from: TripleB45, bigwheel15, (kroid77 but never recieved..)
    helping noobs daily PM me
